-   Opel tuning (https://forum.4tuning.ro/136-opel-tuning.html)
-   -   Opel Tuning : BERTONE TURBO EXTREME (https://forum.4tuning.ro/136-opel-tuning/3827-opel-tuning-bertone-turbo-extreme.html)
[T3m]b3|| 09-03-05 14:40
Oricum...la Borla tziar face la min 300E...yo 1 zic k merita satzi aduci ceva dafara ;)
dandan 09-03-05 16:30
Re: BERTONE TURBO EXTREME
Originally Posted by \"bertone turbo\"
VA POT PERZENTA O MASINA CARE CREDETIMA NU SE GASESC PIESE DE TUNING ASA CAT AI BATE DIN PALME ADICA ACU 4 ANI NICI UN TUNER GERMAN NU AVEA IN OFERTA OPEL ASTRA TURBO.
CU SACRIFIICI MARI TIMP SI MULTI PRIETENI AM REUSIT SA INVAT CE INSEAMNA PREPARAREA UNUI MOTOR.
POT SPUNE CA PANA IN MOMENTUL DE FATA MASINA A TRECUT PRIN MAI MULTE STAGII DE PREPARARE NU A AJUNS LA FINAL CEI DREPT.
AM INCEPUT CU A COBORA GARDA LA SOL CUM NU AM AVUT UN SUPORT DE LA TUNERII CONSACRATI CE CREDETI CA AM FACUT? AM COBORATO PRIN PROCESUL NUMIT SPRINGUIRE A ARCURILOR,SI SCURTAREA A AMORTIZOARELOR.
APOI AM INCERCAT SA MARESC PUTEREA MOTORULUI PRIN A ELIMINA CATALIZATOARELE SI TOBA FINALA,IN CONTINUARE TREBUIA MARITA PRESIUNEA DIN TURBO,DE BENZINA .................................................. AM AVUT UN ZID DE TRECUT PROTECTIA MOTORULUI DIN ECU............................................... ..................AM AJUNS LA UN STAGIU FOARTE RIDICAT DACA VRETI VA MAI POT POVESTII UNDE AM AJUNS SEBASTIAN STIE CAT M-AM CHINUIT
PANA SA CALEZ MOTORUL NU AM FACUT MARI MODIFICARI MECANICE,ADICA AM INCOCUIT TOT TRASEUL DE ADMISIE CARE ERA DIN CAUCIUC SI INTERCOOLERUL CU UNUL DIN ALUMINIU TRASEUL L-AM FACUT TOT DIN ALUMINIU (TABLA ROLUITA SUDATA )NEAVAND DE UNDE SA IAU TEAVA,LA PARTEA ELECTRONICA AM FACUT UNELE COMPROMISURI(MINCIUNI) ADICA AM MINTIT SISTEMUL CA SA IMI PERMITA SA MARESC PRESIUNILE DIN TURBO SI BENZINA.MAI EXPLICIT ECU DE TURBO ARE UN MAP SENZOR, LA APROAPE TOATE MASINILE ACESTA LUCREAZA PE PRESIUNEA DE AER CA UN MANOMETRU LA MINE ESTE CA UN DEBITMETRU. CA SA FAC MODIFICAREA CA ECU SA NUMAI INTRE IN PROTECTIE LA PRESIUNI SUPERIOARE TE LUCRU A TURBINEI AM PUS O DIODA TENER PE MUFA DE PE MAP NE LASAND ASFEL SA TREACA O VALOARE MAI MARE SPRE ECU ACESTA NU SESIZEAZA PRESIUNA MARE DIN TURBO SI ASTFEL AM PUTUT RULA CU 1.5BARI IN TURBO AVAND NEVOIE SI DE BENZINA AM PUS O REZISTENTA PE SENZORUL DE TEMP A APEI CREEIND ILUZIA CA MOTORUL ESTE RECE FACANDUSE UN REGLAJ AUTOMAT AL ECU. CA SA MEARGA AM INTRERUPT CIRCUITELE MODIFICATE SI DE LA OVERBOOST SI LE-AM PUS PE BUTON.FUNCTIONA ASA,OPREAM MOTORUL ACTIONAM BUTONUL SI PORNEAM ASA AVEAM MODIFICARILE IN STARE DE FUNCTIONARE.TOATE ACESTEA AU FOST POSIBILE CU AJUTORUL LU GABI DE LA OPEL DI-BAS CARE ESTE PROFESOR PE ELECTRONICA.
