-   -   Sport-Sedanuri de lux :2006 BMW 330i vs 2006 Lexus IS 350 vs 2006 Mercedes C350 Sport (https://forum.4tuning.ro/55-versus-auto/19377-sport-sedanuri-lux-2006-bmw-330i-vs-2006-lexus-is-350-vs-2006-mercedes-c350-sport.html)
Nautilus 30-09-06 00:48
Re: Sport-Sedanuri de lux :2006 BMW 330i vs 2006 Lexus IS 350 vs 2006 Mercedes C350 Sport
Rectific: BMW 330i E90 foloseste motorul N52 B30, echipat cu Valvetronic (sistem care variaza deschiderea supapelor - "valve lift") si cu dublu-VANOS (sistem care variaza momentul deschiderii supapelor - "valve timing"), ce actioneaza continuu (nu in "trepte" ca la VTEC).
Unul din motivele adoptarii sistemului Valvetronic este necesitatea eliminarii clapetei de acceleratie, care creaza o restrictie destul de pagubitoare pe traseul de admisie. De 100 de ani s-a incercat si la carburatie si la injectie inlocuirea ei cu ceva mai bun
However, as you can see in the picture as well, at light throttle (when the car is running leisurely, down hill or at light load) the throttle butterfly partially or even nearly closes. Simultaneously, the pistons are still running, sucking air from the partially closed intake manifold. Needless to explain, the intake manifold between throttle and combustion chamber will become partial vacuum, resisting the sucking / pumping action of pistons. This waste energy. Engineers called this energy loss as "Pumping Loss". The slower the engine runs, the more the throttle butterfly closes, thus the more energy loss.
Without throttle butterfly, how does it control the amount of air entering cylinders ? by controlling the lift of valve.
http://www.bmwworld.com/pics/engine/vt_works.jpg
Motivul pentru care pe motoarele de foarte mare turatie nu se foloseste Valvetronic: ar necesita arcuri de supapa mult mai solide, iar costul fabricarii lor (si al celorlalte componente mecanice ale distributiei) din aliaje exotice ar duce pretul unui M3 la o cifra astronomica
~Nautilus
Race 30-09-06 13:19
Copiii de 10 ani au obiceiul de a studia date tehnice in Auto Catalog sau carfolio.com si sa converseze in stilul "X are 350 CP si Y are 400 CP, Y trebuie sa fuga mult mai bine".
Exact ! Si sunt intr-o majoritate covarsitoare fani BMW sau Honda,care nu realizeaza ca puterea MAXIMA nu e totul.Pe langa ei mai sunt si cativa care nu stiu ce spun/vor si se contazic singuri,si care lauda motoarele turate dar cumpara supra-alimentate :D
Nici nu e nevoie de Valvetronic pe M-uri, o data fiindca au deja sistemul de distributie variabila VANOS
Asa e,de ce sa variezi doi parametri cand poti varia doar unul :rolleyes2
Pur si simplu ati luat-o la goana din discutia de baza a acestui topic. mare pacat, devenea interesanta.
:lol:
Da,foarte interesanta.Numai "am vazut teste","mie imi place BMW","Mercedes e Mercedes","Lexus e mai rar in Romania" etc. Intr-adevar,numai posturi pline de substanta si informatii relevante...
Bai Race, ai o problema si vad ca tie greu sa treci peste ea, in visele tale C350 cica e mai bun, mai frumos i mai despept ca un 330i, din nefericire esti contrazis clar de muuulta lume care a testat si a catalogat ambele masini
Nu am facut absolut nici o referire la design.O masina nu poate fi desteapta,e doar o gramada de metal,plastic si cauciuc.Faptul ca tu o privesti ca pe o fiinta umana (cum reiese din descrierea ta) e destul de grav.
Nu am zis ca e mai bun C350.Discutia a pornit de la afirmatia ta ca MOTORUL de BMW e mai bun decat cel de Mercedes pentru ca are 3 litri nu 3,5.De atunci pana acum discutia a fost DOAR despre cele doua motoare,nu despre masini in ansamblu.
Daca nu citesti posturile celorlalti abtine-te la a posta.
