-   Scule-Echipamente Service (https://forum.4tuning.ro/528-scule-echipamente-service.html)
-   -   Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc (https://forum.4tuning.ro/528-scule-echipamente-service/119818-vand-polizor-dublu-masina-gaurit-coloana-electromotor-u650-alternator-u650-etc.html)
ellaghe72 20-10-10 09:22
re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
Up....
ellaghe72 22-10-10 15:28
-Polizor trifazic(380V) dublu PD 500-----430ron
-Dulap metalic tip fiset-----------------230ron
-Dulap metalic 2 usi--------------------350ron
-Masina gaurit cu coloana(380V)-------1400ron
-Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron
-Element filtru ulei avion(inoxidabil)---------------------------40ron
-Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron
-Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron
-Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22)
-Placute Widia--------------------------------------------------5ron/buc
-Reductor presiune oxigen---------------------------------------100ron
-Trusa pentru sudura oxiacetilenica------------------------------350ron
-Pompa picior(1cilindru)------------------------------------------12ron
-Pompa picior(2cilindrii)-------------------------------------------22ron
-Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------100ron
-Manometru presiune0-250atm.--------------------------------------10ron
-Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc
-Cutite strung widia10x10----------------------------------------5ron/buc
-Stativ magnetic ceas comparator--------------------------------120ron
SCULE PROFESIONALE DRAPER-ANGLIA
-Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur
Legenda:
Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009
-Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron.
-Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron.
Telef.0722.121.520
roby200687 24-10-10 10:05
Buna. M-ar interesa cat ar costa un set de prese de arc (2 prese), si un suport hidraulic de cutie de viteza.
ellaghe72 24-10-10 14:32
Presa arcuri nu mai este de actualitate si suport hidraulic de cutie de viteza,nu am.
roby200687 24-10-10 15:13
poti sa aduci?
ellaghe72 24-10-10 19:07
Nu....
ellaghe72 30-10-10 09:51
Legenda:
Telef.0722.121.520
ellaghe72 04-11-10 18:45
Legenda:
Telef.0722.121.520
ellaghe72 10-11-10 19:36
Up....
ellaghe72 22-11-10 00:55
-Trusa pentru sudura oxiacetilenica------------------------------320ron
Legenda:
Telef.0722.121.520
ellaghe72 28-11-10 17:36
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron
Alternator Volkswagen Jetta-S.H.-----------------------------90ron
Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron
Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron
Placute Widia------------------------------------------------5ron/buc
Reductor presiune oxigen------------------------------------100ron
Trusa pentru sudura oxiacetilenica--------------------------350ron
Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron
Polizor trifazic(380V) dublu PD 500------------------------450ron
Dulap metalic tip fiset---------------------------------------250ron
Dulap metalic 2 usi------------------------------------------400ron
Masina gaurit cu coloana(380V)---------------------------1300ron
Cutite strung vidia--------------------------------------------------5ron/buc.
Set placute vidia(10buc/blister)(12x12)---------------------------150ron
Semeringuri FARTEC-----110x130x13--------------10ron
------80x100x13----------------------------------------8ron
------50x70x10------------------------------------------7ron
-------35x50x8--------------------------------------------5ron
--------26x42x10------------------------------------------4ron
Manometru presiune0-250atm.-------------------------------------10ron
Manometru presiune 0-60atm---------------------------------------8ron
Cutite strung 10x10--------------------------------------------------5ron/buc
Stativ magnetic ceas comparator---------------------------------100ron
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron
Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron
Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur
Legenda:
Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009
Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron
Telef.0722.121.520
ellaghe72 04-12-10 20:12
Up....
ellaghe72 09-12-10 21:29
Up....
ellaghe72 13-12-10 17:53
Vand:
Mandrina 20/B22-fixare pe con morse-----40ron
Legenda:
Telef.0722.121.520
ellaghe72 22-12-10 10:08
Up....
sharky-vw 25-12-10 15:45
pune o poza cu Biax MPPI-46
ellaghe72 03-01-11 14:43
Vand:
Mandrina 20/B22-fixare pe con morse----------------------40ron
Trusa pentru sudura oxiacetilenica--------------------------320ron
Polizor trifazic(380V) dublu PD 500------------------------430ron
Dulap metalic tip fiset---------------------------------------200ron
Masina gaurit cu coloana(380V)---------------------------1200ron
Legenda:
Telef.0722.121.520
sharky-vw 03-01-11 22:12
sunt interesat..as dori cate o poza cu fiecare...
ellaghe72 07-01-11 16:43
7 Attachment(s)
Avet foto dle.sharky-vw
ellaghe72 12-01-11 20:39
Vand:
Legenda:
Telef.0722.121.520
BeWaRe 16-01-11 18:14
Salut nu te supara a-si fi interesat de biax .Nu vreau pietre la el sau alte accesori . il lasi la 1 mil? Astept un raspuns Salve
ellaghe72 16-01-11 18:34
Aveti PM dle.BeWaRe
ellaghe72 24-01-11 21:54
Vand:
Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron
Legenda:
Telef.0722.121.520
ellaghe72 29-01-11 12:00
Up....
salfkm 30-01-11 11:06
Poti pune te rog niste poze cu urmatoarele produse,scuze daca au mai fost postate pozele dar nu am urmarit topicul de la inceput
ellaghe72 30-01-11 13:38
10 Attachment(s)
Aveti foto dle.salfkm
ellaghe72 03-02-11 11:34
Vand:
Legenda:
Telef.0722.121.520
ellaghe72 11-02-11 20:20
Up....
ellaghe72 17-02-11 18:58
Up....
ellaghe72 28-02-11 13:41
Up....
ellaghe72 06-03-11 10:53
Nu mai sunt de actualitate:
ellaghe72 12-03-11 15:44
Vand:
Legenda:
mihai1 13-03-11 15:53
M aintereseaza motor electric.
Deci cat are ca vad cate doua valori la orice .wataj, turatie, tensiune.
Am inteles ca ee la 220 volti.
ellaghe72 17-03-11 10:39
Vand:
Legenda:
ellaghe72 26-03-11 23:24
Up....
crine 28-03-11 23:48
Poze cu masina de gaurit cu coloana si cea de banc daca le mai aveti, si mandrine, se poate? Multumesc.
ellaghe72 29-03-11 09:19
Masina de gaurit de banc nu mai este de actualitate.In schimb aveti un link,unde regasiti foto masina gaurit cu coloana:https://forum.4tuning.ro/528-scule-ec...ml#post3365260
ellaghe72 03-04-11 00:33
Vand:
Legenda:
ellaghe72 19-04-11 21:25
Vand:
Polizor trifazic(380V) dublu PD 300------------------------430ron
Legenda:
ellaghe72 26-04-11 22:46
Up....
