Re: Vand/cumpar: aerografe,compresoare,vopsele...etc.
Mai face careva compresoare cu motor de frigider?
Marfa noua, 5 bari, 7,5 litri butelia, supapa siguranta, reductor presiune, nivel zgomot comparabil cu cel de la calculator............550 RON.
Pentru orice informatii contactati-ma: Tel: 0765252492 E-mail: [email protected] |
Buna ziua.
Eu ma ocup cu realizarea de sabloane alfabetice folosite cu precadere in inscriptionarea de stalpi si alte chesti de cei ce opereaza in sistemul energetic, cu o vasta experienta in realizarea de sabloane. Am facut pe plan local si ceva stancil-uri pentru cei pasionati de airbrush. Avem o masinarie CNC, deci putem realiza la standarde inalte si calitate a materialului exceptionala ( PE - rezistente la aproape orice solvent, mai putin la nitrodiluant) ORICE MODEL - ORICE MARIME modelul clientului 0747.277296 - [email protected] va asteptam |
Salut,
Vand compresor pentru aerograf: Second-hand...stare impecabila.Pret 450 RON Specificatii: Mini Air Compressor,Airbrush Compressor Airbrush Compressor is use for Auto/Motor cycle Graphics, Fingernails, Cake/Food Decorating, Hobbies & Crafts, Tattoos/Body Art, Tanning, Instrations/Fine Art, T-shirt/Texiles, Abrasive, Taxidering/Lures, Murals/Sign Painting, Ceramics and so on. Features: Portable & lightweight Low noise Thermally protected. Over pressure protected. Auto stop Pressure-adjustable. Constant pressure and Zero pulsation. Specifications: Type: Single Cylinder Piston Compressor With Air Tank Power: 1/5 HP Voltage: 220-240V / 50HZ 110-120V, 220V / 60HZ Air output per min./liters: 23L-25L/min Auto stop, start at 30 psi, stop at 58 psi (special pressure available) Safety valve: release the air pressure automaticly when the pressure over 6 bar in the air tank. Air tank: 3.5L Fitting: manometer; pressure regulator; air filter; Connections: with connection 1/8"BSP (1/4"BSP to choose) Weight: 5.2KG Dimension: 310 X 130 X 310mm Electric Cable: 1.8m. Carton Dimensions:65 x 33.5 x 37cm/4pcs N.W./G.W.:22kg/24kg Certificate: CE |
Am vopsele, compresoare si pistoale aerograf pentru vanzare. www.airart.ro
10 Attachment(s)
Vβnd 4 buc aerografe 2x0,25 1x0,2mm si 1x0,5mm
la pachet se mai adauga furtune, cuple mecanice, filtre, cheite, perii pt curatare cat si un set de flacoane cu vopseluri pt airbrush... Pretul pe pachet 400 lei 0767108516 YMS: gstemate |
Vandut compresorul alb de mai sus....Dl. Radu sa-l folositi cu placere.Multumesc 4Tuning. Cat de curand poze cu un nou proiect. Pentru orice informatii contactatati-ma: Tel: 0765252492 E-mail: [email protected] |
Salut,
Poze compresor nou. Execut la comanda compresoare aerografie. Tel: 0765252492 E-mail: [email protected] |
Vandut,
Cat de repede fotografii proiect nou. Pentru orice informatii contactati-ma. Cu Stima, Mihai Tel: 0765252492 E-mail: [email protected] |
Buna seara,
Fotografii proiect nou, maine pleaca la Iasi :D Anunt valabil. Cu Stima, Tel: 0765252492 E-mail: [email protected] |
Cumpar mini compresor sau compresor pentru aerograf.Vreau sa fie ceva mic si ieftin...Doresc sa vopsesc suprafate mici maxim 35 cm patrati...Poate fi Home Made si sa fie cel mai zgomotos,ma intereseaza doar sa mearga.astept oferte pe pm.
Salut, vreau sa ma apuc de niste proiecte mai mici ca hobby in airbrush, si ma gandeam poate sunt anumite pers care mai au timp liber si dornici sa ma poata sfatui, ce vopsele sa folosesc, care e ordinea de aplicare a straturilor etc.
Cine doreste sa-mi dea add pe mess si vb... id YM: CS_L89 Respect! |
Cumpar aerograf 1.8-3 max sau diuza+ac 0,2 iwata, perii, vopsele aerografie+textile.
