-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   Amp. 5ch Audison, Special Edition, Chrom Shadow (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/71249-amp-5ch-audison-special-edition-chrom-shadow.html)
AlexBanu 15-04-08 20:57
Re: Amp. 5ch Audison, Special Edition, Chrom Shadow
Mai multe detalii aici http://ampguts.realmofexcursion.com/Audison_LR_605XR/
bezz 20-04-08 22:05
il poti compara cu un lrx 5.600 ? :D merci
Rafaila 21-04-08 20:14
Putere RMS: 50W x 4 (4 Ohm) + 290W Sub (2 Ohms)
Aceasta este singura configuratie posibila???
bezz 21-04-08 21:48
dap
POWER SUPPLY 11 ÷ 15 VDC
IDLING CURRENT 1.8 A
MAX COMSUMPTION (Nominal Pwr) 60 A
MAX DYNAMIC POWER (5 ch x 4 Ohms) 60 W x 4 + 250 W
CONT. NOMINAL POWER (Tol. +10%; -5 %) VDC
5 ch x 4 Ohms; 0.3 % THD; 12 VDC 40 W x 4 (RMS) + 150 W (RMS)
CONT. OUT POWER (5 ch x 4 Ohms; 13.8 VDC) 50 W x 4 (RMS) + 200 W (RMS)
CONT. OUT POWER (4 ch x 4 Ohms; 1 ch x 2 Ohms; 13.8 VDC) 50 W x 4 (RMS) + 290 W (RMS)
DISTORTION THD (1 KHz; 90 % Nominal Pwr) 0.05 %
BANDWIDTH (-3 dB; Nominal Pwr) 4 Hz ÷ 70 KHz
CROSSOVER FREQUENCY
LO-PASS SUBWOOFER 50 Hz ÷ 150 Hz
HI-PASS FRONT 50 Hz ÷ 150 Hz
LO/HI-PASS FRONT 150 Hz ÷ 850 Hz
HI-PASS REAR 50 Hz ÷ 150 Hz
FILTERS SLOPE 12 dB/Oct. (24 dB/Oct. Subwoofer)
DAMPING FACTOR (4 Ohms) 100
RISE TIME 2.5 μS
SIGNAL / NOISE RATIO (1 VRMS input) 103 dBA
INPUT SENSITIVITY 0.3 V ÷ 4 VRMS
INPUT IMPEDANCE 15 KOhms
LOAD IMPEDANCE 8 - 4 - 2 Ohms
REMOTE IN - OUT 7 ÷ 15 VDC
DIMENSIONS (BxHxL) 175 x 50 x 475 mm (6.88 x 1.96 x 18.70 inch)
m-a pus si pe mine pe ganduri ca nu merge pe 2 ohm decat pe iesirea de sub
dj81bas 21-04-08 22:46
pai si care ar fi problema daca nu ar merge in 2ohm decat pe sub?....mi se pare un amplif ideal pt un sistem cu doua cai full activ pe fata si un sub.
O putere decenta pt un sistem de calitate. pt cine vrea spl.....nu are ce sa faca cu acest amplif.
Rafaila: pai si la ce ai avea nevoie de alta configuratie???
dj81bas 29-04-08 09:06
up.............
dj81bas 08-05-08 23:22
upppppppppp
dj81bas 20-05-08 23:10
uppppppppppp
dj81bas 24-05-08 11:56
pret promo .....180euro:D
dj81bas 17-06-08 01:57
vandut....se poate inchide acest thread.
