Re: Oltcit Club 11RL - BC 99 FNX - The Grimm Reaper
Does not matter the position of the engine,if you want to fit a small v6 and you put your mind to it,it's possible!
From what i've measured any flat four below 2litres,with 8 valves(so only 1 camshafts on every side) could fit nicely,but you have to make new engine mounts,and an adapter plate between the gearbox and the engine,or fit a longitudinal gearbox with new driveshafts,or change the rear axle and make it RWD:shock: |
users like julaikos and pupa have orerbored and fitted diferent pistons to have a bigger displacemend.... Pupa ..even made a double turbo job.... ;) Look for the threads.... :rolleyes2 and you shall see....:twisted: |
poze de sezon...cica8)
misto masinuta :D
cand ma uit pe la pozele voastre si cele mai vechi, regret ca nu am prins si eu masinuta mai devreme...dar daca-n 2007 eram eu copil tampit si vroiam servo, ac ...asta e |
ca acu am si servo si ac... si nu ma mai incanta despre abs ..imi vine greata ...ca imi face masaj la picior si nu opreste masina asa cum vreau eu, asa ca am scos siguranta si merg fara ....:twisted: la oltcit am dat cu un ulei siliconic de la Wurtz(parca asa ii spune) pe bucsele de la volan si se misca super usor.. Am comandat niste garnitui pt turbo de pe ebay ..sper sa imi vina cat de curand ca sa le pot monta ca cele care le-am facut eu s-au ars deja si scapa gaze pe langa... |
Bai cred ca o sa-ti fac un cadou,si anume sistemul ala de acceleratie de gsa :P
nu zau.... stai ca m-am prins
nu imi spune ca deja te-ai apucat de ....stii tu ce...;) multumesc anticipat.... poate apuc sa pun si eu modina cu radiatoru anu asta...:rolleyes2 ca si asa le am cumparate de prin 2008 sau 2009:lol: |
azi am achizitionat ceva pt masina....:twisted:
| All times are GMT +2. The time now is 14:43. |
