da da Sierra dar care :twisted: .da ne dam dar am spart iar radiatorul si momentan e iar in service pana saptamana viitoare :cry:
Re:
offffff
imi pare rau sa aud asta :cry: :cry: :cry: Quote:
stai linistit am mai schimbat unul intr-o ora in intersectia de la orhideea inainte de ultima cursa ,toate se repara saptamanaa viitoare o facem lata :lol:
Zmeilor ! :twisted:
bai maserati-ul asta e chiar tare ,ma rog nou era super, iata specificatiile de pe maserati.com :
Biturbo Year: 1981 Technical specifications Model Biturbo Production start 1981 Number Produced 9206 Ignition electronic Lubrication full-flow filter Transmission 5-speed ZF + reverse (3-speed automatic to order), rear wheel drive with Salisbury-type differential Gear ratios I=3,42 II=2,08 III=1,39 IV=1,00 V=0,87 R=3,66 (Automatico: I=3,42 II=2,08 III=1,39 R=2,09) Chassis monocoque steel construction Front suspension MacPherson struts, dual-rate telescopic dampers, coil springs, anti-roll bar Rear suspension semi-trailing rear arms mounted on a rear subframe, coil springs, dual-rate hydraulic telescopic dampers Brakes discs all round, dual circuit, servo-assisted, additional drums on rear wheels for handbrake Steering rack and pinion (power assistance to order) Cooling system water-cooled, centrifugal pump Length 163.50 in. (4,153 mm) Width 67.48 in. (1,714 mm) Height 51.38 in. (1,305 mm) Wheelbase 98.97 in. (2,514 mm) Front track 55.91 in (1420 mm) Rear track 56.34 in. (1431 mm) Dry weight 2,394 lbs (1,086 kg) Tyres fr/rear 195/60 HR 14, Pirelli P6 Wheels light alloy, 5\" 1/2 J x 14\" Top speed 133.5 mph (215 km/h) Bodywork three-box two-door coupé seating five Fuel tank 13.41 Imp. gal. (61 litres) 0-60 mph 0 to 100 km/h in 6.5 sec. Standing mile 0 to 1000m. in 29.0 sec. Years of activity 1981-1987 (Including 2nd series) Engine 90° V6 Bore and stroke 82x63 mm Total displacement 1,995 cc Compression ratio 7.8:1 Maximum power 180 bhp at 6000 rpm Maximum torque 25.8 kgm (187 lbs/ft) at 4,400 rpm Timing gear three valves per cylinder (two intake, one exhaust), twin overhead camshafts Fuel feed two IHI turbos, a single Weber 36 DCNVH 16/100 twin-choke carburettor, MABC (Maserati Automatic Boost Control) from June 1983 onwards Dar am inteles ca are alt motor de 225Cp pe injectie cred ca e de pe Maserati 222 ,oricum daca masina e in stare buna (ceea ce cred)nu sunt prea multi care sa-i tina piept, mai ales daca s-a umblat putin la motor. PS:Cum ar fi daca ar avea motorul de pe Ghibli de 306 Cp? |
Re:
Re:
Re:
opel calibra 2,0l 16 v turbo, destul de modificat, zic eu, cutie getrag 6 trepte etc ;) |
Re:
Masina lui Radu fuge foarte bine.Sunt convins ca nici biturbo nu e mai prejos.Totusi-parca ar merge berea tot pe Radu-prietenii stiu de ce...
Re:
m-am luat de cateva ori cu maserrati 2,0l biturbo, model mai vechi, la fel cu acesta, in craiova si i-am dat ffff rau |
Re:
Cred ca faci Biturbo cum e acesta dar chiar nu cred ca l-ai face daca ar avea 306 CP.
Bine nu stiu cat de modificat e masina ta...... |
Re:
Re:
multumesc, sper sa reusesc |
Re:
Re:
oricum, masna ta merge ff bine |
Re:
Am achizitionat ceva mai nou.Un Corrado 2.9VR6 225 cp.Ca sa fiu in rand cu poporul.Astept provocari :D |
L-ai luat pe ala care era al lui Alex?
