-   Anunturi Auto Daewoo (https://forum.4tuning.ro/496-anunturi-auto-daewoo.html)
-   -   [Vand] Piese Matiz (https://forum.4tuning.ro/496-anunturi-auto-daewoo/214707-vand-piese-matiz.html)
mannuadi 08-09-11 16:37
Re: [Vand] Piese Matiz
se mai adauga
fete usi matiz 2 - 250 ron
macarale geamuri electrice - 200 ron
caseta servodirectie ,pompa servo si conducte - 600 ron
ceasuri matiz 2 - 80 ron
volan matiz simplu - 120 ron
tripla stanga - 50 ron
motor euro 2 - 1200 ron
electromotor - 200 ron
alternator - 200 ron
cutie de viteza - 350 ron
planetare - 90 ron buc
etrier - 80 ron buc
portfuzeta completa - 100 ron buc
cabluri schimbator - 100 ron
pedalier - 80 ron
caseta directie mannuala - 250 ron
pompa frana + servo - 100 ron
bord negru + ceas - 150 ron
mocheta gri - 100 ron
cablu frana de mana - 30 ron
bara stabilizatoare - 50 ron
macarale geamuri + 2 manivele - 70 ron set 4 buc
haion - 80 ron
stop frana central cu suport - 40 ron
aripa dreapta - 40 ron
punte spate - 100 ron
bara spate - 80 ron
si multe altele
preturi negociabile tel 0762285498
mannuadi 14-09-11 19:58
S-au vandut fetele de usa ,consola schimbator ,macaralele electrice ,instalatia electrica si caseta de servodirectie
mannuadi 20-09-11 19:35
se mai adauga
jante aliaj 4*114.3 5.5 j et 41 r13 +anvelope 175/60 r13 - 1000 ron
telescoape haion - 45 ron buc
coloana directie -80 ron
praguri noi klokkerholm 110 buc
toba finala e3 - 250 ron
toba intermediara e3 - 200 ron
racord flexibil +catalizator e3 - 200 ron
precatalizator + sonda lambda -150 ron
radiator racire - 150 ron
radiator incalzire - 120 ron
etrier - 80 ron buc
pedalier - 80 ron
haion - 80 ron
bara spate - 80 ron
si multe altele
mannuadi 25-09-11 10:38
se mai adauga piese matiz 2008 :
fete usi simple - 50 ron set
finitii interior - 100 ron set
plansa bord simplu - 100 ron
macarale geamuri - 100 ron set
ansamblu stergator fata cu motoras - 100 ron
centuri fata spate - 100 ron
modul climatizare - 80 ron
tubulatura dezaburire - 30 ron
tubulatura intrare aer - 20 ron
tubulatura ventilatie - 30 ron
modul incalzitor - 50 ron
suflanta - 50 ron
evaporator - 50 ron
evaporator pt euro 3 - 80 ron
mocheta interior - 100 ron
caseta directie manuala - 250 ron
arcuri fata spate - 100 ron set
punte spate cu abs - 400 ron
conducte frana spate abs - 100 ron
pompa frana +modulator abs si conducte - 400 ron
fuzete cu abs + disc frana +etrier - 220 buc
plaetare cu senzor abs - 150 ron buc
senzori abs - 200 ron set
jante aliaj 4*114.3 5.5 j et 41 r13 negre - 850 ron
distantiere punte spate - 100 ron
usa fata stanga + set bandouri - 300 ron
usa fata dreapta - 200 ron
usa spate stanga - 100 ron
usa spate dreapta - 150 ron
geamuri usi fata cu tenta verde - 250 ron
scaune matiz - 50 ron buc
bancheta - 80 ron
finitie plafon -50 ron
tel : 0762285498
mannuadi 02-10-11 19:27
oglinda cu reglaj electric - 100 ron buc
fete usi simple + manere - 50 ron set
perii geamuri - 20 ron set
motor matiz e4 - 1650 ron https://img685.imageshack.us/img685/8769/imagine1559.jpg
cutie de viteza e4 - 650 ron
motor matiz e2 - 1200 ron https://img26.imageshack.us/img26/2609/imagine1560.jpg
cutie de viteza e2 - 400 ron
pompa de benzina - 200 ron
rezervor benzina - 50 ron
gura umplere rezervor - 25 ron
toba finala e4 - 250 ron https://img801.imageshack.us/img801/5939/imagine1888.jpg
toba intermediara e4 - 200 ron https://img853.imageshack.us/img853/3659/imagine1883.jpg
racord flexibil +catalizator e4 - 200 ron https://img265.imageshack.us/img265/7098/imagine1882.jpg
precatalizator + sonda lambda - 150 ron
