-   Alte Anunturi Piese (https://forum.4tuning.ro/524-anunturi-piese.html)
-   -   Comanda piese USA pentru masini americane (https://forum.4tuning.ro/524-anunturi-piese/208795-comanda-piese-usa-masini-americane.html)
Meridivs 20-05-11 15:36
1999 DODGE STRATUS 2.4L 2429cc 148cid L4 FI (X) DOHC
Brake/Wheel Hub : Brake Pad
WAGNER QuickStop (Only 8 Remaining)
Rear; Organic
$29.87
WAGNER QuickStop
Front; OE Semi-Metallic
$31.79
Brake/Wheel Hub : Rotor
RAYBESTOS Professional Grade
Front; Outside Diameter 10.235" / 5 Bolt Holes 10-1/4" Rotor Diameter;
$51.43
x2
$102.86
Subtotal
$164.52
Country: Romania, Zip/Postal Code: 061078
Shipping from 2 locations:
Shipping Location AExpress Mail International from United States
$75.25
Shipping Location BExpress Mail International from United States
$31.90
Total
$271.67
Pretul include toate taxele, transportul pe teritoriul SUA, asigurare, vama si taxele de aeroport. Timp mediu de livrare - 2 saptamani din momentul lansarii comenzii.
Pentru oferta pe masina dvs. trimiteti un mesaj cu piesa dorita, modelul masinii, anul si motorizarea pe e-mail atlanta@pieseamerica.com sau mobil 0724 171 140
Meridivs 04-06-11 17:12
Re: Comanda piese USA pentru masini americane
2003 NISSAN ALTIMA 2.5L 2500cc L4 FI [QR25DE] DOHC
Suspension : Strut Mount
MONROE
Strut-Mate Susp Strut Mounting Kit
$31.79
x2
$63.58
Suspension : Strut Assembly
MONROE Monro-Matic Plus
Front Left
$63.99
Front Right
$65.89
Steering : Tie Rod End
RAYBESTOS
Inner Tie Rod
$22.90
x2
$45.80
RAYBESTOS
Outer Tie Rod
$17.28
x2
$34.56
Subtotal
$273.82
Country: Romania , Zip/Postal Code: 061078
Shipping Location A Express Mail International from United States
$80.71
Shipping Location B Express Mail International from United States
$39.48
Total
$394.01
Pentru masina dvs. trimiteti un mesaj cu piesa dorita, modelul masinii, anul si motorizarea pe e-mail atlanta@pieseamerica.com sau mobil 0724 171 140
Meridivs 05-06-11 17:02
2008 CADILLAC ESCALADE 6.2L 6199cc 378cid V8 FI (8) [L92] OHV
8 Attachment(s)
Fuel/Air : Air Filter
WIX
Heavy Duty Version
$18.93
Engine : Oil Filter
ACDELCO DURAGUARD
FILTER,OIL
$14.27
Suspension : Stabilizer Bar Bushing
RAYBESTOS Sway Bar Frame Bushing Kit; Contents: (2) Bushings - 1 1/8" ID Blue Professional Grade; Sway Bar Bushing
Rear Suspension; To Frame
$18.87
Suspension : Stabilizer Bar Link
RAYBESTOS Stabilizer Link Kit; Contents: (2) Bolts - Hex 3/8-16 8.00"; (2) Spacers - Metal 3.00"; (8) Bushings - Blue Synthetic; (8) Washers - Cupped; (2) Nuts - Hex Lock 3/8-16; Instruction Sheet Professional Grade; Sway Bar Repair Kit
Front Suspension
$23.47
Suspension : Control Arm Bushing
RAYBESTOS Sold individually Professional Grade
Front Suspension; Upper; Plus Or Minus 1 Degree Camber; Offset Bushing
$54.99
WAGNER ThermoQuiet
Set, Rear; OE Ceramic
$61.79
WAGNER ThermoQuiet
Set, Front; Incl. Inst. Hardware Kit; OE Ceramic; Incl. Inst. Hardware Kit
$65.79
Suspension : Ball Joint
RAYBESTOS
Front Suspension; Lower; Cast Iron Arm
$22.83
Belt Drive : Belt
GATES Part # 6K935AP RoadMax Automotive V-Ribbed Belt (Standard)
$15.55
Subtotal $296.49
Shipping from 3 locations:
Shipping Location A Express Mail International from United States $35.02