159 da de banuit, nu e chiar asa proasta cum zici tu nici pe departe, problema ta e ca ai niste complexe care te apasa
Nu,e cel mai bun sedan sport facut vreodata ! Pierde orice comparatie ce-i drept,si in toate testele concluzia finala e "daca n-ar arata asa n-ar cumpara-o nimeni,e atat de jalnica"...dar ce conteaza asta !? Stie sandumrs ca "da de banuit",deci clar e o masina buna ! :lol: (asta e valabil si pentru Brera si Spider)
Care ar fi complexele alea maestre psiholog ? Nu cred ca a nu-ti place o masina lenta,proasta si scumpa constituie un complex.Sau poate te refereai la BMW ? Intr-adevar,ce fel de om nu e fan BMW ? :rolleyes2 Multi oameni simt nevoia sa se incadreze intr-un stereotip stupid,dar tu exagerezi rau cu asta.Si ce-i mai grav,spre deosebire de altii exagerezi fara nici un fel de argumente,cat de puerile ar fi ele.Iti sugerez sa te lasi de citit AMS,nimic bun nu poate iesi din asta.Desi acum cred ca e prea tarziu :sad:
Inainte sa ne lasam toti in genunchi si sa facem matanii minunatei firme BMW,ar trebui sa stii ce face i-VTEC.Si anume exact acelasi lucru ca VANOS (adica variaza continuu momentul deschiderii in functie de sarcina si turatie),in plus avand doua profile (un prag) pentru deschidere si timpul de deschidere.Ca un sumar,Honda nu are variatie continua a deshiderii,ci doar doua trepte,iar BMW nu variaza deloc timpul de deschidere,care intamplator e cel mai important dintre cei 3 parametri.Sistemul Honda e mult mai bun.
Parca tu ziceai acum ceva timp de strategii de marketing...exact asta e si aici.Atata timp cat nu accelerezi pana la 250 km/h,ridici de tot de pe acceleratie pana ajunge masina la 50 km/h,repeti,o masina functioneaza EXTREM de putin la sarcini partiale aproape nule.Eliminarea clapetei de acceleratie e pur si simplu un moft.
Sigur ! La 50.000 EURO pentru un M3 sau 80.000 pentru M5,cateva zeci de arcuri mai tari ar creste pretul semnificativ :D
Motivul pentru care nu e Valvetronic pe M-uri e ca au introdus prea multe componete in miscare,care au masa si deci inertie mare la viteze mari.E un exemplu clar pentru ce fac multe firme:tehnologie noua care NU functioneaza !
sandumrs 02-10-06 00:24
Inutil sa discutam bai Race, tu esti stupit si rau de tot, tu nu vi cu nici un argument, efectiv e o provocare pentru tine sa fi Gica contra, sunt sigur de un lucru, esti Roman, te pricepi la toate si la fotbal si la F1 si la masini. Problema ta pe acest topic e BMW si ale sale motoare muuult premiate si de asemenea Honda si ale sale motoare la fel de premiate.
In final nu e foarte important pentru noi ca utilizatori cum si de ce sunt aceste motoare asa de performante ci rezultatul final "performanta".
Nu mai atotstiutorule, cauta si vezi, nu am zis ca 159 e cea mai buna, am zis ca e o masina de care trebuie sa tinem seama in clasa ei, o confunzi greu de tot cu Alfele din trecut si ai un complex fata de ALfa, incearca sa treci peste acest complex ca vremurile se schimba si nu ne mai invata tu pe noi ca nu ai nici un argument, nimic din ce ai scris tu nu e argumentat, fabulatie la greu si insitenta.
Si nu ma lua tu pe mine peste picior ca n-are rost, sau poate oi fi vreun pilot de curse???
sandumrs 02-10-06 01:58
https://www.youtube.com/watch?v=dgTsO...elated&search=
Un mic argument stimabile Race. Zimi e trucat? Oare Alfa mergea cu 20km/h mai incet ca celelalte? Ma indoiesc. Sunt si alte argumente in caz de nevoie.