levier frana de mana - 40 ron
cablu frana de mana - 50 ron
punte spate cu abs (tamburi ,piston ,frana , saboti frana ) aproape noi - 400 ron
brate punte spate - 50 buc
fuzete cu abs + disc frana +etrier - 220 buc https://img15.imageshack.us/img15/1307/imagine1891.jpg
planetare cu senzor abs - 150 ron buc
jante aliaj 4*114. 3 5. 5 j et 41 r13 negre - 850 ron https://img199.imageshack.us/img199/3559/imagine1876.jpg
coloana directie - 80 ron
suflanta - 50 ron
evaporator - 50 ron
set bandouri - 100 ron
bancheta - 80 ron
finitie plafon - 50 ron
preturi negociabile tel 0762285498 sau 0722521798
GAby645 03-10-11 10:39
am nevoie de :
chedere usi ( cele exterioare si interioare )
fete de usi
manere plafon spate
set centuri spate
macarale geamuri spate + macara stanga fata !!
fami un pret pe toate daca le ai !!
stima
mannuadi 16-10-11 21:07
s-au dat :
motor matiz e2
cutie de viteza e2
au mai ramas :
suflanta - 50 ron
evaporator - 50 ron
bancheta - 80 ron
lusian 17-10-11 13:43
tablou de bord matiz 2004 ( tot ansamblul kilometraj, indicator benzina, temperatura ulei)Aveti asa ceva?
mannuadi 17-10-11 20:39
am doar cele doua ceasuri indicator benzina si temperatura ulei
andrei87grs 17-10-11 21:37
o carcasa de filtru de aer ai?
mannuadi 22-10-11 19:21
s-au dat :
motor matiz e2
cutie de viteza e2
au mai ramas :
finitii interior - 80 ron set
ansamblu stergator fata cu motoras - 800 ron
centuri fata spate - 80 ron
motor matiz e4 - 1450 ron
cutie de viteza e4 - 550 ron
toba finala e4 - 200 ron
toba intermediara e4 - 180 ron
levier frana de mana - 20 ron
cablu frana de mana - 40 ron
distantiere punte spate - 80 ron
modul climatizare - 60 ron
suflanta - 50 ron
evaporator - 50 ron
evaporator pt euro 3 - 60 ron
mocheta interior - 80 ron
usa fata dreapta - 150 ron
usa spate dreapta - 100 ron
scaune matiz - 40 ron buc
bancheta - 60 ron
finitie plafon - 40 ron
mannuadi 26-10-11 15:52
au mai ramas :
suflanta - 50 ron
bancheta - 60 ron
mannuadi 08-11-11 18:58
preturi negociabile:
fete usi simple + manere - 30 ron set
finitii interior - 50 ron set
plansa bord simplu - 800 ron
macarale geamuri - 60 ron set
ansamblu stergator fata cu motoras - 50 ron
centuri fata ,spate - 50 ron
motor matiz e4 - 1200 ron
cutie de viteza e4 - 420 ron
pompa de benzina - 100 ron
toba finala e4 - 180 ron
toba intermediara e4 - 150 ron
racord flexibil +catalizator e4 - 150 ron
precatalizator + sonda lambda - 100 ron
brate punte spate - 40 buc
conducte frana spate abs - 70 ron
pompa frana +modulator abs si conducte - 300 ron
fuzete cu abs + disc frana +etrier(etrierul este vopsit rosu cu vopsea foliatec) - 200 buc
planetare cu senzor abs - 120 ron buc
senzori abs - 150 ron set
jante aliaj 4*114. 3 5. 5 j et 41 r13 - 800 ron
telescoape haion - 40 ron buc
coloana directie - 50 ron
radiator incalzire - 100 ron
modul climatizare - 50 ron
tubulatura ventilatie - 20 ron
modul incalzitor - 40 ron
suflanta - 40 ron
set bandouri originale - 80 ron
bancheta - 60 ron
mannuadi 20-11-11 10:00
au mai ramas:
motor matiz e4 - 1000 ron
ecu motor e4 - 400 ron
ecu motor e2 - 150 ron
cheie cu chip ,contact ,butuc usa st dr si cititor chip - 200 ron
jante aliaj 4*114.3 5.5 j et 41 r13 - 800 ron
parbriz original matiz - 200 ron
pompa frana + modulator abs si conducte - 300 ron
mannuadi 24-11-11 17:41
Vand Jante 13" 4x114,3 ; 5,5J ; Et41. echipate cu anvelope de vara 175/60 r13 (marime optionala pt matiz care se poate trece in CIV ); Mai ofer 1 anvelopa aceiasi marime pe janta de tabla .anvelopele sunt toate marca Dunlop si acelasi model . Pret : 1000 de lei negociabil.
