Re: Sibiu, discutii off-topic
Ia zi .. cand te fac o liniuta ? aaa .. cand imi iau carnetul :)) |
Facem facem , dar nu te cunosc :) Cel putin nu de pe forum :P
Stai sa se mai indrepte putin vremea sa putem iesii ca oamenii fara multe haine pe noi :P |
Cine stie un importator/distribuitor Dayco prin Sibiu?
CE PATESTI DACA CIRCULI FARA BARI? ITI IAU ASTIA TALONU SAU E VRAJEALA
Depinde la ce masina.
Multe masini au barile prinse de masina iar peste vin bari de plastic (ornamente). Cu acele masini teoretic poti sa circuli pentru ca au bari. |
atata vreme cat ai placutele de inmatriculare la vedere n-au treaba cu tine
VAND Statie auto MTX Audio Model THUNDER 6500D
150 watts x 2 at 4 ohms 250 watts x 1 at 4 ohms 500 watts x 1 at 2 ohms 775 watts dynamic power x 1 at 2 ohms Adaptive Class D Technology variable 40-200 Hz crossover, 24 dB/octave (since the amp is strictly for low-frequency reproduction, the crossover is always active) preamp outputs compression circuitry guards against overdriving speakers during loud musical passages at high sound-pressure levels EBC2 port for multi-amp external control of bass boost high preamp input capability (up to 8 volts) PWM MOSFET switching power supply gain control Thunder EQ bass boost (0-18 dB at 40 Hz) rubber Iso-Feet allow you to mount amplifier without the mounting screws contacting the amp's chassis speaker-level inputs with SmartEngage (turns on the amp when it detects signal from the receiver, eliminating the need for a turn-on lead) Pret: 800 Ron Negociabil Detalii la telefon: 0742115680 |
e cam mare pretul..mai scade tati..cine vrea statie asa mare isi poate lua SIERRA DUVAL VT8000 de 1150 W RMS la 850 lei nou nouta si pe deasupra mai e si Stabila la 1 OHM..parerea mea e ca mai mult de 500 lei nu iei pe ea..si stiu pe cineva care ar fi interesat sa o cumpere...lasa-mi un pm cu nr tau...
pai daca dai si tu un search pe google si cauti "SIERRA DUVAL VT8000" nu prea gasesti detalli, iar in schimb daca dai mtx audio zic ca gasesti foarte multe detalii. iar de pret .. am scris negociabil tinand cont ca statia este NOUA! 150 euro eu zic ca e un pret bun.
2. Daca e noua inseamna ca oferi factura cu garantie 3. Mtx e Mtx totusi .. |
Pai de cand ii legea asta ca daca e noua trebuie si garantie si factura ? esti persoana juridica ptr factura ?
@mikeyexc esti cam in urma cu schimbarile
Eu cumpar de cativa ani pe persoana fizica,,,, si cand a fost vorba de garantie si factura...nu m-a refuzat nimeni pe motivul de "nu sunteti persoana juridica" Cand cumperi un frigider? trebuie sa fii persoana juridica ca sa ai dreptul la garantie? |
pai vezi ca faci o greseala, una e factura si una e bon fiscal :)
oricum stai relax. nu are factura si nici garantie. esti multumit ? fi am zis la pers. juridica de factura, nici decum de garantie. dar na sunt unii carcatosi si n-au ce face :D |
parerea mea este ca daca o cumperi noua totdeauna vei primi un certificat de garantie..iar daca tu vinzi statia ai mult mai multe sanse sa te creada lumea ca e noua...si stai relax ca stiu diferenta dintre un mtx si un sierra duval vt8000...iar statia e foarte ok...am vb cu mai multi specialisti care se ocupa doar cu (decibeli) si e mult mai ok...asta in cazul in care vrei sa ai muzica de ce sa dau 150 euro pe o statie care nici macar nu e stabila la 1 ohm si are 800 w (parca asa scria) si sa nu imi iau una nou nouta cu inca 50 euro in plus si sa am si garantie si sunet mai mare...poti sa vezi in masina la mine cum suna daca ne-o intalni cumva...si poate ai sa iti faci si tu o parere despre SIERRA-u ala care "nu are prea multe detalii"...PAREREA MEA
@mickey uitate putin pe net si vezi un pic cand a fost fabricata....e totusi 2002...are 9 ani vechime..sa nu imi spui ca 9 ani de zile nu a fost montata niciodata...eu unu cel putin nu cred asa ceva...pentru ca cine isi ia un amplif il monteaza cu siguranta..
