-   -   Poze spion: Ferrari 612 Scaglietti Facelift 4x4 (https://forum.4tuning.ro/18-masini-tunate/27419-poze-spion-ferrari-612-scaglietti-facelift-4x4.html)
TDR TNY 19-11-06 11:15
Re: Poze spion: Ferrari 612 Scaglietti Facelift 4x4
Originally Posted by B 68 VLD (Post 627096)
TDR TNY, in conceptia ta cum ar fi trebuit sa arata ca sa exprime marca? Oare de ce nu-si pune nimeni dintre voi care ati post-at aici problema cu Ferrari si 4x4. Eu unul nu am mai auzit de vreun Ferrari 4x4, voi? Va dati cu parerea ca este asa, ca este pe dincolo. Imi place sa cred ca cei care isi cumpara un Ferrari si-l cumpara pt performanta si abea dupa aia pt un alt motiv.
MARANELLO, Italy — Ferrari is ready to break with tradition by adding a four-wheel-drive system for ***ure sports cars, according to reports.
The Italian company has filed patent drawings for a part-time 4x4 system, which could be used on front-engined models such as the 612 Scaglietti and the forthcoming V12-powered 600, as well as Maserati's Quattroporte and Coupé. The setup also combines all-wheel drive and a transaxle layout for the first time in a Ferrari.
A patent drawing published by Autocar magazine shows that the new system is very compact and is simpler than rival 4x4 systems based on a rear-drive layout. A constant velocity joint and an oil-bath clutch — the clutch transmits power to the front wheels — are encased on the end of the engine block.
The system will not be an Audi quattro-style, full-time 4x4; instead, it will function like a traction control system, using sensors and computers to transmit drive to the front wheels if the car starts to slide while cornering. In higher gears, the system is limited to 20-to-30-second bursts of 4x4 traction to stop overheating.
What this means to you: Don't worry — it's not a Ferrari SUV, though that might happen as well, according to rumors from Italy. This is a road-safety aid that will enhance Ferrari's legendary handling.
Sursa: edmunds
in conceptia mea ......4x4 nu inseamna ca au scuza pt designul asta oribil....arata hidos....eu am zis ca e o masina urata ...tu te-ai trezit vorbind de cu totul si cu totul alt subiect........e forum....nu e taraba in piatza!:rolleyes2 :shock:
Nautilus 19-11-06 11:47
Asta nici macar nu e 4x4 adevarat, e cam acelasi lucru cu un Haldex, care functioneaza numai cand una din punti pierde aderenta, in restul timpului cari 100kg de metal inutil dupa tine :D
Ei au un motiv pentru care il monteaza totusi. In ultima vreme a devenit destul de nasol pentru toti producatorii auto sa infrunte concurenta, si daca nu poti reduce costurile asa cum fac coreenii si chinezii, trebuie sa vinzi mai mult - si nu toti cei care au bani de Ferrari sunt experti in pilotajul de strada, multi isi iau unul ca sa faca impresie doar, asa incat trebuie sa le furnizezi o masina care nu face surprize neplacute. E mai convenabil si pentru asigurator o masina care nu e "naravasa"
Ferrari-urile ideale au fost 365GTB/4, 288GTO, Testarossa/512TR/512M, seria 355/360/430... nici unul limuzina cu 2 usi pentru plimbat seara prin oras :p
~Nautilus
B 68 VLD 22-11-06 01:34
Nu faci nici 2 bani. Eu spun ceva tu intelegi altceva. Ca sa pricepi si tu ti-am zis ca tu de exemplu pui accentu pe design cand aceste masini sunt niste vitrine tehnologice. Vrei design dute la Alfa Romeo si admira-le. Se face un topic dupa care discutiile sunt urmatoarele: uau, ce tare, super frumoasa, mi-as lua si eu una etc etc. Abtineti-va daca nu aveti nimik de spus.
subaru driver 22-11-06 17:33
mi se pare mie sau este primul ferrari cu tractiune intergrala?:shock: nici nu se pune problema...o masina cum si-ar dori fiecare
morghen 22-11-06 19:55
ferrari mereu a facut mashini urate(cu unele exceptzii)...dar acum s-au intrecut pe ei inshishi. Cat despre 4x4...deh..rahat...japonezii ,koreenii shi europenii vand asha ceva de mult timp...falimentu ii manca pe ashtia cu cotetzu asta :)
parerea mea.
Race 23-11-06 14:33
Ferrari 4x4...ii mai trebuie un Diesel si gata !:???:
Descrierea metodei de functionare de aici zice asa:exista al doilea ambreiaj,care e conectat INAINTE de cutia de viteze la motor si apoi la roti,in ambele cazuri cu rapoarte de transmisie FIXE.Ceea ce inseamna ca la o turatie oarecare rotile din fata se invart cu aceeasi viteza indiferent ca masina e in treapta 1 sau 6.Acest mod inteligent de a praji ambreiajul respectiv ar explica partea cu "the system is limited to 20-to-30-second bursts of 4x4 traction to stop overheating",insa ar fi totodata si cea mai proasta idee pentru un sistem de tractiune integrala care sa intre in productie.Bineinteles,exista oricand posibilitatea ca site-ul respectiv sa scrie tampenii care n-au nici o legatura cu ce va face Ferrari.
Nautilus 24-11-06 14:53
Un ESP nu era mai eficient si mai putin costisitor? :)
~Nautilus
B 68 VLD 24-11-06 14:55
Poate era dar nu suna asa pompos ca un sistem 4x4. ;)
3SGE 26-11-06 08:32
Imi place ca voi criticati ferrari , dar nu va ganditi ca ei au ingineri si proiectanti care au studiat problema si puterea financiara necesara pt a baga in buzunar multe alte firme. N-aveti frica ca sau gandit ei deja la planul de viitor si nu datele tehnice spun totul. Este un ferrari totusi! Si nu poate fii comparat cu un amarat de bmw, honda sau stiu eu ce.
paulbijnitzaru 27-11-06 22:41
imi palce ferrari ... dar asta e ca pixu... adancitura aia ... si .. nici nu stiu cum sa explic ... dar esentialu` e ca ... nu`mi place
claudiu lucian 28-11-06 08:56
poate arata mai bne in realitate, poate cand o sa ii faca nishte poze klumkea o sa va schimbati parerea. acum snt spiuon si poate sunt facunte din nishte unghiuri care nu o avantajeaza.
strik3ru 28-11-06 21:20
deci arata destul de bine...in primu rand dak tinem cont k e un ferrari ...da totusi ferrari 4x4 poate copii nostri o sa conduca camioane ferrari..:)))) cine stie vom vedea
Duruselu 02-12-06 22:25
new wheels in da hood... un alt monstru scos de ferrari.. interesant.. 4x4....un tank pe 4 roti .. superb
tocatoru 04-12-06 12:28
parerea mea e ca Ferrari ramane si nimika din ce fac nu ii va duce la faliment,nu multzi pot avea un Ferrari egal cat de vechi in shimb un mertzan sau un bmw e cam plin asta spune tot
