Re: Cele mai tari masini vazute in Tg-Jiu
ii sustin afirmatia :P
6,1 litri Hemi 420 CP si 570 Nm 0 la 100 km/h in 4,4 secunde Greutate – 2.163 kg ;) nu stiu de unde a scos puterea aproape dubla :)) |
Puterea ca puterea, da zgomotul e infernal:twisted:
asa e, te scoala din mormant
din cate am auzit, paul asa zice, ca ar avea 750,dar sincer nu stiu cat o fii de adevarat |
de unde 750??? cred ca si-ar dori .........:workout:
nu stiu ce a zis Florin dar eu o sa fiu 100% sigur ca are, sa zicem in jur de 750 hp cand o sa il bage pe dynotest.
si atunci o sa vedem dar o sa il intreb si pe Florin sa vad ce zice, pentru orice eventualitate |
este bi-urbo ? Greu mie sa cred ca are 750 cp .
masina e stock, doar finala facuta sa urle.
Merci 8) . Ma distrau copii care visau aici :no: . Scuze de off.
Salut, m-am documentat Jeep-ul lui Paul are 550 cp.
Aaa apropo am mai vazut un q7 ABT alb , este de la noi din targu jiu sau esre doar in trecere? |
Jeep Grand Cherokee SRT8(2005-2009) Wheelbase 2781 mm 109.5 in Track front 1608 mm 63.3 in rear 1577 mm 62.1 in Length 4956 mm 195.1 in Width 1862 mm 73.3 in Height 1694 mm 66.7 in Length:wheelbase ratio 1.78 Ground clearance 178 mm 7 in Kerb weight 2172 kg 4788 lb Weight distribution (Front) 55.00 % Fuel capacity 77.7 litres 17.1 UK Gal Drag coefficient 0.390 Frontal area 2.82 m2 Cx 1.10 Bore × stroke 103.00 mm × 90.90 mm 4.06 in × 3.58 in Cylinders V-8 in 90.0° vee Displacement 6.1 litre 6059 cc (369.743 cu in) Type OHV 2 valves per cylinder 16 valves in total Sump Wet sumped Compression ratio 10.30:1 Fuel system SMPFi Maximum power (SAE net) 425.8 PS (420.0 bhp) (313.2 kW) @ 6200 rpm Specific output 69.3 bhp/litre 1.14 bhp/cu in Maximum torque (SAE net) 569.0 Nm (420 ft·lb) (58 kgm) @ 4800 rpm bmep 1180.1 kPa (171.2 psi) Specific torque 93.91 Nm/litre Maximum rpm 6400 rpm Manufacturer Chrysler Code Main bearings Coolant Water Bore/stroke ratio 1.13 Unitary capacity 757.38 cc/cylinder Aspiration Normal Compressor type N/A Intercooler None Catalytic converter Y Engine location Front Engine alignment Longitudinal Drive 4WD Wheels front 9 x 20 rear 10 x 20 Tyres front Goodyear Eagle RSA 225/45 W 20 rear Goodyear Eagle RSA 285/40 W 20 Brakes F/R VeDi/Di-S-ABS Brake ∅ front 360 mm rear 350 mm Braked area Transmission 5A Top gear ratio 0.83 Final drive ratio 3.73 Sursa carfolio.com |
DOUBLE OWNED :lol:
Salut o sa mai apara in scurt timp 2 masini de lux pe la noi prin oras: un Merc S 600 si un Maybach.
Proprietaru o sa il aflati la timpu potrivit. |
| All times are GMT +2. The time now is 21:15. |
