Re: Vanzari/cumparari - piese de ocazie
Vand sistem franare complet BMW E46 328:
-etrieri fata -port-etrieri fata -placute frana fata (minim 75%) -discuri frana fata -etrieri spate -port-etrieri spate -placute frana spte (aproape noi,95%) -discuri frana spate PRET:200euro Interior Recaro textil/electric/memorii (BMW E46 coupe): -scaune fata -bancheta spate -fete de usi PRET:300euro 0767040634 0729926451 YM:catalinvlad85 |
CAUT in continuare airbag ( model poza ) ASTEPT OFERTE
https://s3.postimage.org/w3ijzz7wf/18102011680.jpg https://s3.postimage.org/jdebmvzy7/18102011678.jpg https://s3.postimage.org/co7s6vem7/18102011679.jpg |
*** VAND ***
- MOTOR 2.8 VANOS ( ESTE INCA PE MASINA ) * MOTORUL + ACCESORII + SISTEMUL ASC+T - 24 MIL - MOTOR 1.8 i M43 ( ESTE INCA PE MASINA ) * MOTORUL + ACCESORII - 7 MIL - MOTOR 1.8 is M42 ( ESTE INCA PE MASINA ) * MOTORUL + ACCESORII - 12 MIL DETALII : trushk_vl / 0748628686 |
12 Attachment(s)
VOLAN M SINGLE STAGE - 350 LEI VOLAN 3 SPITE CU AIRBAG - 200 LEI VOLAN 4 SPITE CU AIRBAG - 70 LEI VOLAN 3 SPITE FARA AIRBAG - 70 LEI MAPA BMW - 60 LEI O PARTE DIN PACHETU MAHON - 120 LEI BOXE BMW + CUTIE - 60 LEI PLEOAPA LUNETA SEDAN - 90 LEI PLEOAPE SCURTE HELLROT - 60 LEI |
cumpar o janta de tabla pentru urs, 4x100 pe 14
astept pm |
20 Attachment(s)
Jante BMW MOTORSPORT 4 buc/17+ anvelope iarna ( nu sunt OEM )
pret: 550 euro |
*** C U M P A R PT BMW E36 SENZORI PARCARE PDC SA FIE COMPLET OFER PRETUL CORECT ***
0767 350 190 TEO ID / bmw_e36mcoupe MULTUMESK |
6 Attachment(s)
am si eu un set jante bmw 5x120 17
400 euro negociabil |
Vand Set Proiectoare ZKW care se potrivesc pentru gama BMW:
- SERIA 3 E90 SI E90LCI PE PACHET M - SERIA 3 E91 SI E91LCI PE PACHET M - SERIA 5 E60 SI E61 PE PACHET NORMAL - SERIA 6 E63 SI E64 PE PACHET NORMAL - SERIA X ANUME X3 E83 SI X3 E83LCI PE AERODINAMIC PACKAGE 1 SI 2 Part number-ul proiectoarelor, asa cum se si poate vedea in poze este 6317 6 910 791 si 6317 6 910 792. Nu prezinta absolut nici o crapatura/ ruptura/ lipitura. Pretul unui proiector nou OEM este de 107eur, eu cer pe ambele 90eur. Contracost pot oferi pentru ele si kitul complet de xenon HB4. |
https://forum.4tuning.ro/524-anunturi...-17-4-buc.html Cel Mai bun pret la cele mai bune anvelope
cumpar timonerie cutie ZF pentru e36. 0745853326
Cumpar pentru e46 berlina FACELIFT stopurile de pe portbagaj cu ALB-ROSU.
caut capace praguri pt e36 ca modelul din poza orice culoare
cumpar suport prindere bara stabilizatoare+suruburi bmw e36
Geam oglinda M, dreapta, cu incalzire are cineva?
