Re: VW - DIY (Do it yourself)
DIY Inlocuire radiator caldura GOLF 3 : http://volkswagen.ms...showtopic=98763
DIY Short Shifter Golf 3 : http://forums.vwvort...read?id=2471732 DIY Inlocuire bucse punte spate GOLF 3 : http://volkswagen.ms...showtopic=88056 DIY reparatie pompa servodirectie Golf 3 : http://volkswagen.ms...showtopic=64085 http://volkswagen.ms...howtopic=100445 cand am timp mai postez 30-40 salut |
Imi poate spune si mie cineva daca se poate monta cutie de viteze de golf 2 la motor de golf 3?
Va multumesc! |
Re: VW - DIY (Do it yourself) golf2
DIY GOLF 2
Instalare MFA http://www.doppel-wobber.de/forum/in...ge=Info&id=161 http://forums.vwvortex.com/showthread.php?295039 http://www.golfgl.de/mfa-nachrusten/ http://forums.vwvortex.com/zerothread?id=2893535 - Front Solid Mount http://forums.vwvortex.com/zerothread?id=2172704 - Redone Headliner http://forums.vwvortex.com/zerothread?id=2429595 - Homemade Rear strut Bar http://forums.vwvortex.com/zerothread?id=2406753 - Tint Your Taillights http://forums.vwvortex.com/zerothread?id=1979975 - Your Own mk4 Style Key http://forums.vwvortex.com/zerothread?id=2160184 - OBD2 Port For Your Car. http://forums.vwvortex.com/zerothread?id=2359900 - Starter Repair/Replacement http://forums.vwvortex.com/zerothread?id=1912244 - Make Heater Controls LIght Up Red http://forums.vwvortex.com/zerothread?id=2260248 - Replace Sunroof gasket http://forums.vwvortex.com/zerothread?id=1063928 - ABA 2.0 Swap http://forums.vwvortex.com/zerothread?id=2294015 - Open element Air Filter http://www.matey-matey.com/debadged_grille.shtml - Bagdeless Grill http://forums.vwvortex.com/zerothread?id=2225178 - Another LED tutorial http://forums.vwvortex.com/zerothread?id=2195481 - Badgless Aero Grill http://forums.vwvortex.com/zerothread?id=2152124 - Roll Fenders http://forums.vwvortex.com/zerothread?id=2127198 - Horn DIY http://forums.vwvortex.com/zerothread?id=2003249 - Remove Lense from inside Clear Signals http://forums.vwvortex.com/zerothread?id=2420000 - Tailgate Bora/Jetta Style http://forums.vwvortex.com/zerothread?id=2131917 - Shifter Box Bushing Carrier http://forums.vwvortex.com/zerothread?id=1890859 - mk3 Dash Swap to mk2 http://forums.vwvortex.com/zerothread?id=2191462 - Corrado Dash Swap (GO TO PAGE 4.) http://futrellautowerks.com/projects/89clvr6.htm - vr6 Swap guide! http://forums.vwvortex.com/zerothread?id=2437737 - Redone Headliner http://forums.vwvortex.com/zerothread?id=2443253 - Photography Tips http://forums.vwvortex.com/zerothread?id=2443945 - Headlight LED http://forums.vwvortex.com/zerothread?id=2408122 - Another Headliner Redone http://forums.vwvortex.com/zerothread?id=2445085 - Alarm System install (including Shock Sensor) http://www.thediygroup.com/rbrakes.html - Rear drum to Rear Disc Swap http://www.thediygroup.com/5thdamage.htm - For when your 5th gear hates you. http://www.thediygroup.com/5thswap.htm - After your 5th gear hates you. swap it http://www.geocities.com/nathanklippel/short_shift - DIY shortshift http://www.thediygroup.com/020flange.htm - Replacing Drive Flange on the 020 http://users.snip.net/~gajewski/1.8t...2shellFAQ.html - Great 1.8T DIY http://www.vintagewatercooleds.com/t.../Headlight.htm - Headlamp http://forums.vwvortex.com/zerothread?id=1092128 - Turbo Charger for your 8v, and 16v http://forums.vwvortex.com/zerothread?id=2353060 - Lightweight Battery install http://forums.vwvortex.com/zerothread?id=566501&page=12 - vr6 sway bar install (half way down the page) http://forums.vwvortex.com/zerothread?id=566501&page=13 - Fog/driving light install (1/4th down the page.) http://forums.vwvortex.com/zerothread?id=1887777 - Rusty battery tray replacement http://members.aol.com/mk28v/howto.htm - Strut bar And tons O other DIY's http://www.griotsgarage.com/catalog....1500&SKU=11183 - Bumber Dye http://www.4130-products.com/step/remove/index.htm - remove a2 gauge cluster. http://www.4130-products.com/step/install/index.htm - install custom gauges http://www.4130-products.com/step/handle/index.htm - A2 door handle swap http://www.4130-products.com/step/gl/index.htm - change the color of the gauge cluster lights http://www.4130-products.com/step/odometer/index.htm - Odometer Fix http://www.4130-products.com/step/a2fbrake/index.htm - A2 Brakes Fix http://www.4130-products.com/step/clunk/index.htm - Fixing A2 Clunky Struts http://www.4130-products.com/step/shim/index.htm - Installing shims http://www.4130-products.com/step/screw/index.htm - Remove the Screw from the rotor http://www.4130-products.com/step/bigbrake/index.htm - Install Big brake http://www.4130-products.com/step/struts/index.htm - Swap out your struts http://www.4130-products.com/step/ign/index.htm - A2 ignition switch Replacement http://www.4130-products.com/step/vapor/index.htm - Vapor Barrior Replacement http://www.4130-products.com/step/cvboot/index.htm - CV Boot And Half Axle Replacement http://www.4130-products.com/step/hub/index.htm - Hub Centric Adapters http://www.4130-products.com/step/jack/index.htm - Where to put the damn jack http://forums.vwvortex.com/zerothread?id=759123 - mk3 dash in the mk2! http://optiecorp.com/dekon/diy/Dimminglights.txt - Fix your dimming lights http://optiecorp.com/dekon/diy/a2mk2standfor.txt - what does mk2 and a2 stand for http://optiecorp.com/dekon/diy/abaswap.txt - EVERYTHING on ABA Swaps http://optiecorp.com/dekon/diy/fenderolling.txt - Fender rolling http://optiecorp.com/dekon/diy/replacespedocable.txt - Replace the Speedo Cable http://optiecorp.com/dekon/diy/stickydoorlocks.txt - Fix sticky door locks http://forums.vwvortex.com/zerothread?id=1070902 - Install Chinese style Handles http://forums.vwvortex.com/zerothread?id=1475085 - another great 1.8t Swap Guide! HUGE! http://forums.vwvortex.com/zerothread?id=1935373 - HockeyPuck motor mounts (i've seen them before they work perfect!) NOTA * MOMENTAN AM TIMP DOAR PT GOLF2/GOLF3 TOATE LINKURILE SUNT VERIFICATE DE MINE , GOOGLE TRANSLATE POATE FI CEL MAI BUN PRIETEN AL VOSTRU SUCCES Propun conduceri ca acet topic DIY sa fie impartit in categorii ex : vw GOLF ==> golf1 golf 2 golf 3 s.a.m.d fara alte postari si o sectiune CERERI . Ma pot ocupa personal O ZI BUNA |
Service vw passat b6 tdi 2.0 l 140 cp
Pentru schimbul de ulei am folosit un extractor de ulei Pela 6000 https://imgur.com/1xNaT7Z https://imgur.com/cdSKCPF https://imgur.com/TESiEDv https://imgur.com/sONNZfh https://imgur.com/E9QJ0hm https://imgur.com/ryofen5 https://imgur.com/0IVaLe0 https://imgur.com/vGm7eac https://imgur.com/YDwq9g0 https://imgur.com/yROO6gw https://imgur.com/VKUi5iP https://imgur.com/dCbXXQW https://imgur.com/86KeHiO https://imgur.com/wymDsV3 https://imgur.com/vvZzwKW https://imgur.com/rDwNGFN |
aveti idee daca se poate monta xenon in proiectoare de golf 3? ce fel de KIt i-mi trebuie?
Ceva pentru golf IV 1.9 TDI ('99) ?
| All times are GMT +2. The time now is 22:05. |