Iti atasez cand vrei factura+garantie pe persoana fizica de la un amplificator Sony luat din magazin ! Ma rog .. fiecare cere cat crede pe produs dar asta nu inseamna ca o sa-l si vanda ! p.s. Vand si eu amplificator Sony clasa D 2x300RMS NOU cu factura+garantie 1 an si 8 luni (l-am probat pe masina o singura data!) Pret catalog 1200 ron ! |
@tino
iati prietene statie nou, nu te obliga nimeni sa cumperi statia mea. iar despre SIERRA .. fiercare isi lauda marfa .. si interenetul spune treaba asta cat de laudat ii sau nu .. dar din pacate nu este! ii greu sa traiesti cu adevarul. fiecare vrea sa fie cum vrea el. nu-i problema, ma bucur ptr statia ta. si sa-mi arati si mie difuzorul ala care il ai tu pe un ohm. nu trebuie live arata-mi-l in poza :) sunt curios. si mai arat-mi unde ai vazut ca statia mea e facut acum 9 ani. si iti garantez ca nu a fost montata pe nici o masina si nicaieri, nu a fost folosita. @SynTheLaZ nu neaparat iei factura. le e lor mai usor cu factura prietene .. dute la real si cumpara un electronic/electrocasnic si vezi ca nu iti da factura, iti da un bon fiscal. fiecare cum vrea. dar am mai spus-o si o mai spun, nu aveti altceva de facut si criticati pe altii.:nospam: |
Prietene... stii ce te sfatuiesc eu?
Sa cauti mai bine in acest topic si ai sa vezi ca exista un topic dedicat vanzarilor pe zona sibiului... Si nu ne strica buna dispozitie.. Nu crezi ca are dif de 1 ohm Tino? Te inseli |
mucea, sfatuieste mai bine pe unu de varsta ta !
Te rog sa iti revizuiesti comportamentul ! Uiti ca ai venit in comunitatea noastra si trebuie sa respecti niste reguli ! Cu siguranta nu esti tu cel care a pus coada la pruna, cel care le stie pe toate ! Te rog sa asculti si sfatul altora iar daca nu esti in stare cauta-ti te rog alt loc unde sa iti etalezi cunostintele ! Cel mai mult conteaza sa iti respecti aproapele dar din pacate unii stim numai sa cerem si nu avem habar cum si cand trebuie sa oferim ! Iti multumim ! |
mouse ii zici lu fiuto mai laba.
si cu asta am pus punct in fata la toti labarii care se baga inseamna doar ca sa scrie si si ei pe forum doar sa se arate. ca daca nu se arata nu se simt ca traiesc. |
nu stiu la tine cat da :D in fine, nici eu nu am chef sa ma cert. dar ma dispera romanii astia care nu au altceva de facut si in loc sa se uite la ei sa fie mai bine ii judeca pe altii. |
Oare mai are rost sa spun ceva?
Ne-ai demonstrat tot ce stii si tot ce poti ! Quote:
Nici pe la scoala n-ai prea dat se pare ! |
daca dif. e 2x2ohm poti sa ii dai din amp. 1 ohm :D legarea in serie ... + la - , + la - ... si de la primul plus .. la ultimul minus cabluri pana in amp ! |
dar ei nu specifica ca e de un 1 ohm, doar ca e 2 x 2 ohm. am dreptate ? |
tocmai asta e ! diful este de 1 ohm ..
ai dat si tu repede o cautare pe google dar nu ti-a iesit ! (ai luat primul link de pe google care duce la ******* :))) Quote:
Fac pariu ca esti genul care s-a chinuit sa treaca clasa la mate/fizica ! |
mie producatorul nu imi zice treaba asta, nu mi-l certifica :D zice ca e 2 x 2 ohm :D nu ca e si daca il legi in paralel e de 1 ohm. ca il faci tu aia e altceva. dar aia nu iti zic treaba asta ca e de 1 ohm. zic altii dupa calculele lor. si cu asta daca vrei am putea sa incheiem subiectele si sa ne vedem fiecare de ale noastre. ok ? |
Am avut dreptate cand am scris ca ai dat repede google si copy/paste?