300zxtt 03-10-06 11:23
sunt in total de acord cu cele spuse de race
apropos sandumrs,daca cineva nu-ti impartaseste opinia sau nu are aceleasi preferinte e stupid?am inteles ca in munich sa construit o biserica si in altar e stema alb-albastra.ce-ar fi sa te duci sa faci pe acolo niste plecaciuni ca poate poate iti mai vine mintea la loc,ca in viziunea ta bmw-ul a ajuns la rangul de zeu
sandumrs 05-10-06 23:41
Stai tu linistit, nu incerc sa fac pe nimeni sa creada ceva, doar sutin cu tarie ca BMW 330i e o masina de top si ca Alfa 159 e o masian reusita. Punct.
Race 08-10-06 16:15
Asa e :sad:
Ar trebui sa ma las de postat date si chestii tehnice,si sa incep si eu cu "BMW e BMW" :rolleyes2
Acum ca tot mi-ai dat ideea,o sa ma interesez si despre fotbal :lol:
Parca stabilisem ca in linie dreapta 330i e cea mai lenta masina din aceste versus.Presimt ca tu ai totusi alta idee despre "rezultatul final performanta" unui motor...
Daca as confunda-o cu Alfele din trecut as zice ca e o masina extraordinara.Tocmai asta e problema,Alfa in momentul de fata traieste din reputatie,imagine si design.
Vezi care e problema cu cliseele ? Nu se potrivesc tot timpul cu realitatea cand nu stii mai nimic despre respectiva realitate...
Te-am mai intrebat maestre psiholog,ce e ala complex fata de o firma care produce masini ?!
Acum ca mi-ai spus tu,imi dau seama ca nu stiu nimic despre domeniul auto :???: Poate ma apuc sa citesc Auto Motor si Sport,mai invat si eu cate ceva :D Nu de alta,dar stau destul de prost la capitolele snobism auto si admiratie suprema si nejustificata fata de firmele germane...
sandumrs 08-10-06 22:48
Bai asta nu ma face tu snob ca n-ai nici in clin nici in maneca cu acest domeniu, esti nul. Tot ce ai scris e demagogie ieftina, nimic concret sau despre masini umplii pagini cu mari porcarii si esti gica contra pe unde apuci, esti singurul care nu a spus nimic la subiect.
Si ai stabilit tu ca 330i e cea mai lenta pe linie dreapta la fel cum ai stabilit tu ca Alfa 159 e o masina proasta, cauta atent, o sa vezi ca te inseli. Bai ce destept esti tu, impresionant aproape.
Zimi un singur motiv pentru care Alfa 159 e o masian porasta.
300zxtt 08-10-06 23:44
personal nu va cunosc pe nici unul dintre voi(sandumrs si race),dar am tot respectul pt cunostintele in materie de masini pe care le detine race dar vad ca amandoi aveti cunostinte teoretice si nu practice.va bazati teoriile pe teste si comentariile ce reies din publicatiile ce apar in reviste sau internet.
eu vb din ce stiu ca se intampla prin servis sau din masinile ce le-am avut.
pot spune despre alfa ca este o masina super frumoasa si doar atat.sunt mai multe criterii ce trebuiesc luate in vedere atunci cand alegi o masina sa o cumperi si nu rezultatele unor teste.ele sunt facute cu masini noi dar oare masina aceia se va comporta identic si dupa N kilometri?sau va trebui sa treaca de sute de ori prin servisul reprezentantei si dupa ce ai facut imprumuturi enorme pe la diferite banci ca sa achiti contravaloarea reparatiilor?
am fost fan bmw.am iubit culorile alb-albastru de pe stema.dar atunci cand esti tot timpul cu mana pe telefon sa faci rezervare la bavaria si-ti petreci timpul pe la servis sa vezi daca e gata masina nu mai ai aceasi sentimente fata de acea marca.
am inceput sa vad latura practica a unei anumite masini.ultimul bmw seria 3 care pot spune ca e bmw a fost modelul pisicuta.restul sunt niste bucati de metal ce-ti toaca banii pe piese sau reparatii.tot timpul trebuie sa-ti apara ceva.cand spui ca in sfarsit ai masina pusa la punct trebuie sa apara un zgomot sau un bec aprins in bord.
stiu ca o sa-mi sara multi pe cap dar acum vorbesc din propie experienta si nu din ce zic unii sau altii
sandumrs 09-10-06 22:24
Da ma e clar clar BMW nu e numarul unu la fiabilitate, asta e mai mult decat evident, dar sa ne gandim si la targetul clientilor de BMW, bineinteles nu ei sunt de vina ca se strica, dar......................... si aici e un mare dar mai trebuie sa stii si cum sa te comporti cu masina( ma refer la a avea grija de ea).