Pentru mai multe detalii pm sau 0762285498.
mannuadi 27-11-11 10:30
8 Attachment(s)
mannuadi 06-12-11 17:17
motor matiz e3 sau 4 - 1200 ron
ecu motor e3 - 350 ron
pedalier - 90 ron
aripa dreapta - 50 ron
modul climatizare - 40 ron
tubulatura dezaburire - 25 ron
modul incalzitor - 30 ron
suflanta - 30 ron
evaporator pt euro 3 - 40 ron
comutator avarii - 25 ron
comutator stergatoare fara temporizare - 25 ron
comutator semnalizare - 25 ron
buton ceata spate - 20 ron
buton dezaburire luneta - 20 ron
bancheta - 60 ron
haion cu geam cu luneta - 120 ron
stop frana luneta - 40 ron
Pentru mai multe detalii pm sau 0762285498. sau 0722521798
mannuadi 28-12-11 10:20
tamburi cu rulmenti - 150 ron
punte spate - 150 ron
pedalier - 90 ron
plansa bord simplu - 80 ron
pompa servo pt directie - 150 ron
pompa frana - 80 ron
pompa frana +modulator abs si conducte fata - spate - 250 ron
suflanta - 30 ron
mocheta interior pe negru sau gri - 80 ron buc
bancheta - 60 ron
Jantele se dau si la schimb cu jante de aliaj pt vw-seat ,4*100 6 - 7 j, et 35 - 38, r14
neaga_bmw 19-01-12 23:12
pedalier - 90 ron
suflanta - 30 ron
bancheta - 60 ron
sal reinoieste si tu preturile:D
mannuadi 20-01-12 17:27
motor matiz e3 - 1000 ron
bobina e3 - 200 ron
bobina e2 - 80 ron
ecu motor e3 - 300 ron
set de arcuri matiz - 100 ron
pompa servodirectie - 100 ron
distantiere 15 mm punte spate - 100 ron
punte spate simpla - 150 ron
tamburi cu rulmenti - 100 ron
geamuri usi fata st - dr cu tenta verde - 100 ron
parbriz original matiz ca nou - 200 ron
pedalier - 50 ron
macarale geamuri - 50 ron set
levier schimbator cu cabluri - 80 ron
pompa frana + modulator abs + senzori abs si conducte - 200 ron
tubulatura dezaburire - 20 ron
suflanta - 30 ron
bancheta - 50 ron
haion cu geam cu luneta - 110 ron
Jantele se dau si la schimb cu jante de aliaj ,4*100 6 - 7 j, et 35 - 38, r14
rat_lycu 27-01-12 17:17
distantierele le poti trimite luni la focsani ? multumesc .
mannuadi 27-01-12 19:59
distantierele s-au dat , restul ramane valabil
mannuadi 18-02-12 12:16
motor matiz e3 - 900 ron
bobina e3 - 200 ron
bobina e2 - 50 ron
ecu motor e3 - 250 ron
punte spate simpla - 100 ron
pedalier - 50 ron
suflanta - 30 ron
bancheta - 50 ron
03xuc 28-02-12 19:18
salut, imi trebuie si mie vasul de apa pentru spalat parbrizul, ce pret????
andrei87grs 28-02-12 20:00
salut! tobe pentru euro 2 ai?
mannuadi 29-02-12 18:07
da ,am toba intermediara si toba finala
mannuadi 02-03-12 20:13
Pentru mai multe detalii pm sau 0762285498. sau 0722521798[/QUOTE]
andrei87grs 04-03-12 14:30
la ce pret ambele ?
mannuadi 04-03-12 14:58
150 ron ambele
sorin_maican20 04-03-12 22:29
Jantele fara anvelope la le pret ar fi?
