Re: Statii Radio la preturi mici !!!
Valabil ... !
valabil
Valabil ... !!!
Valabil ... !!!
Valabil !!!
U p !!!
Valabil !
0733232321 ! |
Antena Avanti Forza la super pret !
Valabil !
U p !!!
0733232321 - Cristian !
Valabil - 0733232321 !!!
In Piatra Neamt asiguram montajul si calibratul antenei !!!
Cea mai exclusivista statie de pe piata comunicatiilor CB.
Cea mai avansata statie destinata autoturismelor. Model 2011. Caracteristici: ASQ,CTCSS,DCS,DTMF,SCAN,DW,EMG,TSQ,NB/ANL,HI-CUT,8 ROAGER BEEP-uri 7 CULORI ALE DISPLAY-ULUI,EXPANDOR PE RECEPTIE,COMPRESOR PE EMISIE PROGRAMAREA TIMPULUI DE EMISIE,MULTISTANDARD CANALE 40/80 MOD DE LUCRU AM/FM FRECVENTA 26.565-27045 MHz ALIMENTARE 12V DIMENSIUNI 139*37*184 mm GREUTATE 850g PUTERE 20W CONSUM 1.5A max. Sensibilitate squelch -119 dBm minim -27dBm maxim Distorsiune 1.5% SENSIBILITATE MIKE 10mV MICROFON MULTIFUNCTII 6 PIN Pret : 650Ron !! |
Amplificator statii emisie receptie KL 203 P - 295 Ron
Descriere Produs Detalii tehnice Frequency 20-30 MHz Supply 12-14 Vcc Input energy/power 10 A Input power 0.5-10 W Input power SSB 1-20 W Output power 100 W Max Output power SSB 200 W PEP Max Mode AM-FM-SSB-CW Fuse 12 A Output power level 1 Size 109X125X35 mm Weight 325 gr. Antenna preamplifier 26 dB Electronic switch Inversion polarity protection |
In curand Storm Turbo Explorer cu ASQ , afisaj cu 7 culori , ecou si functia VOX !!!
Valabil !
0733232321 - Cristian ! |
PROMOTIE !!!
Statie emisie receptie Megawatt PRO1000 + antena ML145 Megawatt - 325Ron Caracteristici : ***CEA MAI CALITATIVA STATIE CB LOW COST 4W AM/FM , ASQ , SCANARE Caracteristici generale Producator MEGAWATT Descriere produs STATIE CB CU ASQ Putere de iesire: 4W Numar de canale: 40 Frecventa (MHz) 26.965 - 27.405 Tensiunea de alimentare: 12.6 V Receptor: Sistemul de receptie: conversie duala superheterodina Frecventa intermediara: 10.695MHz - 455 MHz Sensibilitatea > 1΅V per 20dB SINAD Puterea de scoatere audio @10% THD 2.0 W @ 8 Ohm Distorsiunea audio: < 8% @ 1 KHz Rejectia imaginii 65 dB Rejectia canalului adiacent: 65 dB Rata semnalului/ zgomot: 45 dB Consum in standby 250mA Transmitator: Putere: 4W FM Modulatie AM / FM Toleranta in Frecventa: 0.005 % Selectivitate: > 60dB Raspuns in Frecventa: 400Hz / 2400 KHz Impendanta Antena: 50 Ohmi Puterea de iesire ciclu 10% 4W@ 13.8V DC Modulatia AM: de la 85% la 95% FM: 1,8 KHz ± 0,2 KHz Raspunsul in frecventa: de la 400 Hz la 2.5 KHz Impedanta de iesire RF 50 Ohm neechilibrat Raport semnal/ zgomot: 40 dB MIN Dimensiuni (W x D x H mm): 160x 120 x 45 Informatii suplimentare: Controlul de Frecventa: PLL Display Multicolor Posibilitate memorare 2 canale Gama temperaturilor de functionare, de la -10°C la +55°C Curent consumat: 1000mA (fara modulatie) Curent consumat: 60mA in stand-by ***Antena pentru statie radio CB (in banda libera) - distanta de lucru 10 -15 Km. Kitul contine o antena Megawatt ML145 si o baza magnetica 120/PL. Banda de frecventa: 26-30 MHz Numar de canale: 90 canale Puterea maxima aplicata(W): 400 SWR minim in centrul benzii: 1.1 Castig: 1.3 dB Lungime(mm): 1600 Impedanta(Ohm): 52 Greutate(g): 350 Material: Otel Cablu: 3 m de la baza magnetica |
Statie portabila Storm Turbo Extreme ASQ - putere reglabila - 670Ron
Functii : *Asq Autosquelch permite cautarea automata a frecventei optime ... ... *RB Roger Beep emite un beep la intreruperea emisiei *Ecou - Se poate regal ecoul emisiei *7culori aveti posibilitatea de a schimba culoarea ecranului * VOX - Cand acest mod este selectat radioul va transmite automat atunci cand microfonul detecteaza vocea dvs. (sau alte zgomote) Pachet cu toate accesoriile incluse Contine: Kit pentru instalare auto : cablu antena externa si alimentare bricheta Suport pentru 9 acumulatori nu sunt inclusi Incarcator pentru acumulatori la 220 volti Incarcator pentru acumulatori la 12 volti Antena flexibila de 20 cm Suport prindere auto Detalii statie: Buton volum Reglaj Squelch manual SI AUTO Mufa difuzor extern Mufa microfon extern Buton ON/OFF Comutator Low power output de la 10 watt la 4 watt Buton Dual Watch Memorare canale Tasta Scanare canale LGT - iluminare ecran LCD CH9/CH19 - canale urgenta Display LCD multifunctii Difuzor incorporat Microfon incorporat |
http://www.redzonetuning.ro/category...isie-receptie/
Super preturi la statii emisie receptie / Garantie 48 luni / Calitate exceptionala !!! 0733232321 - RedZoneTuning |
Statie Radio CB Avanti Kappa 4-60 W
Statie radio CB Avanti Kappa 60W Noul model Avanti Kappa este cea mai puternica statie radio CB pentru autoturisme, cat si cea mai mica statie cu putere marita - max. 60W, in conditiile in care o statie de 60W in acest moment are dimensiunile de cel putin 3-4 ori mai mari, neputand fi instalata intr-un autoturism,Puterea reglabila permite utilizarea acesteia in orice stat european. Ca si noutati notabile ar fi posibilitatea de conectare la calculator pentru personalizarea setarilor preferate, putere reglabila max. 60W, ecou, 8 Roger-Beep-uri programabile, TOT, codare CTCSS & DCS, momorii etc. AVANTI KAPPA 2 - 3 TREPTE DE PUTERE = 4/15/60W - ECOU,8 tipuri de roager beep - NB(filtru interferente),DW(urmareste 2 canale) - ASQ(squelch automat),240 canale Specificatii tehnice: - Gama de frecvente: 25,615 / 27,405 - Impedanta antenei: 50 Ohm - Temperatura: -20 / 60 grade - Alimentare:max. 15V - Curent max.: 11A - Modulatie AM : 90% - Deviatie: +/- 2KHz - Sensibilitate: 0.5uv(FM) - Squelch: 05.uv / 1000uv - Difuzor:3W 8ohm - Distorsionare: 5% - Zgomot: 45dB - Dimensiuni L / l / I :158 / 138 / 48mm - Greutate: 833g 5 ANI GARANTIE !!! Pret : 800Ron |
la ce pret ajunge Statie radio TTi TCB 880H si Antena CB auto Sirio Megawatt 4000 PL
ms:-) |