Tin sa te contrazic un pic, sunt foarte importante testele comparative, e foarte greu sa vorbesti despre masini daca nu trec prin mana unor oameni care se ocupa cu asta, asta le e painea. Clar as vrea sa am si eu ocazia sa lucrez la vreo astfel de revista. Este de asemenea clar ca sunt foarte importante si experientele personale care la ai cu masina dar asta e un fapt puternic subiectiv.
Inca ceva, nu va cumparati niciodata BMW-uri la mana a doua, asta e o parere pur personala pe care o sustin cu tarie.
Si inca ceva nu va cumparati BMW daca nu aveti sange alb albastru. Si aici nu e vorba de un cult cum zicea Race, e doar o pasiune pentru o marca, in cazul meu nu e vorba de o exacerbare asa cum am fost acuzat.
Ca fan BMW sunt constient ca s-ar putea sa dai o forja la un 330i nou si in 10 min sa se aprinda o groaza de martori luminosi in bord, dar ce sa-i faci pasiunea. Plus ca asta nu e o regula.
Oare in 5 ani cum o sa reziste combinatia de doua motoare electrice plus unu pe benzina de la Lexus, am un zambet puternic pe fata, va fi tragic. Glumesc, nu se strica niciodata.
Degeaba ma acuzati voi ca sunt ignorant fata de masinile japoneze concurente cu Seria 3, chiar nu-i adevarat, numai ca BMW le bate cam pe toate.
300zxtt 12-10-06 19:55
[QUOTE=sandumrs;580880]Da ma e clar clar BMW nu e numarul unu la fiabilitate, asta e mai mult decat evident, dar sa ne gandim si la targetul clientilor de BMW, bineinteles nu ei sunt de vina ca se strica, dar......................... si aici e un mare dar mai trebuie sa stii si cum sa te comporti cu masina( ma refer la a avea grija de ea).
atunci hai sa ne cumparam bmw si sa-l punem intr-o vitrina si sa-l admiram.cum sa te comporti altfel decat sa-i faci reviizile la timp si din cand in cand sa-i mai dai in goana?
eu am stat multi ani in Arabia Saudita si acolo poti spune intradevar cat de reusita e o masina.sunt conditii climaterice ce distrug rapid orice masina(temperatiri ce depasesc lejer 50C,si cel mai dureros adversar al unui motor ,nisipul) si in afara de japoneze nu prea gasesti.daca vrei un bmw ieftin il poti cumpara de prin saudia sau dubai.are cea mai mare devalorizare pt ca numeni nu il cumpara. e unanim cunoscut pe acolo fiabilitatea bavarezelor.mercedesul in schimb e mult mai bine cotat din cauza putinelor defectiuni ce le afiseaza.si nu poti spune ca acei arabi stau prost la capitolul finante....
si cea mai bine cotata masina ramane Lexus,ce are cea mai mare pondere la preferatele arabilor
infiniti si acura nu a prins vreun loc printre preferintele lor
sandumrs 12-10-06 23:32
Nu e de pus in virtina man, numai ca un foarte mare procent din posesorii de BMW-uri le confunda cu Ferrari sau Porsche.
Cat despre Arabia, posibil sa ai dreptate, nu le place la nisip.
Si calar Lexus e senzatie, nu se strica niciodata, titanium made.
300zxtt 13-10-06 12:05
nu spun ca nu se strica niciodata ,doar spun ca sta mult mai putin prin servis si e peste bmw la capitolul fiabilitate
The_Mask 13-10-06 21:44
Am urmarit acest topic de la inceput, si m-am abtinut de la comendari pentru ca nu sunt in masura sa ma pronunt din moment ce n-am condus aceste masini, insa observ ipocrizia unora care nu pot recunoaste ca masina X este sub Y(n-am dat nume ca sa nu-mi sara "direct" in cap") Tot ceea ce sustine Sandumrs este lipsit de argumente, pentru el Bmw Rullzzzz exact ce spune si un pustin de 14 ani pe care`l intrebi ce masina isi doreste...Nu inteleg de ce nu recunoasteti ca s-a terminat cu suprematia Mercedes/Bmw in segmentul acesta!
sandumrs 14-10-06 15:15
Eu sunt lipsit de argumente??!!