Detalii pe PM. |
Caut sa cumpar un aerograf cu gravity feed (cupa deasupra), dubla sau simpla actiune si cu duza intre 0.2 - 0.35.
Multe din anunturile de mai sus in pacate nu mai sunt de actualitate asa ca astept un pm daca are cineva ceva :D Seara buna |
Vand aerograf Infinity 2 in 1 folosit dar in stare impecabila.Sau schimb dar numai cu triplex 2.Pret 500 Ron negociabil
vand aerograf bd 128 si un bd 208 200 lei bucata
0765577601 sau id florynez |
Vand instalatie cromat marca Spectra Chrome + instalatie deionizat apa. Pret 6000 euro.
Mai multe detalii la: 0723 557736 0741 066982 sau email : [email protected] |
Vand Aerografe :
- Aerograf AZTEK NOU(poza 1) 250 RON :http://www.testors.com/product/13711...n_Airbrush_Set *se poate folosi atat single action cat si double action - Aerograf double action VALEX NOU(italia) 200 RON : http://www.valex.it/webvalex/prodott...I%20PNEUMATICI *are doua borcane +cupa laterala - Aerograf rusesc anul 1980 si ceva... editie speciala 20 de ani de la revolutia din rusia (single action 3 duze, 3 ace) 150 RON |
cumpar minicompresor aerograf ofer maxim 350ron sau cumpar kit aerograf (folosit) ofer maxim 500ron.
astept oferte. cu stima |
Vand Kit Complet Aerografie
-Aerograf Iwata Eclipse HP BCS - Aerograf cu alimentare prin aspiratie cu o duza de 0.5 mm
Iwata Evoluion sunt aerografe cu dubla actiune si alimentare prin aspiratie. Aceste aerografe sunt recomandate pentru pictura pe textile, picturi murale sau auto. Datorita duzei cu diametru mare si a constructiei speciale, aceste aerografe sunt indicate pentru culorile mai vascoase. -Compresor aerograf Eurotec 16A Harder & Steenbeck Capacitate: 16 L/min.. Presiune: 4 Bar ,Nivel de zgomot: 53 Db. ,Greutate: 8,5 Kg, Capacitate rezervor: 2,5 L.,Intrerupator on/off automat,Regulator de presiune cu filtru de umiditate. Accesorii si consumabile: Distribuitor pt. 3 Aerografe 2 x Furtun Panzat BD 24 1xPlastic Primer 1L Lac Pe Baza De Apa Solutie de Curatare a Aerografului Iwata 400ml Culori Aerograf ComArt - Toate culorile Opac Transparent(@25 buc) Multe alte accesorii: Pensule, Cutite sablonare, Stencilsuri format A3/A4 Format electronic(AI, PS, ETC) Astept oferte! 0764.936.031 (Bucuresti) |
mai vinde cineva aerografe cu tot ce trebuie?
De vanzare Vopsea cameleon, perlata, flip-flop, etk etk
Contact p.m. sau 0730 345 375 |
Vand aerograf hansa set 681+compresor+set culori. Aerograful: Hansa Hobby Line 681 Airbrush set cu conexiune prin aspirare, cupa de 5 ml, adaptor si doua recipiente goale de 30 ml, duza de 0. 3 mm cu sistem duza tip clichet.
Compresorul: Eficienta: 10L/ min Performanta: 70 Watt Conexiune electrica: 230V/ 50HZ Presiune: 2, 9 Bar Vand acest set pt ca nu il folosesc. . doar l- am probat o singura data. este ca si nou.Contactatima la nr de tel:0747500211 |
Ovidiu il vinzi cu tot cu compresor ? Adica la pachet ma refer , in montez si pot face aerografe cu el ? Daca da , ce pret !
10 Attachment(s)
Vand pistol de vopsit, HVLP, il am de 8 ani, functioneaza perfect, nu mai vopsesc de aceea se vinde la kit cu cale, cheie, bolturi noi rezerva pt el, sita, perie, etc...
