Re: Clio RS vs Corsa opc
...diferenta dintre cei 197 de cp ai lui clio si cei 189 ai opc-ului este de 11 cp???????...inseamna ca prea ami stiu mate...LA MINE REZULTA DOAR 8CP DIFERENTA.lucru insimnificabil tinand cont de diferenta de cuplu de 15 nm in favoare opc-ului...
Ps. sti ce inseamna DTM? Deutsche Tourenwagen Masters (German Touring Car Masters) |
...decat sa faci pe smecherul ,mai bine taceai...STIU FOARTE BINE CE AM VRUT SA ZIC,DACA NU AI INTELES STAI JOS...si nu ti face probleme ca stiu ce inseamna dtm...
renault clio rs 2.0 I
Engine Inline-4, dohc, 4v/cyl, VVT.( NU E TURBO) Capacity 1998 cc Front wheel drive Power 197 hp / 7250 rpm Torque 159 nm / 5550 rpm top speed: 220 km/h 0-100 km/h: 6.9 s Weight 1240 kg PRICE € 23000 Opel Corsa D opc 1.6 T Type of engine In-line Cylinders 4 Valvetrain Dual Over-Head Cam (DOHC) Engine installation Front mounted engine, transversee capacity 1598 cm³ Max. power output 141 kW 189 hp @ 5850 rpm Valves per cylinder 4 Fuel injection Multipoint injection Charger Turbocharger Max. Torque 230 Nm @ 1980 rpm Drivetrain serial Front wheel drive Manual gearbox 6 Performance 0 to 100 km/h 7.2 sec. Top speed 225 km/h weight 1203 kg Consumption Annual Average 7.9 l/100 km PRICE € 22,560 ...cu tot respectul bambake(eu vad 197cp)...daca are 200cp cineva a gresit pe aici... |
Inovatiile din F1 abia se vad la Ferrari-urile de strada,e de-a dreptul hilar sa crezi ca un hatch mic de familie are vreo treaba cu tehnologia F1.Desi Clio RS merge bine pe circuit,pe strada ma indoiesc ca se va putea tine vreodata de Corsa pe un drum virajat.Pentru condusul de zi cu zi,un aspirat turat de putere mica e cel mai prost lucru posibil.
Baietii de la Evo zic asa (test pe drum nu pe circuit): "Henry in the Mini leads, followed by Hayman in the Cupra, me in the VXR and Roger in the Clio. Straight by straight, the Clio is falling away from the pack. It makes up a little ground under braking and through the bends, but the general trend is backwards. The plain and bitter truth is, it can’t keep up. And for the car that’s the protector of the Clio Trophy’s awesome reputation, that’s about as bad as it gets." Ca sa nu mai vorbim ca viteza maxima de 215 km/h e jenanta pentru o astfel de masina. Quote:
Vrei sa zici ca ceea ce este facut la departamentul F1 nu are de a face cu masina de strada? Sti cat de complex e internele ului motor, aerodinamica acestuia, sa faci o suspensie reltiv buna e usor, dar sa faci un motor bun...trebue sa fi mare expert, si aici nu bani conteaza ci design-ul. Eu vad multe motoare iesite din poarta de fabrica cu multe greseli de design sau prelucrare, asta nu e o problema ca oricum nu vrei sa folosesti la maxim respectivul motor, dar totusi sunt acolo. Cateva din asta se poate modifica, restul numai daca schimbi rau refaci piesa respectiva. Credema ca modelele sportive, mai ales cele limitate trec prin mana celor mai buni oameni la firma respectiva, fie specialisti de F1, DTM, rally sau de orice. Despre chestia ca un aspirat nu e bun in oras...sau un aspirat turat ca asta este greu de condus...eu am condus TypeR in oras si un SR la fel, mi sa parut perfect, pana la 4-5000 merge ca un aspirat obisnuit de capacitate mica (deci este relaxant) dar peste 5000 devin furie, merg ca nebunul pana la limitator. Pana acuma nu am mers cu o masina mai usoar de condus decat TypeR-ul, poti sa ii faci orice vrei, poti umbla in a 5-a la 50 si tot trage, sau in a 2-a la ~100...nu te omoara, nu face miscari la care nu ai fi preparat...daca un si avea alte preferinte...cine stie... |
Discutia a degenerat enorm de la compararea a doua masini la ce fac marcile in f1. Daca vorbim de lag la turbo de ce nu vorbim si de lagul enorm pe care il are un aspirat pana ajunge la cuplu. Poate e mai buna clio daca te duci pe A2 si ii dai blana dar condusul nu e doar sa mergi pe autobanda sau liniute de 400m. Daca doriti puteti sa scrieti pe forum turbo vs aspirat vs compresor si fiecare cu parerile lui.