dandan 09-03-05 16:32
mondeo
stii unde pot sa fac un motor de mondeo 2001 de 1,8L 110cp mai puternic?
SEBASTIAN 10-03-05 06:55
Re: mondeo
de ce suma dispui ca sa-l modifici?
bertone turbo 10-03-05 08:24
Re: mondeo
CE VREI SA ITI FAC LA MASINA?
SAS SANT SERPII
bertone turbo 11-03-05 08:59
Re:
Originally Posted by \"Cortez\"
Frate bertone am si io nevoie de serpi ptr un c18xe, as vrea detalii , cine cum unde cat costa!multumesc!
vino la garaj sii vorbim
Cortez 12-03-05 13:45
pai frate nu pot veni la garaj ptr. ca sunt de la iasi!
probabil o sa vb pe 27 la bucuresti!
dandan 12-03-05 15:36
Re: mondeo
SAS SANT SERPII
cati cai extra va scoate masina dupa modificare?.....si cum calculezi caii ?
All the best and f..k the rest
SEBASTIAN 19-05-05 22:34
L E G A L R A C I N G
Pentru prieteni pot acum sa ofer test pe stand de putere la 1200000lei doua teste unul acum si altul dupa modificari la interval de o luna.
dandan 23-05-05 13:57
Re: L E G A L R A C I N G
am mai zis dar a fost sters.......asa ca zic din nou....
cum adica pt prieteni?
si daca nu suntem prietenii tai,cat costa?
eu stiu ca daca-i lege,este pt toata lumea.
uite...eu renunt la o \"doza\" si-ti dau 1200000 ,doar sa modifici ce-ai scris mai sus si sa faci aceiasi oferta pt toata lumea.
omuliber 23-05-05 16:30
Cu modificarile facute masina deja intra la categoria superioara(250CP)... asta daca se respecta ce spuneati alta data.
P.S. Ce cuplu ai si in ce ture? Si ce faci cu tractiunea fata?
bertone turbo 24-05-05 09:33
Re:
cuplu pe la vreo 400-450
omuliber 24-05-05 10:44
Ai evo310?
bertone turbo 24-05-05 19:24
Re:
Ai evo310?
nu evo 360
blowwind 24-05-05 19:24
poze ceva ?? :)
omuliber 25-05-05 09:28
Ce-ai in loc de K04, ti-au pus Garrett sau K26?
bertone turbo 27-05-05 08:51
Re:
NU.........................IHI
omuliber 27-05-05 14:05
Hai mah, zi-i! K24, ce-ai pus?
SEBASTIAN 31-05-05 16:01
Au au ce masina o sa fie astra turbo.
Inca o grupa la care nu mai poti paria.
omuliber 31-05-05 22:32
Dimportiva, la grupa \"E\" e destul loc de pariat...
SEBASTIAN 31-05-05 23:04
Poate dar pentru putin timp.
Am vazut Atra asta mergand si cand nu mergea.
La pana in 200cp cam greu sa-i sufle cineva, dar pista e deschisa pt multi si oricie-si poate demonstra superioritatea.
Pariez pe BETONELU!
omuliber 01-06-05 10:16
Ce sa caute la pana in 200CP????
Are turbina schimbata, deja intra in categoria urmatoare \"E\"...!!!
Sau regulile se schimba pe baza altor criterii?