De ce crezi asta bro???!!! Ma indoiesc ca ai urmarit cu atentie ce s-a intamplat pe aici.
http://www.caranddriver.com/shortroa...35i-sedan.html
http://blogs.edmunds.com/roadtests/c...at.2006BMW330i
http://www.caranddriver.com/comparis...-s60r-awd.html
Cam cele mai bune argumente, de pe o piata unde masina e neutra, la fel ca si cele supuse la test.
Nu cred ca trebuie sa ascult la argumentele voastre ca nu ati reusit sa spuneti nimic.
Cautati cu atentie, poate gasiti macar un test comparativ in care 330i sa iasa sifonat. O sa fie o lunga cautare.
riptor 14-10-06 15:37
lexus pt ca e mai deosebit si nici la calitate nu sta rau deloc
AdriANNO 16-10-06 16:15
Originally Posted by ZoliaT (Post 458167)
Sport-Sedanuri de lux :2006 BMW 330i vs. 2006 Lexus IS 350 vs. 2006 Mercedes-Benz C350 Sport
Aleg 330'u!;)
B.v.L 18-10-06 03:03
hai ca aleg si eu 330i avand tractiune spate se descurca bine in drift :P
pimp_lex 18-10-06 16:45
LOL, pai toate au tractiune spate
B.v.L 18-10-06 17:16
scuza`ti am aflat ulterior si eu :) imi cer scuze public :D
br01tim 19-10-06 20:31
eu merg pe Lexus!are un design mai special si nici la imagine de marca si puterea motorului nu sta rau.
weedboy 20-10-06 02:37
8) bmw pana la moarte8) ....bmw masina mea de suflet
m_power87 23-10-06 02:18
prefer 3-iarul, e cel mai frumos, asta e parerea mea
Nautilus 28-10-06 14:10
Re:
Daca ai fi citit topicul incepand de la prima pagina ai fi vazut ca nu e vorba de modelul E46 ci de E90, care numai frumos nu e :p
~Nautilus
puma rider 10-11-06 15:11
Eu as baga si un saab 9-3 aero acest versus, chiar daca nu e asa po****ra precum celelalte marci, masina e dotata cu un motor v6 turbo de 250 cp, ce le face fata, iar puntea spate, denumita ReAxs, are un anumit grad de virare pasiva(asa scrie in pliant), pentru a mai anula din dezavantajele tractiunii pe puntea fata
sandumrs 11-11-06 10:58
Aero... va avea in scurt timp 280Cp iar motorul trage senzational, insa este doar o Vectra de lux, mai are mult pana departe. parerea mea.
puma rider 12-11-06 16:29
Diferentele dintre saab 9-3 si vectra sunt destul de mari...intradevar la concurenta interiorul arata ceva mai bine, dar masina cred ca face fata cu brio in clasa premium...intamplator chiar am in familie un 9-3 aero modelul 2004 cu doar 210 cai, ce a facut intre timp aproape 90 000 de km, si masina ne-a oferit numai satisfactii, pretul, la momentul la care a fost cumparata masina fiind cu vreo 6000 mai mic fata de un bmw 330 cu echipare asemanatoare...eu sunt convins ca bmw este o masina ceva mai performanta...dar preturile sunt nejustificate pentru ce primesti in schimb, mai ales la ultima generatie
sori 12-11-06 16:52
lexus , te lasa fara cuvinte;)
SEBASTIAN 12-11-06 22:36
bmw sta in fata.
The_Mask 13-11-06 08:04
Originally Posted by SEBASTIAN (Post 620199)
bmw sta in fata.