Am avut dreptate cand am scris ca habar nu ai de legile fizicii ? Nu te mananca nimeni daca recunosti .. iti promit ! Oricum .. eu am terminat, m-am lamurit cu cine stau de "povesti" ! Ma duc sa-mi trezesc cainele sa port cu el o discutie putin mai inteligenta decat cu tine ! Noapte buna ! |
oricum eu nu te-am chemat la povestit, te-ai bagat singur in seama fara sa te prezinti, iar cei 7 ani de acasa lasa de dorit :P sper sa nu iei maxim acuma. |
rog pe paul mig sa stearga toate commenturile facute pe ultimele doua pagini, nu de alta dar chiar mi-am pierdut 20 de minute din viata sa vad care din oameni e mai rotund, care stie mai bine fizica etc.
@Mickey: poti sa postezi pe bazar, si o sa gaseasca cine o sa fie interesat. @TNO: Nu fi rau, poate exista statii bune si care sa nu fie ca ale tale, sau , daca stai sa te gandesti, exista statii pentru gusturile fiecaruia. Mai e o chestie, eu sunt cel mai praf la fizica de aici, dar pentru asta exista google. Nu zic sa dai copy paste la primu` lucru pe care il gasesti, dar omul va scria exact de pe cutie... deci nu mai sariti pe el asa gramada, ca nu i frumos. @Mickey: ai putea incerca sa pastrezi discutia intr-o limita a decentei, nu sa folosesti argumente injurioase, tinand cont ca este un forum public dar care are totusi niste reguli, si ar fi pacat sa iti fi facut cont doar ca sa iei ban pe el. @Sinthelaz: In loc sa iei la misto, ai putea sa ajuti omu` sa se lamureasca, da i un link care sa il ajute si rezolvi mult mai repede problema. Nu are rost sa stati sa va luati in gura unu` cu celalalt, ca nu rezolvati nimic. In rest, spor la vanzare...stii cum e vorba: Nu e prost cine cere... |
Catδ intelepciune aici :shock:
Noroc ca e topic OFF Topic :lol: |
@Cristi...sa sti ca ai dreptate la faza cu cele 20 minute pierdute...si eu le-am pierdut.:lol:
Am sa intervin si eu la aceasta "cearta" si sa explic de la ce a inceputul totul sa inteleaga toata lumea si sa nu mai existe neintelegeri. 1. Acest user MickeyExc imi este prieten si m-a rugat sa-l ajut sa vanda aceasta statie si neavand cont pe 4tuning am postat eu in locul lui. 2. Vazand ca nu intervin la discutie a fost nevoit sa-si faca si el cont sa poata sa raspunda intrebariolor. Si bineinteles ca sunt ff multi aceea care intevin intr-o discutie doar asa sa se afle in treaba.....Nu vreau sa supar sau sa jignesc pe nimeni dar cateodata "unii" o fac intentionat sa se vada ce mari "macho" sunt si ce "cunoscatori" avem prntre noi dar, daca e sa pui pe vre-unul sa-ti faca sonorizarea la un CONCERT si aici ma refer la tot ce cuprinde acesta pun pariu ca habar nu au..dar sa lege un player in masina si sa comenteze de calitate si vechime a unui produs stiu.. Deci sper sa nu o luati in nume de rau, dar decat sa va apucati cu crititcile si cu informatiile luate aiurea mai bine ziceati : " bafta la vanzare" Drumuri bune si asfalt uscat la toata lumea!!! |
bunghi ai vazut vreodata apratura profesionala de concert care vine cu tirurile si dureaza 1 zi intreaga sa o instaleze 10 oameni ?
Despre ce vorbeam noi si ce spui tu ! Ti-o spun pe aia dreapta .. tovarasul tau vinde un amplificator si nu stie ce vinde defapt ! Lup cum sa-l ajut daca el stie tot? Nu-l vezi cat de rotund e? Nu vreau sa pierd timpul incercand sa invat pe cineva chestii elementare invatate in scoala pe se pare ca nu le prea stie dar totusi vrea sa ne impresioneze dand un copy/paste de pe un site :rolleyes2 Nu are rost sa discutam pe marginea acestui subiect pentru ca este fara scapare .... Numai bine cu vanzarea ! |
| All times are GMT +2. The time now is 23:20. |
