Re: ROVER tuning
super smecher cel dp 400
Re: ROVER tuning
tipu' la ala negru sunt puse barbitze ?.....la ce pret le ai?..ID MESS e highman2u
Re: ROVER tuning
sal...are cineva poze cu vreun rover 600 facut??
Re: ROVER tuning
Hi guys
Here is a Picture of my freinds 1.8 vvc turbo with pg1 http://www.discountdiagnostics.co.uk/me23424.jpg i will look for engine shots later :twisted: engine is from a 1.8 turbo zt with mgzr 160 vvc head and 1mm decomp plate , 12psi boost with rover 200 brm gearbox type2 lsd and k3 ecu. |
Salut, vad ca tu ai cea mai tare masina dintre noi...., spune-mi te rog dc stii ceva despre un chit turbo pt zr 160, dc as putea gasii undeva , dc se merita, si dc se poate monta asa ceva
merci mult de tot aaaa si inca ceva caut o pompa de frana pt el....sau garnituri...am inteles....problema este ca tin frana dar "tine jos" inca o data merci, si dc ai cumva cd-ul despre care se vorbea....cu [email protected] aaaaaaaaaaa era pt alex mg zr 160...... |
Re: ROVER tuning
https://forum.4tuning.ro/430-masina-mea-rover-mg/89223-rover-200-25-mandria-mea.html a facut george in romania asa ceva a doua varianta si cea mai scumpa e din motorul de 1.8 16v vvc sa schimbi chiloasa cu una de 1.8 16v 120 cp si calculatorul si incepi sa-l faci pe ala turbo si tot cam acolo ajungi 300 cp cu un cost ceva mai mare. in prima varianta de poate omologa motorul avand avelasi nr de cp si mai ales ca modelele de ZR pana in 2002 au avut euro 2 deci e cea mai simpla varianta. |
Re: ROVER tuning
Hello
Rover / mg make a 1.8 turbo from standard , you can pick full engine up for £500 with turbo and manifold , that is easist option , just use the k series turbo bottom end and turbo with vvc head , you can do it in a day . |
Re: ROVER tuning
merci merci, spune-mi te rog dc stii de unde pot lua o pompa de frana pt zr 160, sau garnituri....merciiiiiiiiiiiiiii
Re: ROVER tuning
Hallo
Yes i tune standard ecu with tool from http://www.doityourselfdiagnostics.c...d&productId=33 Kind Regards |
ROVER
Am fost si eu la Bavaria in Cluj dar nu ma mai duc nici moarta acolo. Sunt groaznici.....Ma interesau niste bucsi antirului....ca de la piese auto mi+au zis ca numai in reprezentanta le gasesc.....In fine.....poate ma ajutati voi.....unde as putea gasi bucsi antirului pt un Rover 200 din '99, motor 1.4, 16valve, 76 kwh? aaaa...era sa uit...si un parbriz, ca mi-a facut un camion cadou o pietricica. Mersi mult.
Re: ROVER
Click pentru parbriz Piese de tot felul pe eBay sau la unul din comerciantii din insula. Daca ai codurile poti face o intrebare si la Ciclop. Sarbatori Fericite tuturor ! |
Re: ROVER tuning
credeti ca 416 nu se poate tuna? abia de o luna miam luam si eu prima masina, un 416 si.. 1500 euro, lovita putin aripa stanga, fara semnalizare laterala stanga, 55000 km, condusa doar in italia, de vreo 8 ani a stat pe tusa..are toate dotarile, in afara de abs..cateva zgarieturi nesemnificative.. am gasit ceva body kituri pe net..oare merge asta la a mea? sunt cam incepator in ale masinii..care e diferenta exterioara intre 400 si 416?! tre sa ma pun sa le invat, sa nu dau banii pe ceva prostii http://www.spoilere.ro/ro/product/1252 |
Re: ROVER tuning
Re: ROVER tuning
Re: ROVER tuning
sorry, nu stiu cine e Sese. stii cumva vreo firma ce se ocupa cu asa ceva, prin transilvania? |
| All times are GMT +2. The time now is 16:52. |
