Re: [VAND] Electronice si aparate AUDIO
9 Attachment(s)
Receiver YAMAHA R700
Stare tehnica foarte buna, optic impecabil, carcasa din lemn, made in JAPAN. Se vinde cu manualul printat original. Pret 185euro. Dimenisuni: 480mm (w) x 122mm (h) x 337mm (d) Notes: HIFI Receiver, 2x62W an 8 Ohm nach DIN, 2x80W an 4 Ohm. Synthesizer-Abstimmung mit Station Lock, je 5 Stationstasten für UKW und MW, digitale Frequenzanzeige. |
6 Attachment(s)
Tuner NORDMENDE TU 1340
Stare tehnica si optica foarte buna, made in GERMANY. Pret: 170lei Date tehnice: * Principle: Super-Heterodyne (Super in general); IF-Freq 460/10700 kHz * Wave bands: Broadcast, Long Wave and FM * Power type and voltage: Alternating Current supply (AC) / 110; 220 Volt * Metalic case * Dimensions: 440mm (w) x 145mm (h) x 320mm (d) Aus der "Philharmonic-HiFi-System" Serie. Gerät war auch in SCHWARZ erhältlich |
6 Attachment(s)
Tuner SANSUI TU-X701
Tuner AM/FM stereo, stare tehnica si optica excelenta, model foarte rar, display orange LED, made in JAPAN. Pret: 330dolari. It has selectable IF bandwidths with a decent front end that uses an RF attenuator. The IF strip uses 10.7 MHz transformers to tune GDT ceramic filters for optimum distortion performance. Sansui claims that the TU-X701's "SLDD" (Super Linear Digital Decoder) eliminates spurious frequencies. |
Tuner SANSUI T-510
Tuner vintage AM/FM stereo, in stare tehnica si optica foarte buna, made in JAPAN. Pret: 130lei |
12 Attachment(s)
Linie audio completa MARANTZ formata din CD-player model CD-45, amplificator model PM-253 si tuner model ST-253.
Stare foarte buna de functionare. Toate componentele made in JAPAN! Pret 145euro. |
Tuner Marantz ST 400
Model deosebit in stil vintage, in stare foarte buna tehnica si optica. Made in JAPAN. Pret 465lei. Features : • Dual tuning displays • Gyro touch tuning knob • High quality FM audio output when used with a good aerial Specifications : - 1979 - 1981 vintage - Dual displays : analogue tuning dial and digital frequency display - Servo lock fine tuning FM Stage [87.5 - 108 MHz]: - Sensitivity : DIN mono [S/N 26 dB 75 ohms]: 0.9µV DIN stereo [S/N 46 dB 75 ohms]: 23µV - IHF mono: 10.3/1.8 dBf/µV Sensitivity of alternate channels N/W: 65dB - Image frequency rejection : 57dB - Interference rejection : 98dB AM rejection: 55dB - Signal to noise ratio DIN : Unweighted: Mono: 65dB Stereo: 65dB Weighted: Mono: 70dB Stereo: 65dB - Pilot frequency rejection 19 kHz: 65dB Carrier frequency rejection [38 kHz]: 68dB - Total harmonic distortion : Mono (N/W): 0.1% Stereo (N/W): 0.2% - Frequency response : 30 Hz to 15 kHz +0dB / -1dB - Stereo separation : 45dB Balance: 0.2dB MW Stage [525 - 1605 kHz]: does not work - Sensitivity [S/N 26 dB 30% mod. 1 MHz]: 25µV Selectivity 1 MHz ± 9 kHz: 46dB - Image rejection at 1 MHz : 45dB Interm. frequency rejection at 1 MHz: 45dB - Signal to noise ratio at 1 MHz : 55dB Total harmonic distortion at 1 MHz: 0.5% - PLL loop FM multiplex demodulator, 3 gang FM, 2 gang AM - Five point signal strength needle meter - Gyro touch tuning control - smooth action with good grip - Dimensions [W x H x D] : 416 x 146 x 243mm - Weight : 6kg !! |
6 Attachment(s)
Tuner JVC T-X200L
