Re: Viteza maximă indicată pe bord cu Audi
Audi developed a sports version of the coupe in 1990, called the Audi S2. This featured the well proven 2.2 litre in-line five cylinder 20-valve turbo petrol engine from the Audi 200 20V, which was derived from that used in the Audi Quattro. A similar version of the engine was used in the Audi 100 based S4 (the 'Ur-S4'). The S2 came as standard with quattro permanent four wheel drive, and featured a heavy-duty 5-speed manual transmission. The S2 was initially available with a 2.2L turbocharged engine which produced 220 PS (162 kW; 217 bhp) (Engine code: 3B), coupled to a 5-speed transmission. In 1992, the engine received minor upgrades, including distributor-less ignition, which increased power output to 230 PS (169 kW; 227 bhp) (Engine code: ABY) which was coupled to a new 6-speed gearbox. Although the power increase was minimal, the engine now produced 350Nm of torque (up from 309Nm) and featured an overboost function that allowed up to 380Nm in short bursts. The 3B-engined car will accelerate from 0-100 km/h (62.1 mph) in 5.7seconds, continuing to a top speed of 246 km/h (152.9 mph). The ABY-engined coupe will accelerate from 0-100 km/h (62.1 mph) in 5.9seconds, continuing to a top speed of 246 km/h (152.9 mph). In 1993, the S2 received some cosmetic updates, including new AVUS style alloy wheels, elipsoid beam headlamps and clear front indicator lenses. This coincided with the introduction of the five-door S2 Avant, along with a limited run of four-door S2 saloon/sedan models, of which 306 were produced. The S2 saloon and Avant are actually based on the next generation B4 platform, and feature a lot of similarities in the rear axle support system to the later B5 A4 quattro. The B4 platform S2 Avant was also used between 1993 and 1995 as the basis for Audi's RS2 Avant super-sports estate, which was modified for Audi with assistance from Porsche. 1) din cate am citit are 227 bhp , viteza maxima e de 246 km/h ! 2) din cate ai spus tu are pe usor 400 bhp , si prinde 300 km/h ! Cum ? nu am inteles eu ceva ? nu e S2/RS2 ? |
Este o chestie care se vehiculeaza pe forumul asta.
Se numeste "tuning". Motorul ala e foarte potent stock doar cu modificari din electronica. Ti-am zis de s2/rs2 ca folosesc acelasi motor ca sa iti fie mai usor sa cauti pe youtube. Acum ne-am inteles? |
250 km/h, A4 , 2,4l ,fabricatie 2000 , nemodificata .La 220km/h in treapta a 4 a imi taie gazul.
Audi A6 2009 3.0tdi 234cai....250km/h limitat
audi a4 b7 avant 2.0 tdi BLB
jante 16 - 220km/h in blana jante18 - 210km/h in blana |
s2-cod motor 3b sau aby(putin peste 200 cp si aprox 330 nm) rs2 cod motor adu.(putin peste 300 cp si aprox 400nm) Diferenta intre cele 2 motorizari(adu si aby):turbo,galerie evacuare,galerie admisie,intercooler,injectoare si bineinteles softul. Motorizarea 3b are inclusiv aprinderea diferita. Mai exista codul motor aan(audi s4,s6) Peste 400 cp fara a schimba nimic la motor(doar din soft) poate ajunge adu(rs2) Ca si top speed,cu treapta 6(sau 5 in functie de cv)si limitare de viteza inclusiv turatie anulata ajunge undeva la 300km/h pe la 7500 rpm.Sau se face upgrade la transmisie. Numa'bine |
Iti multumesc ca ne-ai luminat. :)
Era evident chiar din postul la care ai dat quote de ce i-am spus omului ca s2/rs2 au acelasi motor.Ca sa poata cauta mai usor pe youtube. Oricum la baza e acelasi 2.2 t in 5 cilindri. |
deci.
bluey stie cate ceva despre cinci pistoane, dar nu stie toate chichitele si codurile, asta e , nu poti sa le stii pe toate @passbogdan. 200 fwd si awd mc1/2 165 cp 200 turbo quattro kg 182 cp s2,200 20v 3b,aby 220cp s4/s6 aan 230 cp rs2 adu 314 cp. |
a3 1.8t AGU 1997 la baza 150cp
aproape 260km/h pana a crapat arborele si cutia de viteze cu urm modificari: gt28rs injectoare 440 pompa benzina audi s6-2001 ambreiaj sport spec 2 kit admisie directa k&n intercooler custom evacuare custom 76mm bujii reci beru roti 205/45/17 soft upsolute |
Audi A6 - 2,5l, quattro
170 in a 5a ca mai mult nu am avut curaj... nu am fost niciodata si nu voi fii vitezomana... :eyebrow: pentru mine oricum ajunge... trebuie neaparat sa dau pedala si in a 6a treapta sa vad ce poate sau am dreptul sa ma laud si cu 170?... :workout: |
Audi A6 3.0 TDI V6 224 cp maxim pe bord atins personal la intoarcere din Germania catre Romania 255 - cu bataie 257 km/ora hmmmmmm foarte frumos. nu cred ca se putea mai mult dar daca.........as fi vrut 300 km /ora si punct. :D
210 cu audi a4b5 1.9 tdi 90 cai + cip... e limitat la 210 zic eu, pt ca am 4500 turatii la 210km/h nu trece nicicum peste, in treptele 1,2,3,4 trece de 5000. se poate scoate limitarea? multumesc!
nu este limitat, nu are motorul putere sa urce mai sus iti mai trebuie cp!
Oricum real cu 90 cai nu ai mai mult de 190 pe bord si asta cu indulgenta
| All times are GMT +2. The time now is 10:59. |