Multumesc.
mannuadi 05-03-12 04:38
750 ron
dar suna-ma si ne intelegem
mannuadi 07-03-12 19:17
Jantele s-au vandute ,au ramas anvelopele de vara 175/60 r13 (marime optionala pt matiz care se poate trece in CIV) ,anvelopele sunt toate marca Dunlop si acelasi model . Pret : 400 ron 5 buc
andrei87grs 07-03-12 20:25
salut! poti sa te uti daca ai cumva inelul de plastic(ornament) care vine in jurul manetei de reglaj a oglinzii?ala care vine prins de fata de la usa. Nu te-am mai sunat ca e putin tarziu acuma....a si ma am o intrebare daca ai cumva partea aia de la carcasa filtrului de aer, nu stiu daca se poate separa.Atasez si poze.
andrei87grs 10-03-12 17:16
recomand cu incredere! un om de nota 10!
mannuadi 17-03-12 19:01
10 Attachment(s)
vand anvelope vara 175/60 r13 ,
3 buc Dunlop Sp Sport D8 profil 8 mm - 80 ron buc
2 buc Dunlop Sp Sport 2000 profil 4 mm - 40 ron buc
2 buc Kumho Solus Kh15 profil 4 mm - 40 ron buc
bobina e3 - 200 ron
bobina e2 - 50 ron
pedalier - 50 ron
suflanta - 30 ron
bancheta - 50 ron
mannuadi 19-05-12 21:59
motor matiz e3 - 800 ron
bobina e3 - 200 ron
bobina e2 - 80 ron
electromotor - 150 ron
set fise bujii e2 - 35 ron
set fise bujii e3 - 40 ron
iac - 40 ron
tps - 35 ron
senzor ax came e3 - 50 ron
portfuzeta - 50 ron buc
etrier - 40 ron buc
planetara stanga cu senzor abs - 120 ron
pompa servodirectie - 80 ron
tamburi cu rulmenti - 80 ron set
geamuri usi fata st - dr si triunghiuri cu tenta verde - 100 ron
pedalier - 80 ron
centuri fata ,spate - 50 ron set
levier frana de mana - 15 ron
pompa frana + modulator abs + senzori abs si conducte - 150 ron
suflanta - 30 ron
mocheta interior pe negru sau gri (impecabila) - 80 ron buc
set bandouri originale - 50 ron
bancheta - 50 ron
mannuadi 19-06-12 21:04
bobina e3 - 200 ron
bobina e2 - 80 ron
iac - 40 ron
tps - 35 ron
pedalier - 80 ron
suflanta - 30 ron
bancheta - 50 ron
Pentru mai multe detalii pm sau 0762285498.[/QUOTE]
ionutp 22-06-12 13:44
salut
capota si aripa fata dreapta de culoare albastra aveti??
mannuadi 28-06-12 09:18
bobina e3 - 200 ron
bobina e2 - 50 ron
ecu motor e2 - 100 ron
electromotor - 100 ron
set fise bujii e2 - 30 ron
iac - 40 ron
tps - 35 ron
pedalier - 80 ron
macarale geamuri - 40 ron set
centuri fata - 15 ron buc
levier schimbator cu cabluri - 70 ron
cablu frana de mana - 35 ron
suflanta - 30 ron
comutator avarii - 20 ron
comutator stergatoare fara temporizare - 20 ron
set bandouri originale - 40 ron
scaune matiz - 35 ron buc
bancheta - 40 ron
stop frana luneta - 35 ron
Alias829 29-07-12 20:03
Salut! Polita haion luneta, carlig remorcare si buton reglaj faruri este? :D