In stare buna de functionare, made in JAPAN. Date tehnice:
8 Attachment(s)
Tuner MARANTZ ST 300
Model deosebit in stil vintage, stare foarte buna tehnica si optica. Pret 380lei. Detalii tehnice: DIN mono (S/N 26 dB 75 ohms): 0.9µV DIN stereo (S/N 46 dB 75 ohms): 24µV IHF mono: 10.3/1.8 dBf/µV Sensitivity of alternate channels N/W: 65dB Image frequency rejection: 55dB Intermed. frequency rejection: 88dB Interference rejection: 98dB AM rejection: 53dB Signal/noise ratio DIN: Unweighted: Mono: 65dB Stereo: 63dB Weighted: Mono: 69dB Stereo: 63dB Pilot frequency rejection 19 kHz: 60dB Carrier frequency rejection 38 kHz: 65dB Total harmonic distortion: Mono (N/W): 0.15% Stereo (N/ W): 0.3% Frequency response (30 Hz – 15 kHz): +0/-1dB Stereo separation: 43dB Balance: 0.2dB MW Stage (525 - 1605 kHz): Sensitivity (S/N 26 dB 30% mod. 1 MHz): 25µV Selectivity 1 MHz ± 9 kHz: 46dB Image rejection at 1 MHz: 45dB Interm. frequency rejection at 1 MHz: 45dB Signal/noise ratio at 1 MHz: 55dB Total harmonic distortion at 1 MHz: 0.5% LW Stage (150 - 350 kHz): Sensitivity (S/N 26 dB 30% mod. 250 kHz): 200µV Selectivity at 250 kHz ± 9 kHz: 24dB Image rejection at 250 kHz: 36dB Interm. frequency rejection at 250 kHz: 43dB Signal/noise ratio at 250 kHz: 48dB Total harmonic distortion at 250 kHz: 0.5% With: 416mm Height: 146mm Depth: 243mm Net weight: 4.5kg |
Ok, dupa atatea luni se impune o recapitulare a situatiei cu aparatele care intre timp S-AU VANDUT:
Asadar, nu mai sunt disponibile urmatoarele: - AKAI GX-75 MKII - RANK ARENA R-930 - ONKYO T-4650 - TECHNICS ST-8080 - KENWOOD KR-V87R - TECHNICS SA-R230 - MARANTZ SD-40 - AKAI GX-67 - TECHNICS ST-G70 - PIONEER TX-410L - PIONEER CT-737 - PIONEER SX-F21 + Rack - YAMAHA R700 Restul celorlalte aparate sunt in continuare disponibile la vanzare. |
Intre timp s-au modificat preturile catorva aparate, iar unele din ele s-au vandut,
asadar incercam o recapitulare a celor care raman in continuare la vanzare: Receiver + deck AIWA AF 3060 = 380 lei Receiver RANK ARENA R-930 = 270 lei Receiver TECHNICS SA-200 = 350 lei Receiver SUPERSCOPE R-1270 by MARANTZ = 270 lei Receiver digital SONY STR-D265 = 380 lei Receiver JVC RS-11 = 320 lei Receiver PHILIPS 22AH777 = 185 lei Receiver PHILIPS 22RH 734 = 55 euro Receiver BANG & OLUFSEN Beomaster 3000-2 = 250 euro Receiver BASF 8425 = 270 lei Receiver SANYO DCX 6000K = 85 euro Deck ONKYO TA-2570 = 240 lei Deck ONKYO TA-2500 = 260 lei Deck DENON DRW-850 = 250 lei Deck SANSUI D-590R = 270 lei Deck PIONEER CT-939 = 135 euro Tuner TECHNICS ST-7300K = 190 lei Tuner GRUNDIG T-1000 = 170 lei Tuner JVC T-X200L = 160 lei Tuner PIONEER F-447 = 160 lei Tuner NORDMENDE TU 1340 = 170 lei Tuner DUAL CT-1140 = 125 lei Tuner SANSUI T-510 = 130 lei Tuner ONKYO T-9060 = 125 euro Tuner ONKYO T-9990 = 300 euro Tuner KENWOOD KT-1100 D = 220 euro Tuner YAMAHA T-85 = 150 euro Tuner SANSUI TU-717 = 235 euro Tuner SANSUI TU-X701 = 330 dolari Tuner MARANTZ ST 300 = 380 lei Tuner MARANTZ ST 400 = 465 lei Tuner GRUNDIG T-9000 FineArts = 220 euro Amplificator SONY TA-313 = 115 euro Amplificator AKAI AM 2200 = 200 lei Linie audio (amplificator+tuner) MARANTZ PM-253 + ST-253 = 100 euro Preturile sunt usor negociabil. Trimit oriunde in tara cu posta romana/atlassib si plata ramburs. Mai multe detalii si poze reale ale aparatelor gasiti in cadrul acestui topic. |