Am si eu nevoie de un sfat, daca ma puteti ajuta;
am un e 34, 525, m50, care are in ea ulei castrol edge 5w30. Nu imi place de loc cum se comporta cu acest ulei, in sensul ca are un consum exagerat. M-am documentat putin si acest ulei nu are nimic de-a face cu motorul meu. Asa ca nu prea stiu cu ce sa il inlocuiesc. M-am gandit la un ulei bmw 10w-40 sau 5w40. Imi puteti sa niste sfaturi! Apoi daca are cineva motorasul de la incalzire, caci al meu cam face zgomot si alte grile de incalzire, cea centrala si stanga fata. Eventual sa se riste sa mi le si schimbe. Merci |
*** C U M P A R PDC(SENZORI PARACARE)SISTEM COMPLET PT E36
SISTEM HI-FI COMPLET PT E36 OFER PRETURILE CORECTE TEL / 0767 350 190 TEO ID / bmw_e36mcoupe MULTUMESK |
Daca vrei iti pot aduce ulei OEM BMW la 8eur/litru. Daca te intereseaza, intra mai bine aici :arrow: https://forum.4tuning.ro/641-piese-bm...ml#post4695193 |
Premium EDGE 5W-40 Mid-range magnatec 10w-40 |
Multumesc!
Am vazut si eu recomandarile de la castrol. Dar nu stiu ce sa zic, sa fie asa mare diferenta intre 5w30 si 5w40, la edge?. Tu daca ai fi in locul meu ce ai alege edge sau magnatec? |
Sa sti ca si eu m-am gandit la OEM BMW, care e facut tot de castrol, 10w 40. sau chiar varianta aceea 5w-40. O sa ma gandesc si iti spun.
Multumesc oricum |
Bafta |
Multumesc. Asa o sa incerc
caut difuzor bara m
vand grila E36 pret 50 lei tel 0755399055
8 Attachment(s)
DEZMEMBREZ 4 MASINI BMW E 36 ( COUPE BERLINA CABRIO COMPACT BRECK ) + multe alte piese pe stoc .....
Elemente de caroserie si motor . Pt alte detalii 0726.290.042 . Id mesenger : mecanicautobmw - aeroterma completa - airbag pasager - alternator - ambreaj - amortizoare fata spate - arcuri - arcuri amortizoare si flanse - aripa fata spate - armatura bara spate - ax volan - baie de ulei - balamale capota - bandouri oglinzi aripa - bara Spate cu senzori si fata - bara torsiune cu tot cu bielete antiruliu - bascula / brat fata spate - bloc proiectoare ceata - bloc semnalizare - bloc stergatoare - bobine inductie - buton asc - buton avarie - cablaj electric - calculator ABS - calculator airbag - calculator inchidere centralizata - calculator lumini - calculator sensor airbag - cap bara - capac motor radiator, tampon si support motor - capitonaj caroserie pt. motor + cutie - capota fata si spate - capota portbagaj - cardan - cardan ,cruce cardanica - carenaj roti (aparatori nori) - caseta directie - caseta directie-servo - ceasuri bord - ceasuri bord ,century - centuri fata spate - chedere (usi,geamuri,portbagaj,capota), furtune si plastice - chedere usi - CLIMA - coloana directie - comanda CLIMATRONIC - conducte aer conditionat - contact - contact usa - convertor - cupola - cutie automata hidramata e36/e34 - cutie automata hidramata steptornic - cutiera ,buton oglinzi - difuzoare originale - difuzor plastic radiator - discuri fata ventilate originale bmw - discuri spate ventilate originale bmw - electromotor - electroventilator - elemente plastic usi - eleron - etrieri fata spate - evacuare motor - faruri originale Bosh - flansa cardan - flansa cardan - fulie pompa servo directive - furtun motor alimentare radiator - fuzeta fata spate - fuzete cu tot cu rulmenti - fuzetele in 5 prezoane fata spate - geamuri electrice fata+spate + butoane+ instalatie + consola - geamuri laterale spate - grila fata - grup diferential - haion coupe/sedan - incuietoare cu motoras ,yala, broasca - injectoare - instalatia electrica - Instalatie spalare