Re: Vtec Controller
Am Si Eu Un Crx Vtec Si Vreau Sa Intreb Ce As Putea Face Pe La Mecanica Sa Creasca Puterea?
Re: Vtec Controller
pai ...depinde de catzi bani ai shi catzi cai vrei ....daca ramane mashina de zi cu zi sau daca o tzi numai pt alergat!
Re: Vtec Controller
pt 2.0i cu 16 valve nu se gaseste un controler dasta ?? motor b20 a4
fara vtec |
Re: Vtec Controller
uite aici niste detalii despre el... Piggyback Fuel Computer Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD). The second-generation SAFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The SAFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The SAFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %. Si costa cam 250€...din cate mi-a spus un mecani nu prea renteaza sa dai banii pe el..mai bine iei un ECU daca tot dai banii si sti ca ai pace SPOON sau Hondata costa dar isi merita banii |
Re: Vtec Controller
Am intzeles ca nu merge pt orice Vtec ... m`am uitat la un vtec controller pe un site shi specifica ca nu merge pt Vtec-E de exemplu cum am yo shi pt mai multe feluri de vtec
Re: Vtec Controller
Azi am avut ocazia sa merg in stanga cu un NSX modificat de MUGEN(axe,evacuare,calculator,autoblocant...),masi na are vtec controller cu buton de max-min langa cele de dezaburire.Cu el dat la minim ma baga in scaun pur si simplu,cu el la maxim se ingusteaza strada in fata mea si ochii in chederul de la partbriz,nu am mai apucat sa vad decat in franare ca avea vreo 130.Nu face,nu merge...asa este, nu e bun,e perfect:D.Cea mai tare jucarie facuta de Honda.
ps: nu stim nici noi ce setari avea la minim sau maxim,asa a venit masina |
Re: Vtec Controller
Pai la maxim banuiesc ca intra de la ture joase Vtecu
Re: Vtec Controller
Re: Vtec Controller
Pai sa ne lamureasca cineva care shtie sigur!
Re: Vtec Controller
ce ziceam mai sus! cu compatibilitatea!
...RESET THE VTEC POWER WORKS TIMING LO-CAM TO HIGH CAM BY THE CONTROL SWITCH FROM 2000 RPM - 8000 RPM TO MAKE YOUR VTEC ENGINE THE BEST PERFORMANCE. EASY TO CONTROL AT NIGHT. EASY TO INSTALL, NO WILL NOT DAMAGE OR INTERFERENCE WITH THE CAR COMPUTER. VTEC ENGINE IS COMPATIBLE. WILL NOT WORK ON I-VTEC; VTEC-E; 3-STAGE VTEC ENGINE |
Re: Vtec Controller
Re: Vtec Controller
de exemplu...cum aflu ce tip de v tec am ?
motorul este D16y8 |
Re: Vtec Controller
D16Y8
• VTEC • Found in o 1997-1998 Honda Civic EX (Sedan Peruvian Version) o 1996-1998 Honda Civic EX (Coupe Peruvian Version) o 1996-2000 Honda Civic EX (USDM) o 1996-2000 Acura 1.6EL (Canada Only) o 1996-1997 Honda del Sol Si • Displacement : 1590 cm3 • Bore and Stroke : 75 mm X 90 mm • Compression : 9.6:1 Piston Code: • D16Y8 1.6 16V SOHC VTEC-II PGM-FI 1590 • Power 127 hp @ 6600 rpm • Torque 107 ft-lb @ 5500 rpm • Head Code : P2J |
Re: Vtec Controller
Stiu sigur ca VTEC Controller'ul merge pe toate motoarele cu VTEC mecanic... orice VTEC controlat electronic, cum este si cazul EP3'ului nu ii va surade aceasta solutie inginereasca ...
Kickass ar putea sa ne spuna mai multe pt ca are o asemenea jucarie Apexi montata pe masina si stiu ca vroia sa o dea jos (sau poate a facut-o deja) si sa o vanda ;) asa ca il puteti contacta... @Urban_Racing: te sfatuiesc dak vrei sa umblii la masina ta sa faci urmatoarele: pt soft fie apelezi la o solutie "profi", vezi Hondata, care o sa iti controleze si pragul de VTEC si limitarea de turatie eventual, fie poti incerca la noi la cei de la MasterTuner (s-au mai "jucat" si cu EP3'ul lui Tsentean si mai au cate ceva experienta la Honda). Afara, Unichipurile Dastek au ceva priza la Honde... acum ramane de vazut ce se intampla si la noi ;) si pt sunet si aparente racing mai intai scapa de finale, lasa tseava pana in tipsurile alea triunghiulare (sa le inlocuiesti e o solutie f costisitoare, iar fara finala kiar nu suna dramatic deloc, ci placut agresiv) |
Re: Vtec Controller
| All times are GMT +2. The time now is 08:57. |