TXA are motor de M5.
era vorba de TXA atunci cand inca avea 3.5! acum e clar ca nu se mai punea problema sa se dea cu txa cu noul motor!
Re:
Re:
cu prima ocazie ai o provocare de la mine ;) :twisted: :twisted: |
cum arata un corrado de 225cp?
in loc sa vedeti ca omul este sincer si declara caii de pe dyno, voi il luati la misto... nu era mai usor sa stea linistit si sa zica ca are 178 sau cati are unul stock ?? Ar fi tare ca de acum la legale sa vina fiecare cu fisa de la dyno... total imposibil, dar cinstit :wink:
Re:
Re:
Imi pare rau ca nu ne-am dat cand avea vechiul motor.Ba a fost el plecat nush unde ba am avut eu motorul varza. Dar dak da Dumnezeu poate pun si eu un turbo pe actuala masina.....bine nu ca ash ajunge cu turbo la caii unui M5 dar...se simte. |
Re:
Si nu am nevoie de sfaturi,aprecieri sau deprecieri de la nimeni. Intreaba pe cei care au fost la Craiova la ultimele liniutze cum alearga masina. Acum ce sa fac...m-am dat si io mare cu 225cp. P.S. E un simplu forum pana la urma nush de ce *** esti ironic. |
Dupa 13 pagini pe care le-am citit m-am hotarat sa ma bag si eu in seama... din pacate pe la pagina 11 mi s-a cam taiat elanul cand am aflat ca ai vandut masina, dar nu-i nimic :wink:
Ca sa incep cu inceputul, felicitari pt noua achizitie :) Citisem undeva pe la inceput ca nu iti schimbasei jantele fiindca nu se potriveau cu nici unele de la alte marci!? eu stiu sigur ca se potrivesc cu cele de pe Alfa Romeo in 4 prezoane... acum nu stiu daca tu aveai 4 sau 5 prezoane :roll: In continuare, as lansa o provocare, atat pt actualul tau Corrado, cat si pentru \"fosta\" ta :lol: |
si eu vreau sa imi testez roshcata cu un corrado d 225 cp :P
asteptam prima ocazie :) |
Re:
Cu fosta nu mai depinde de mine.Cu Corrado accept.Ce motor ai?cp? etc... |
Re:
Re:
La cat de rosu si lung era Assteapta ala al tau trebuia sa stau vreun an dupa o provocare.Uite ca n-am stat. :evil: |
Re:
Re: Maserati Biturbo 2000cc(VL-42-PAC) vs. TXA
Am vandut-o si pe asta.(Corrado)E in bucuresti masina.....la cineva care sa ocupa de ea.Sper ca pana in toamna sa-mi iau alta....caut acte momentan pt recarosare...cele care sunt de vanzare in RO sunt rupte-n doua majoritatea.
Re:
La cat de rosu si lung era Assteapta ala al tau trebuia sa stau vreun an dupa o provocare.Uite ca n-am stat. :evil:[/QUOTE] Vroiam sa spun sa astepti pentru mine sa scot Peugeotul. |
FT TARE FAZA .... DIN CAT AM CITIT IO SI AM CITIT CAM TOT.....CAND VINE VORBA SA TE DAI ....TU ITI VINZI MASINA :))))))))))))))))))) BAAAHHH NU ESTI LA PINKS ;)))) :d ORICUM DACA D LA 185 PARCA TI AI LUAT 225 ...ACU POATE GASESTI CEVA P LA 280 300 SI .....T PROVOC SI IO DA ......MAI BINE NU K MA AGIT AIUREA ...SI U.......O VINZI :d |
pana la urma s-a facut cursa cu txa ca m-am plictisit citind si am sarit la ultima pagina...?
Cred ca nu si topicul poate fi inchis, nici una din masini nu mai este ceea ce a fost cand a fost deschis topicul, din cate stiu TXA a schimbat motorul de atunci pana acuma, iar Maseratiul a fost vandut
| All times are GMT +2. The time now is 23:24. |