Razvan P 01-06-05 12:16
daca masina a avut turbo de serie ( si bertone a avut sigur ) clasa ramane neschimbata....logic de altfel ( se incurajeaza tuningul )
zetemte 02-06-05 00:25
Re:
Si Nitro nu e tuning ... pentru ca daca pui nitro atunci sari 2 grupe sus.
Acelasi lucru daca pui turbina pe motor aspirat ... sari o grupa sus.
Si daca pui turbina 10x ori mai mare, dar ai avut inainte turbina pe masina, ramai in grupa acelasi ...
Asta nu e logic ... dar asta e.
SEBASTIAN 02-06-05 06:14
regulament
Unde-i lege nu-i tocmeala.
Razvan P 02-06-05 15:43
Exemplu scurt si la obiect :
Opel astra turbo 2.0T ....serie 7.5 suta si putin peste 15 sec 0-400 m
...daca ii schimbi turbina scoti o sec mai putin (ex teoretic) ...si treci la grupa imprezelor care pleaca de la 5.3 sec pana la suta ?!?!!?!?nu mi se pare normal , mi se pare de bun simt sa raman la grupa la care sunt
pe de alta parte nu e normala nici situatia ta (corolla cu 110 cai )care cu shot de nitro de 35 cai urci teoretic la grupa lui Bertone ?!?!?!? ...dar in fine
SEBASTIAN 02-06-05 16:02
regulament/legea noastra
Fiecare are dreptul la propia opinie.
Noi in calitate de organizatori trebuie sa tinem cont de REGULAMENT si sa-l apliccam cat mai strict.
Intocmirea regulamentului s-a facu prin consultarea diverselor persoane participante si nu in ultimul rand a federatiei auto de la acel moment.
Deoamdata regulametul ramane in picioare si vrem ca toti cei care fac modificari sa le face cu randament maxim altfel in ce priveste competitia au chiar mai mult de pierdut.
SEBASTIAN 17-07-05 15:14
nimic nou?
bertone turbo 20-11-05 14:38
Re: regulament/legea noastra
VINE UFO DIN GARAJ
PARTIE CA VA STROPESTE CU SMECHERIE
Afr!c@nu' 20-01-06 15:12
UFO
Ce sa intamplat cu bertonele asta?....dc e inca in service?...s-a schimbat proprietaru?...masina e inca la dibas...e albastra acum...cu folie de carbon pe capota,plafon si portbagaj...e tare rau...are radiatoru turbo de subaru...da cand intra la curse?
Vladz 21-01-06 13:26
Cand e gata ?
Afr!c@nu' 09-02-06 12:17
Bai bertone turbo...nu mai zici nimik?...Ce s-a intamplat cu masina?...Acum nu mai e la dibas.Au ramas acolo doar spilerele(la vopsit).
Corbu` 10-02-06 16:02
shi io's curios......
cosmin-tuning 05-03-06 20:11
sal all.acum cateva zile am vazut acest bertone (ufo) si arata demential parerea mea.vopsita in doua culori si un set de spoilare in careva cuvinte masina arata super bine.cred ca e cel mai belea bertone pe care l-am vazut prin buc .sper ca proprietarul sa puna niste poze ca sa il vedeti toti.felicitari proprietarului.
dany_let 06-03-06 13:38
sa-l vedem ....
MC Mate 06-03-06 14:16
poate intra bertone turbo si pune si el niste poze recent sau filme cu masinuta
dany_let 07-03-06 08:56
eu nu cred ca intra....
MC Mate 09-03-06 00:46
Poate intra Sebastian pe aici si il anunta el, k am impresia ca se cunosc destul de bine
bertone turbo 12-03-06 12:20
7 Attachment(s)
Scuze Ca Nu Am Postat Mai Devreme Dar Nu Mai Am Avut Net
MC Mate 12-03-06 12:54
Arata super marfa.Pacat ca nu ai niste poze in clare in care sa fie curata.Arata marfa.Sa ai grija de masinuta si sa o vedem alergand.
