-   Scule-Echipamente Service (https://forum.4tuning.ro/528-scule-echipamente-service.html)
-   -   Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc (https://forum.4tuning.ro/528-scule-echipamente-service/119818-vand-polizor-dublu-masina-gaurit-coloana-electromotor-u650-alternator-u650-etc.html)
coxaru 22-01-12 19:35
re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
o poza cu polizorul si care e ultimul pret?
ellaghe72 13-02-12 09:16
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron
Alternator Volkswagen Jetta-S.H.-----------------------------90ron
Alternator Tractor U 650(12V;Cod 1134;36A)(NOU)------------300ron
Semicuzineti Palier+Biela R1 pentru Tractor U 650--------------140ron
Element filtru ulei avion(inoxidabil)---------------------------50ron
Mandrina rapida precisa 0-10mm(pe filet)-------------------40ron
Mandrina 20/B22-fixare pe con morse----------------------50ron
Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron
Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----200ron
Placute Widia------------------------------------------------5ron/buc
Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron
Polizor trifazic(380V) dublu PD 300------------------------450ron
Dulap metalic tip fiset---------------------------------------200ron
Dulap metalic 2 usi------------------------------------------400ron
Masina gaurit cu coloana(380V)---------------------------1300ron
Pompa picior(1cilindru)------------------------------------------12ron
Pompa picior(2cilindrii)-------------------------------------------22ron
Cutite strung vidia--------------------------------------------------5ron/buc.
Set placute vidia(10buc/blister)(12x12)---------------------------150ron
Semeringuri FARTEC-----110x130x13--------------10ron
------80x100x13----------------------------------------8ron
------50x70x10------------------------------------------7ron
-------35x50x8--------------------------------------------5ron
--------26x42x10------------------------------------------4ron
Manometru presiune0-250atm.-------------------------------------10ron
Manometru presiune 0-60atm---------------------------------------8ron
Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc
Cutite strung 10x10--------------------------------------------------10ron/buc
Stativ magnetic ceas comparator---------------------------------100ron
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron
Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron
ellaghe72 16-03-12 00:13
Vand:
Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)--------12ron
------80x100x13-------------------------------------------------8ron
------50x70x10(butuc roata ARO)--------------------------------7ron
-------35x50x8(distributie Dacia)---------------------------------5ron
--------26x42x10(planetara Dacia 1310---------------------------4.5ron
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------375ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------490ron
schumaker 05-04-12 19:44
Pompa picior(2cilindrii)-------------------------------------------22ron...mai este ?
ellaghe72 05-04-12 20:15
Inca mai este.
ellaghe72 23-04-12 13:02
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------70ron
Alternator Volkswagen Jetta-S.H.-----------------------------60ron
Masina gaurit cu coloana(380V)---------------------------1400ron
ellaghe72 27-04-12 21:46
Electromotor Volkswagen Jetta-S.H.----------------------------90ron
Alternator tractor U 650(12V;Cod 1134;36A)(NOU)----------300ron
Semicuzineti Palier+Biela R1 Tractor U 650-------------------140ron
Electromotor(Demaror)Tractor U 650(NOU)-------------------550ron
Alternator Volkswagen Jetta-S.H.-------------------------------90ron
Element filtru ulei avion(inoxidabil)-----------------------------40ron
Polizor trifazic(380V) dublu PD 300---------------------------450ron
Dulap metalic tip fiset------------------------------------------250ron
Dulap metalic 2 usi--------------------------------------------400ron
Masina gaurit cu coloana(380V)----------------------------1400ron
Pompa picior(1cilindru)-----------------------------------------12ron
Cutite strung vidia-----------------------------------------------5ron/buc.
Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)----10ron
------80x100x13----------------------------------------------------8ron
------50x70x10------------------------------------------------------7ron
-------35x50x8------------------------------------------------------5ron
--------26x42x10----------------------------------------------------4ron
Cutite strung 10x10--------------------------------------------------5ron/buc
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron
Electromotor(Demaror),,BALKANCAR''Bulgaria------------------------450ron
Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-----------------50ron
Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-------100ron
Radiator Motostivuitor motor 3 cilindrii----------------------------------160ron
telef.0763012130
ellaghe72 20-09-12 17:35
Re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
Vand:
telef.0763012130
ThEMaTriX 17-11-12 17:45
salut, ai cumva un manometru pana la 160 bar cel putin ? daca da vreau o poza si un pret
ellaghe72 02-12-12 18:14
Vand:
telef.0763012130
t@uru 10-01-13 07:43
poze te rog si dimensiuni
ms
ellaghe72 16-01-13 15:01
Vand:
telef.0763012130
ellaghe72 12-02-14 21:00
Vand:
telef.0763012130
ellaghe72 16-07-16 21:36
Vand:
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------300ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------400ron
telef.0763012130
ellaghe72 13-04-18 07:43
Vand:
telef.0763012130