parbriz 5 L (bidonas,pompa,stropitoare,maneta) - interior complet piele crem - intrerupator lumini ceata - jante bmw 15” 16” 17” 18” si cauciucuri diverse marimi - jug, suport motor si cutie, cu tot cu suruburi - lampi interior (plafoniere) cu spot de citit, set complet fata+ spate - lucasuri aripa alb - luneta cu dezaburire si relee - macara electrica fata spate - macara geam electric si manual - magazie originala 6 cd cu tot cu capacul special din portbagaj - maner usa - manere interior deschidere usa - maneta obc - mânere usi exterior - mocheta fete de usi - modul confort inchidere centralizata si geamuri electrice - motoras inchidere centralizata usa + usita rezervor - motoras inchidere portbagaj - motoras stergatoare - oglinda interior - oglinzi electrice heliomate, complete si întregi - parbriz - pedala frana acceleratie - pistoane admisie - planetare - pompa ABS - pompa ambreaj - pompa benzina - pompa frana - pompa servo - pompa servofrana cu tot cu conducte - praguri laterale - proiectoare - protectie cardan si toba - punte fata - punte spate - racord, debitmetru, clapeta acceleratie - radiator - radiocass original bmw - reglaj manual volan - relee, bloc lumini - rezervor benzina - roata rezerva subtie pe 16 - robineti caldura - scaune incalzite toata instalatia - scrumiera , plafon, parasolare cu oglinzi - semnale fata albe - senzor ABS - senzor centura - senzor parcare - sistem ventilare (aeroterma-radiator, motoras si carcasa completa) - soclu bricheta, bricheta, scrumiera - sonda lambda, termostat - stopuri sedan - suport cal cotiera - suport proiector, cric - tamburi frana mana - tampoane bara spate - tapiterie portbagaj - telescoape portbagaj - timonerie cutie - tompoane bara lonjeron - torpedou, oglinda interior - trager /suport faruri - usa originala portiera - usi portiere sedan coupe - usita rezervor e46 - vas apa si pompa apa stergatoare - vas exp pompa frana - vascocupla - ventilator+suport radiatoare - volanta |
am eu 100 ron ... 0726290042 sau id mesenger : mecanicautobmw
Am multe piese ...astept detaliii poate te pot ajuta .... 0726290042 sau id mesenger mecanicautobmw
macara fara motoras de coupe 100 ron
geam oglinada 50 ron Quote:
Geamuri electrice spate coupe, ai?! :D |
gasesti la mine aproape orice 0726.290.042.
Discuri fata e 36 - 6 cilindri 150 ron perechea .... chiar foarte bune Quote:
:) am avut o masina cu geamuri el spate ... au ramas la mine pe masina .... dak m hotarasc sa le vand te anunt momentan ma mai bucur si eu de ele ...:)
DEZMEMBREZ BMW E 36 CABRIO . 0726.290.042.
softop 250 euro macarale elctrice fata 200 ron cu motoras macarale electrice spate 200 ron complecte motorase decapotare 100 euro buc porbagaj cabrio 100 euro. JANTE 17" m3 ... 5 BUC etc etc etc ..................... ELEMENTE DE CAROSERIE SI MOTOR nu mai am numarul tau de tel dar lasa ca il iau de la sprinter ;) te sun stai linistit ...momentan vreau sa m mai bucur si eu de masina :) Quote:
1.Tripla dreapta BMW e46 facelift(rosu-galben) - 100 ron
2.Bec Xenon H7 35W 6000K - 30 ron 3.Stopuri Led e36 Coupe/Cabrio - NOI(Dectane) - 250 ro 4.Grile crom NOI BMW e46 facelift - 100 ron/set 5.Grile crom NOI BMW e36 - 80 ron/set 6.Volanta Masa Dubla e46 - 300 ron/set 7.Toba finala BMW e46 diesel - 150 lei/buc 8.2 Amortizoare spate Sachs-Boge e36/e46 - 80 lei/ambele |
cumpar bratul de oglinda ( fara sticla) stanga pentru un e46 coupe !
cumpar motor e46 1.9 benzina 118 cai
| All times are GMT +2. The time now is 21:58. |