Da la pret sta in fata, trebuia sa specifici...;)
SEBASTIAN 13-11-06 08:18
e chiar efectiv mai ieftin sio mai bun 29000 costa bmw
pimp_lex 15-11-06 01:31
Lexus sta CLAR in fata
B.z.K. 15-11-06 19:03
Kiar daca apreciez perfomanta BMW de data asta merg pe design asa ca aleg lexus.oricum pana la urma e doar o kestiune de gusturi si simpatii(eventual obsesii)pt anumite marci.cand voi fi pus in "neplecuta" situatie de a alege intre cele 3 poate voi gandi altfel...pana atunci....fiecare alege 60% cu inima si 40% cu capul ca doar de asta suntem oameni si avem simpatii.Niciunul nu va alege o masina doar dupa datele din diverse teste.Parerea mea.
SEBASTIAN 15-11-06 22:34
Eu am multe obsesii.
DAEWOO CIELO, DACIA, OPEL, RENAULT, PEUGEOT, BMW, SUBARU...
Din pacate pentru ca-mi plac asa de mult masinile nu am o marca preferata.
Fiecare la locul la clasa si pentru ce e ea facuta.
B 68 VLD 16-11-06 17:44
Astazi a fost pentru prima oara cand m-am suit intr-un Lexus IS 250 varianta de echipare sport (modelul actual evident) si nu pot spune decat ca am ramas placut impresionant ceea ce de Bmw nu pot spune. Bmw-ul este dragut, Lexus-usul este impresionant, cel putin pt mine.Chiar daca Lexus-ul dinamic vorbind ar fi mai slab si eu consider ca diferentele nu au cum sa fie mari (ma refer si la timpul pe circuit nu numai 402m) eu consider ca este net superior Bmw-ului.
Duruselu 20-11-06 14:31
Am ales bmw... desii nu sunt un fan inrait al marci... ci doar ca imi place designu .... dupa bmw.. e mercedes ..:D
:peace:
Eagleee 08-01-07 11:30
Deci...masinile asta nu sunt lux!!!de loc de fel, is din clasa medie cu motoare mai sportive si considerabil mai mari.
Clasamentul vine asa:
-BMW-ul e ceea mai buna la motor, cutie, suspensie, deci pe pista va fi ceea mai bune+lot of fun.
-Mertanul este categoric ceea mai "luxoasa", ceeam mai de calitate in privinta de habitaclu. Pe pista...merge.
-Lexus-ul este mai putitan, mai simpa la interior, spacific Japonez, Dar daca ne uitam la intragime...poate Lexusul e castigator, sti cate un pic din ambele europene...
Dar eu asi merge pe martan :D are un stil aparte, are prezenta, sugereaza ca esti cineva, ceeaca la BMW este ca esti mare sportiv si bolnav la cap, Lexusul nu zice nimic pentru multi, nu e asa cunoscut...
PiStI 08-01-07 11:51
acuma depinde cine esti si ce doresti
masinile de categoria aceasta sunt stereotipizate:
BMW-"cava fotbalist"
Mercanu'-"cava manelar"
Lexus-..........pauza, foarte putina lume stie ceva destre aceasta marca, doar cei interesati.
Acum depinde unde vrei sa fii bagat, iar daca nu conteaza cum te vede lumea atunci alegi dupa gust, unde nu no comment.
personal as merge pe c350, pt ca masina e proiectata sa mergi repede pana la firma sau la intalnirea de afaciri, nu sa mergi seara la agatzat.
merc. for ever, chiar daca Lexus e mai bun pt. ca a fost proiectat sa bata europenele chiar la ele acasa dar...........
Bemelo 08-01-07 14:49
Sport-sedanuri de lux nu inseamna S classe , A8 etc..... daca asta aveai impresia . Reprezinta masinile din clasa medie premium cu accente sportive. Nu stiu de ce te-ai apucat tu, marele cunoscator , sa critici titlul thread-ului. Nu stiu de ce li se dau voie analfabetilor sa posteze pe forum. :(
Bemelo 08-01-07 14:59
Imi cer scuze pt dublu post , nu am mai putut edita. On topic : Masinile sunt foarte apropiate ,totul tine de gusturi. Am stat in dreapta intr-un Mercedes C350 si am ramas placut impresionat deci chiar daca voi fi subiectiv aleg Mercedes :D..