Shipping Location B Express Mail International from United States $84.10
Shipping Location C Express Mail International from United States $68.44
Total $484
Meridivs 10-06-11 14:52
2004 CHRYSLER PT CRUISER 2.4L 2429cc 148cid L4 FI (B) DOHC
11 Attachment(s)
WIX
$9.67
MONROE Sensa-Trac
Front
$69.99 x2
$139.98
Cooling System : Thermostat Housing Gasket
FEL-PRO
$5.72
MONROE Strut-Mate Susp Strut Mounting Kit
Front
$37.79 x2
$75.58
Inner
$33.79 x2
$67.58
Outer
$39.79 x2
$79.58
Heat & Air Conditioning : Cabin Air Filter
WIX Chrysler PT Cruiser Replaces: Chrysler 05058040AA
$24.79
Ignition : Spark Plug
ACDELCO PLATINUM PLUG
SPARK PLUG .040 GAP
* Non-stock item--shipping delayed up to 5 business days
+ Sold in packs of 8; Price reflects cost of each individual item, not the pack
$8.30 x8
$66.40
Steering : Power Steering Filter
A-1 CARDONE MagnaPure In-Line Filter
1.25" X 3" w/ 3/8" Outer Diameter Neck (For 3/8" ID Hose)
$16.83
Ignition : Spark Plug Wire Set
STANDARD MOTOR PRODUCTS Premium Wire Set; Universal Fit; Conductive/ Metallic Core w/ Bendable Terminals
16 Valve; DOHC
$26.32
Subtotal $512.45
Shipping from 4 locations:
Shipping Location A Express Mail International from United States $30.85
Shipping Location B Express Mail International from United States $43.46
Shipping Location C Express Mail International from United States $96.00
Total $682.76
Meridivs 11-06-11 11:24
1990 JEEP WRANGLER 4.2L 258cid L6 2BBL (T) OHV
Engine : Valve Cover Gasket
FEL-PRO
w/Aluminum valve cover
$9.70
CHAMPION
OEM Spark Plug; .035
$2.69
x6 pcs.
$16.14
CHAMPION PowerPath Professional [Wholesaler Closeout - Private Label Pkg.] (Only 2 Remaining)
$22.52
Ignition : Ignition Control Module (ICM)
AIRTEX / WELLS [19017043, 4883922AA, 53005079, 8953005079]
$83.89
Ignition : Distributor
CARDONE SELECT Electronic Distributor Assembly
Contains Cap & Rotor
$74.89
Subtotal
$207.14
Shipping Location A Ground (FedEx or UPS)
$19.43
Shipping Location B Priority Mail
$44.55
Shipping Location C Ground (FedEx or UPS)
$17.16
Total
$288.28
Meridivs 25-06-11 16:21
2001 DODGE STRATUS 2.7L 2700cc 167cid V6 FI (U) DOHC
Cooling System : Thermostat Housing / Water Outlet
DORMAN Coolant Air Bleeder
Sedan & Convertible; w/ Coolant Air Bleeder
$56.89
Subtotal $56.89
Shipping: International from United States $21.50
Total $78.39
Meridivs 29-06-11 16:44
1993 FORD AEROSTAR 4.0L 245cid V6 MFI (X) OHV
7 Attachment(s)
MEVOTECH Steering Tie Rod End
4WD; Front Inner
AWD; FRONT INNER
RWD; Power steering; Front Inner
$18.92
Power steering; Front Outer
$14.37
x2
$28.74
MEVOTECH Front
$17.17
RAYBESTOS Control Arm Bushing Kit; 2 Bushings - Silentbloc Service Grade
$17.55
MEVOTECH Front Lower, Set of 2
$15.60
MEVOTECH Suspension Ball Joint
RWD; Front Lower
$16.52
RAYBESTOS Service Grade
$23.62
Subtotal
$138.12
Shipping Location A International from United States $35.34
Shipping Location B International from United States $20.52
Total
$193.98
Meridivs 07-07-11 15:29
2008 Dodge Avenger SXT
2008 DODGE AVENGER SXT
MEVOTECH
Front Right Lower
$86.79
MEVOTECH
Front Left Lower
$86.79
Rear Lower control arm, sebring, avenger, w/o awd
$68.43
x2
$136.87
DEEZA Premium Quality
Patented Stronger Greaseable Version; Front Outer
