re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
VAND:
-Polizor trifazic(380V) dublu PD 500-----450ron -Dulap metalic tip fiset-----------------250ron -Dulap metalic 2 usi--------------------400ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Reductor presiune acetilena------------------------------------100ron -Reductor presiune oxigen---------------------------------------100ron -Trusa pentru sudura oxiacetilenica------------------------------350ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------120ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Presa profesionala pivot-capete de bara((copie Draper)------------90ron -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur -Set Biti Mecanici(Mechanics Bit Set)40 pieceStock no.21932-------49 Eur. Total: 102 Eur. Toate sculele sunt noi la cutie. Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--170 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
Up....
Nu mai este de actualitate:
-Set Biti Mecanici(Mechanics Bit Set)40 pieceStock no.21932-------49 Eur. |
VAND:
-Polizor trifazic(380V) dublu PD 500-----450ron -Dulap metalic tip fiset-----------------250ron -Dulap metalic 2 usi--------------------400ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Reductor presiune acetilena------------------------------------100ron -Reductor presiune oxigen---------------------------------------100ron -Trusa pentru sudura oxiacetilenica------------------------------350ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------120ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Presa profesionala pivot-capete de bara((copie Draper)------------90ron -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--170 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
VAND:
Up....
Up....
Up....
Aveti presa pentru pistonul de frana spate la golf IV? Daca aveti Va rog si pretul Locuiesc tot in Bucresti si ma pot deplasa la dumneavoastra eventual.
Nu am presa pentru piston frana spate Golf IV.Dar va puteti confectiona una in regie proprie.Materiale necesare:o placuta veche de frana,o piulita,un surub,aparat sudura arc electric.
Multumesc frumos pentru raspuns. In mare este suficient ce mi-ati spus, insa pistonul de frana la rotile din spate trebuie concomitent rasucit si impins. Mai mi-ar trebui un disc de 35 mm diametru, care sa aibe 2 stifturi, care se imbina in orificiile pistonului, atunci cand rasucesc si imping.
Re: VAND STRUNG PROF.,COMPRESOR IND.,SCULE AUTO PROFESIONALE,,DRAPER''ANGLIA
VAND: -Polizor trifazic(380V) dublu PD 500-----450ron -Dulap metalic tip fiset-----------------250ron -Dulap metalic 2 usi--------------------400ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Reductor presiune acetilena------------------------------------100ron -Reductor presiune oxigen---------------------------------------100ron -Trusa pentru sudura oxiacetilenica------------------------------350ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------120ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Presa profesionala pivot-capete de bara((copie Draper)------------90ron -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--170 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
19 Attachment(s)
VAND: -Polizor trifazic(380V) dublu PD 500-----450ron -Dulap metalic tip fiset-----------------250ron -Dulap metalic 2 usi--------------------400ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Reductor presiune acetilena------------------------------------100ron -Reductor presiune oxigen---------------------------------------100ron -Trusa pentru sudura oxiacetilenica------------------------------350ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------120ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Presa profesionala pivot-capete de bara((copie Draper)------------90ron -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
Up....
Up....
Up....
Up....
Up....
Up....
Up....
Up....
Up....
Up....
Up....
Up....
Up....
-Dulap metalic tip fiset-----------------250ron -Dulap metalic 2 usi--------------------400ron -Masina gaurit cu coloana(380V)-------1400ron -Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron -Element filtru ulei avion(inoxidabil)---------------------------40ron -Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron -Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron -Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22) -Placute Widia--------------------------------------------------5ron/buc -Reductor presiune acetilena------------------------------------100ron -Reductor presiune oxigen---------------------------------------100ron -Trusa pentru sudura oxiacetilenica------------------------------350ron -Pompa picior(1cilindru)------------------------------------------12ron -Pompa picior(2cilindrii)-------------------------------------------22ron -Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------120ron -Manometru presiune0-250atm.--------------------------------------10ron -Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc -Cutite strung widia10x10----------------------------------------5ron/buc -Stativ magnetic ceas comparator--------------------------------120ron SCULE PROFESIONALE DRAPER-ANGLIA -Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur Legenda: Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009 -Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. -Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron. Telef.0722.121.520 |
Up....
o poza cu dulapul la 250 lei ?
Aveti PM.
Up....
Up....
Up....
Up....
Up....
Up....
Up....
Up....
| All times are GMT +2. The time now is 03:09. |