Iar datele de pe opel.ro si renault.ro arata ca opc are 192cp si rs 200cp deci diferenta de 8 cai. Nu mai cautati voi pe site-ri unde e trecut corsa cu cel mai putin si clio cu cel mai mult pt ca daca o luam invers diferenta intre 192 si 197 cat e trecut la clio cel mai putin e doar de 5 cai. Cat despre cat rezista motorul , un turbo intradevar are presiune mai mare dar si turatia excesiva tinde sa omoare un motor. Depinde de stilul fiecaruia de condus.Daca mergi doar blana cel mai probabil va ceda turbina pe corsa inainte sa se strice clio ... Avand in vedere cat de incet se merge de exemplu prin bucuresti sau orice alt oras in perioade de trafic corsa sigur consuma mai putin si pentru asta a fost gandita , iar senzatiile numai cand e nevoie. Pe cand clio a fost gandita doar ca o masina pe care o scoti cand te duci la curse. Fiecare constructor a avut ce segment de piata sa atace , bineinteles ca si renault putea sa faca un motor mai mic turbo lafel cum si opel putea sa puna un motor mai mare aspirat cum era corsa gsi de 1.8 inainte. |
Cat despre LAG (ce numai la masinile turbo exista...) la cosra este, la clio nu!!! Este o alta chestie ca la motoare turbo simti cand intra in actiune turboul prin marirea drastica a cumplului, ceea ce nu este prezent la un aspirat, unde cuplul este linear. Dar de asta este cutia de viteza, cand ai nevoe de putere retrogredezi 2-3 viteze si dai balan...numai idiotii nu merg sportiv din cuplu...sau baeti cu motorina... Care cat rezista...un turbo merge la o temperatura mai mare din constructie, dar la fel de mare e problema cu turatii mari...deci e greu care este mai bun. Cat despre care e mai bun in oras, net superior aspiratul, mult mai prietenos din cauza cum descarca puterea, cum este curba de cuplu, la turatii mici. sub 2000-2500 are mai multa decat motorul turboul, la pornire e mai buna din cauza celor 400ccm, in tatolitate e mai ecfilibrat fundamental un motor aspirat fie de renault, honda, toyota, vw sau orice. Sa nu intelegeti ca sunt impotriva motoarelor turbo, chear acuma incepem un proiect la un Civic 1.4-1.6 turbo, asteptam la peste 200cai, si "numai" pentru drag, style low cost. |
si acum un link pentru toata lumea: clio 197 (nu r27 f1 sau clio CUP) versus corsa opc, de la 5th gear https://youtube.com/watch?v=GjL_AyuhJnc&feature=related |
[QUOTE=Hexer;1274960]Cat despre LAG (ce numai la masinile turbo exista...) la cosra este, la clio nu!!! Este o alta chestie ca la motoare turbo simti cand intra in actiune turboul prin marirea drastica a cumplului, ceea ce nu este prezent la un aspirat, unde cuplul este linear. Dar de asta este cutia de viteza, cand ai nevoe de putere retrogredezi 2-3 viteze si dai balan...numai idiotii nu merg sportiv din cuplu...sau baeti cu motorina...
QUOTE] lag-ul este foarte mic...f mic...! DECI: per total pret/calitate/consum... corsa castiga! consum mai mic in oras, iar cand vrei senzatii tari...intra turbo + un look de "fotomodeala" ;) ! |
@riptor...poti sa pui 100 de videouri, 10.000 de experiente si explicatii pana ce nu are clioul pe fata sigla de vreun contructor german idiotii considera de a fi cacat...
@bambake: nu se poate compara 2 masini in calitate (despre care habar n-ai) sau consum la un sportiv. Se poate compara strict performanta, eventual technologie ce se afla sub capota, ca asta e obiectiv, cum se arata sau ce te simti este subiectiv, deci NU se poate compara asta. Cat despre Clio Cup, mi se pare ca erau masini "Jean Ragnotti", acuma sunt cateva de vanzare cu cutii de schimb fara ambreaj si LSD, rollcage, si tot ce trebue pentru circuit, relativ ieftine, la 12000E. Parerea mea ca aceste Clio-uri sunt aproape de nivelul TypeR (cel anterior, nu actualul). |
2 e mai rapid ca corsa cu 1.2 sec la un circuit de 5 km(ceea ce nu e asa mult pt ca rs-ul este mai puternic) SI NU ISI MERITA BANII, INTRETINEREA JENANT DE SCUMPA... iar restul concluziilor tale sa ti le bagi in fundulet, ca ne pisam pe ele si pe tine ! |
De ce...cine esti tu?
Deci pana la urma ca performanta e mai buna si dupa parerea ta RS-ul, dar nu asi cumpara din cazul intretinerii...ok, e o opinie...eu respect asta... Apropo de fundul meu...al meu e numai iesire(sens unic)...nu stiu tu la ce mai flolosesti pe al tau... |
stai pe la periferie undeva...? educatia ta e de o tara bananiera? ps: pe un drum mai virajat corsa castiga detasat !!!!! |
| All times are GMT +2. The time now is 02:08. |