Intre timp s-au mai vandut cateva aparate,
asadar incercam o recapitulare a celor care raman in continuare la vanzare: Receiver + deck AIWA AF 3060 = 380 lei Receiver RANK ARENA R-930 = 270 lei Receiver TECHNICS SA-200 = 350 lei Receiver SUPERSCOPE R-1270 by MARANTZ = 270 lei Receiver digital SONY STR-D265 = 380 lei Receiver JVC RS-11 = 320 lei Receiver PHILIPS 22AH777 = 185 lei Receiver PHILIPS 22RH 734 = 55 euro Receiver BANG & OLUFSEN Beomaster 3000-2 = 250 euro Receiver BASF 8425 = 270 lei Receiver SANYO DCX 6000K = 85 euro Deck ONKYO TA-2500 = 260 lei Deck DENON DRW-850 = 250 lei Deck SANSUI D-590R = 270 lei Deck PIONEER CT-939 = 135 euro Tuner TECHNICS ST-7300K = 190 lei Tuner GRUNDIG T-1000 = 170 lei Tuner JVC T-X200L = 160 lei Tuner PIONEER F-447 = 160 lei Tuner NORDMENDE TU 1340 = 170 lei Tuner DUAL CT-1140 = 125 lei Tuner SANSUI T-510 = 130 lei Tuner ONKYO T-9060 = 125 euro Tuner ONKYO T-9990 = 300 euro Tuner KENWOOD KT-1100 D = 220 euro Tuner YAMAHA T-85 = 150 euro Tuner SANSUI TU-717 = 235 euro Tuner SANSUI TU-X701 = 330 dolari Tuner MARANTZ ST 300 = 380 lei Tuner MARANTZ ST 400 = 465 lei Tuner GRUNDIG T-9000 FineArts = 220 euro Amplificator SONY TA-313 = 115 euro Amplificator AKAI AM 2200 = 200 lei Linie audio (amplificator+tuner) MARANTZ PM-253 + ST-253 = 100 euro Preturile sunt usor negociabil. Trimit oriunde in tara cu posta romana/atlassib si plata ramburs. Mai multe detalii si poze reale ale aparatelor gasiti in cadrul acestui topic. |
6 Attachment(s)
Receiver AIWA AX 7400
Model deosebit, in conditii tehnice si optice impecabile, made in JAPAN! Pret 135euro! Caracteristici tehnice: - Dimensiuni: 420mm (w) x 150mm (h) x 340mm (d) - Greutate: 12 kg !! - High filter - Loudness - Stereo/mono - FM muting - AFC - Bass adjustable at either 200 or 400Hz, defeatable - Treble adjustable at either 2.5kHz or 5 kHz, defeatable - Backlit FM tuning and signal level meters - Brushed aluminium front panel Inputs and outputs: - Tape Rec/Play (RCA and din plugs) - Aux input - Phono input with ground - AM/FM tuner built in - Headphone socket on front - A and B speaker selectors (can do A, B, A+B) Aparatul se vinde impreuna cu manualul de utilizare ORIGINAL! |
Deck TASCAM SYNCASET 234
Model destinat studiourilor profesionale de inregistrari, made in JAPAN, functie DBX-II, posibilitatea de redare pe 4 piste!! Greutate: 10kg! Pret 235euro negociabil! |
6 Attachment(s)
Receiver GRUNDIG R45
Model vintage EXCEPTIONAL produs intre anii 1975-1977, FOARTE RAR, made in GERMANY, carcasa METALICA, culoare neagra. Pret 150euro! Aparatul este in stare foarte buna tehnica si optica, fara interventii! Link video REAL: https://www.youtube.com/watch?v=2cgre...ature=youtu.be Aparatul este MASIV, GREU si IMPUNATOR! Adevaratii colectionari apreciaza valoarea reala a acestui aparat DEOSEBIT! Dimensiuni: 540 x 150 x 320 mm Greutate: 12,7 KG!!! |
6 Attachment(s)
Receiver TELEFUNKEN HR 5000
Made in GERMANY, stare foarte buna tehnica si optica. Pret 125euro Detalii tehnice:
| All times are GMT +2. The time now is 00:23. |