$32.79
x2
$65.58
Subtotal
$376.03
$22.94
$59.48
Shipping Location C International from United States
$62.34
Total
$520.79
Meridivs 09-07-11 15:13
2004 CADILLAC ESCALADE 6.0L 364cid V8 FI (N) OHV
WAGNER ThermoQuiet
Front; OE Ceramic
$40.79
WAGNER ThermoQuiet
Rear; 4WD; OE Ceramic
$41.79
Subtotal $82.58
Shipping: International from United States $35.34
Total $157.92
Meridivs 16-07-11 16:07
1992 FORD TAURUS GL 3.0L 182cid V6 MFI (U) OHV
6 Attachment(s)
Wiper & Washer : Wiper Motor
MOTORCRAFT [Wholesaler Closeout -- 30 Day Warranty]
Motor: w/ Wiring Kit; Front
$87.79
Heat & Air Conditioning : A/C Compressor
SPECTRA PREMIUM New (Only 3 Remaining)
w/ Clutch; w/ FS10 Compressor; 3/8" Space in Front of Belt
$171.79
Heat & Air Conditioning : A/C Condenser
SPECTRA PREMIUM
$85.79
Heat & Air Conditioning : A/C Receiver Drier / Accumulator
FOUR SEASONS R134a
$92.79
Heat & Air Conditioning : A/C System O-Ring & Gasket Kit
FOUR SEASONS O-Ring and Gasket Seal Kit
$14.18
Heat & Air Conditioning : Inline Filter
ACDELCO FILTER,A/C REFRIG 5/8IN ID FOR SUCTION LINE
$27.79
Cooling System : Radiator Fan Assembly
DORMAN Single Fan, Dual Function
Fully Assembled for Ease of Installation; Incl. Shroud, Motor & Blade
$79.79
Subtotal $559.92
Shipping Location A Express International from United States $97.23
Shipping Location B FedEx International Economy from United States $76.35
Shipping Location C Express International from United States $57.99
Total $791.49
mmmbbb67 02-08-11 01:21
Poti sa aduci un kit shaved door ptr 2 usi de 40 lbs + sistemul manual in caz ca moare bateria, daca da la ce pret, merci
Meridivs 03-08-11 11:20
Se poate aduce, va rog sa trimiteti link-ul produsului pentru o estimare exacta a costurilor de transport.
Meridivs 25-08-11 16:53
1998 JEEP GRAND CHEROKEE LIMITED 5.2L 318cid V8 MFI (Y) OHV
Steering : Steering Gear
ACDELCO Power Steering
GEAR,STRG
$230.99
$92
Total $323
Pretul include toate taxele si comisioanele vamale. Timp mediu de livrare - 2 saptamani din momentul lansarii comenzii.
Pentru oferta trimiteti un mesaj cu piesa dorita, modelul masinii, anul si motorizarea pe e-mail atlanta@pieseamerica.com sau mobil 0724 171 140
Meridivs 26-08-11 11:37
1998 CHRYSLER CIRRUS 2.5L 2497cc 152cid V6 MFI (H) [EEB] SOHC
MONROE Sensa-Trac
Front
$65.79
x2
$131.58
MONROE Sensa-Trac
Rear
$68.79
x2
$137.58
DORMAN
Includes Ball Joint and Bushings; Front Right Lower
$79.43
DORMAN
Includes Ball Joint and Bushings; Front Left Lower
$77.89
Engine : Timing Belt Component Kit
GATES
4 Components (1 Belt, 2 Idlers, 1 Water Pump) PowerGrip Premium OE Timing Belt Component Kit W/Water Pump
Interference engine application
$97.79
Subtotal
$524.27
$61.90
Shipping Location B Express International from United States
$87.74
Total
$673.91
Pentru oferta specifica masinii dvs. trimiteti un mesaj cu piesa dorita, modelul masinii, anul si motorizarea pe e-mail atlanta@pieseamerica.com sau mobil 0724 171 140
Meridivs 28-08-11 16:12
2005 JEEP GRAND CHEROKEE LIMITED
RAYBESTOS 390 Professional Grade
$54.79
x2
$109.58
Front Suspension; Upper; Non-Adjustable
$68.79
x2
$137.58
Subtotal
$247.16
Shipping: International Express
$41.23
Total
$288.39
- Copyright 2025 4Tuning
