Re: my tuning r5
JVC KD-AVX11
Re: my tuning r5
ceva nou
Re: my tuning r5
Doar atat? Restul unde e?
Re: my tuning r5
mai are un picior in pachet nu vezi?
Re: my tuning r5
ala e piciorul meu... sa nu va luati de el :)))
Re: my tuning r5
ornament de gtt + o gromada de problema pentru ca trebe sa tai aripa si trebe sa prelungesc bara din spate si fata etc.
Re: my tuning r5
Coltarul spate l-ai facut din spuma???
Re: my tuning r5
...da
Re: my tuning r5
nu inteleg de ce te incapatanezi sa pui hidosenia aia de prag care nu are nici o treaba cu masina, acum ca ti-ai achizitionat arcadele..din spuma iti poti confectiona doua praguri de gtt, o bara spate gasesti -->> https://forum.4tuning.ro/481-anunturi...te-r5-gtt.html eu zic ca e super pret, iar pe fata iti pui o bara de campus cum are bnz-ul....sau andy wpo, sau poate da domnul sa gasesti una de gtt , nu conteaza starea, dar sa o gasesti.
Re: my tuning r5
de la monstri la masini de serie e o realizare ;):-)
Re: my tuning r5
Merge acel JVC DVD player??Nu`l vinzi ...??
Re: my tuning r5
da merge dar numai am, amvanduto.
Re: my tuning r5
nou amplificator kenwood
125 watts RMS x 2 at 4 ohms 250 watts RMS x 2 at 2 ohms 500 watts RMS x 1 at 4 ohms in bridged mode stereo or bridged mono output Tri-way capable (Tri-Way crossover required) infrasonic filter (15 Hz, 24 dB/octave) 50-200 Hz crossovers: 12 dB/octave high-pass, 18 dB/octave low-pass 12 dB bass boost variable from 40-100 Hz (expandable to 6/12/18 dB when connected to a Kenwood Excelon receiver equipped with BMS controls) Bass Management System preamp outputs fan cooling speaker short, low battery, thermal overload, and DC protection variable color indicator gold-plated terminals requires 4-gauge power and ground leads — wiring and hardware not included with amplifier 2" wide detachable terminal covers |
Re: my tuning r5
Re: my tuning r5
omule .. fara suparare masina asta e COAPTA de rugina din toate incheietuile posibile si tu nu stiu ce faci ...
golesteo toata , pune mana pe smilgher etc si dai freaca sudeaza fibreaza ! |
| All times are GMT +2. The time now is 17:17. |