pretul per kit este 200 Ron, are si filtru de apa/ulei cat si regulator de presiune cu ceas pt LP. Diuza de 1,4mm pachetul complet ce include si pistol de antifon/insonoriznt 0767108516 yahoo messenger: gstemate |
s-a vβndut pistolul de vopsit, va rog nu mai sunati. multumesc 4 tuning pt. gazduire
magazin vopsea auto mixata din stand
vopsea auto gama Du Pont ,accesorii vopsitorie magazin de prezentare si desfacere Bucuresti Str. Valea Oltului nr 131-137 sector 6,puncte de reper blocuri ANL si Mega Image contact: E:mail : [email protected] Tel: 0722.853.342 0764.810.776 |
PISTOL GTIPro VOPSEA 1.3 -2000RON/BUC
PISTOL GTIPro LAC 1.3 -2000RON/BUC PISTOL PRIMER FLG 1.4 -1250RON/BUC PISTOL SLG 600 -640RON/BUC PISTOL DE ANTIFONAT F6 -120RON/BUC MASINA DE SPALAT PISTOALE QRTT DRESTER -5500RON STUTZ FLEXIBIL DeVilbiss 120RON/BUC FILTRU REGULATOR PRESIUNE DUBLU -1900RON/BUC FILTRU REGULATOR PRESIUNE SIMPLU -1150RON/BUC MANOMETRU PRESIUNE DeVilbiss 300RON/BUC MINISUFLATORI AER -300RON/BUC FURTUN AER PENTRU VOPSITORIE Ό - 30RON/METRU FURTUN AER PENTRU VOPSITORIE 5/16 -26RON/METRU FURTUN AER PENTRU VOPSITORIE 5/16 I/D H-7501 -35RON/METRU FILTRU AER HAF -63RON/BUC RACORD CONECTARE CU FILET INTERN LA DOUA CAPETE 5RON/BUC STUTZ RACORD Ό -5RON/BUC STUTZ RACORD RAPID Ό - 5RON/BUC SURUB REGLARE FLG -65RON/BUC CUI PENTRU DIUZA FLG 2.0 -68RON/BUC SET FLUTURE AC&DUZA GTI 1.3 -855RON/BUC SET FLUTURE AC&DUZA GTI 1.4 -855RON/BUC SET DE REPARAT PISTOL KK4585 -480RON/BUC SET PERII DE CURATAT PISTOALE 70RON/BUC DIUZA 1.4 OM -160RON/BUC DIUZA FLG 1.8 +CUI -230RON DIUZA FLG 2.0+CUI -230RON SET REPARATII GTI PRO LAC 1.2 -790RON/BUC SET REPARATII GTI PRO LAC 1.3 -790RON/BUC SET REPARATII GTI PRO VOPSEA 1.3- 790RON/BUC SET INLOCUIRE VALVA AER -550RON/BUC SET FILTRE CANA PISTOL SITE -135RON/5BUC-SET CANA PISTOL DE VOPSIT 290RON/BUC 0722.853.342 DANIEL *PRETURILE CONTIN TVA |
Vand aerograf Paasche VL1007, cu toate accesoriile incluse, cu tot cu Compresor, un set de 10 culori si o sticla de Curatator 500ml. NOI, NEFOLOSITE NICIODATA, doar depozitate pentru un timp. Toate incluse in pretul de 700 lei. Negociez pretul. Bucuresti
0748968398 |
Vand doi litri de lac Spies Hecker Permafast 8007 si un litru de intaritor 3008. Pentru cunoscatori. Pret 200 lei FIX
Attachment 3039304 |
6 Attachment(s)
Vand aerografele din poze + un air eraser(pistol sablare fina)
Vin exact cum le vedeti in poze(sigilate) Aerografele vin cu -3 duze/ace 02,03 si 05 -furtun -cheita Pret:250lei bucata Pentru mai multe bucati se poate negocia Contact:0724885194 |
Salutare
Vand aerograf Iwata HP-BCS diam 0.5mm set complet ( record de prindere, bidonas vopsea si perii de curatat) Vand pistol vopsit baby series Iwata LPH50 Gravite diam 1.0 set complet ( record prindere , bidonas vopsea si perii de curatat ) Produsele sunt noi ! Astept oferte ! |
Aerografe Iwata High Performance Plus HP BP și Iwata Neo HP CN.
Compresor Air Com. Aparatele sunt folosite puțin și funcționează fără probleme. Prețul afișat este pentru cele două aerografe, compresorul este Bonus :). Tot bonus este și un alt model de aerograf (BD 130), care nu apare ξn fotografii. Și acesta este funcțional. Fotografiile sunt recente și bineξnțeles reale. https://olx.ro/oferta/aerografe-iwata-bonus-ID66E3y.html |
Salut !
Vopsea Createx fluo are cineva de vβnzare ? Mulțumesc ! |
| All times are GMT +2. The time now is 06:56. |
