re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
Up....
Up....
Up....
Up....
Up....
Up....
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Mandrina 20/B22-fixare pe con morse----------------------40ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------430ron Dulap metalic tip fiset---------------------------------------200ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 |
Up....
Compresorul il mai ai?
Aveti PM dle.B-69-TAU
Vand: Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Mandrina 20/B22-fixare pe con morse----------------------40ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------430ron Dulap metalic tip fiset---------------------------------------200ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 |
Up....
Clichetul este sigilat ?
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Mandrina 20/B22-fixare pe con morse----------------------40ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------430ron Dulap metalic tip fiset---------------------------------------200ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron |
Up....
Up....
Buna seara,
Ma intereseaza cutitele strung, toate pe care le aveti. In functie de ce anume imi oferiti, voi decide exact ce anume ma intereseaza. In special cutite pentru interior la 90Grade. |
Vand:
Up....
Up....
Up....
Up....
Up....
Up....
Vand:
Up....
Up....
Up....
Up....
VAND MOTOR BENZINA,MOTOR ELECTRIC,POLIZOR DUBLU,MASINA GAURIT CU COLOANA,DIVERSE.
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------50ron Mandrina rapida precisa 0-10mm(pe filet)-------------------40ron Mandrina 20/B22-fixare pe con morse----------------------50ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----200ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------200ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1300ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------10ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron |
Up....
Up....
Vand:
Up....
scuze de deranj, mai ai cumva, din greseala, o fotografie buna, in care sa se vada diagrama de avansuri de la strung?!
Strungul nu mai este de actualitate.
Vand:
Up....
Up....
Up....
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Alternator Tractor U 650(12V;Cod 1134;36A)(NOU)------------300ron Semicuzineti Palier+Biela R1 pentru Tractor U 650--------------140ron Element filtru ulei avion(inoxidabil)---------------------------50ron Mandrina rapida precisa 0-10mm(pe filet)-------------------40ron Mandrina 20/B22-fixare pe con morse----------------------50ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----200ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------200ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1300ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------10ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron |
| All times are GMT +2. The time now is 07:02. |
