Re: Piese E36
ms frumos
vanzare buna sa ai:) |
Re: Piese E36
Dezmembrez motor de pe 316i din 1996, 170.000 km
Preturi in RON, negociabile. Instalatie electrica(cutie, cabluri, mufe)-30; Relee-20 Sensor arbore-40; Senzor ax cu came-40; Senzor temperatura lichid racire-20; Senzor detonatie-30; Furtune vacuum-10; Lant distributie(3000km)-100; Patine-30; Tensionator lant(3000km!)-130; Evacuare finala-50; Corp/clapeta acceleratie-20; Ambreiaj-50; Termostat-30; Furtune radiator (2)-40; Injectoare (4)-60; Rampa injectie/regulator presiune-30; Debitmetru-120; Fise inductie-30 toate 4 Bloc motor, chiulasa, pistoane etc-300 ron Sau toate la 500 RON Tel 0741741186 |
Re: Piese E36
Se adauga toba finala 316i in stare buna-> 60 ron si o finala sport inox, care a fost pe un 318is (trebuie sudata mai bine la intrare si la tips) 60 ron
Re: Piese E36
Relee-20
Sensor arbore-30; Senzor ax cu came-30; Senzor temperatura lichid racire-30; Senzor detonatie-20; Furtune vacuum-10; Lant distributie-50; Patine-30; Evacuare finala-60; Corp/clapeta acceleratie-30; Termostat-30; Furtune radiator (2)-40; Injectoare (4)-60; Rampa injectie/regulator presiune-40; Fise inductie-40 toate 4 |
Re: Piese E36
Relee-20
Sensor arbore-30; Senzor temperatura lichid racire-30; Senzori detonatie-20; Furtune vacuum-10/buc; Lant distributie-50; Patine-30; Evacuare finala stock -50; Corp/clapeta acceleratie/galerie admisie-20; Termostat-30; Furtune radiator (2)-40; Injectoare (4)-50; Rampa injectie/regulator presiune-40; Fise inductie-40 toate 4 Plus o toba finala sport de 318/318is, necesita refacerea sudurilor de la intrare si de la iesire: 50 ron |
Re: Piese E36
Relee-20
Senzor temperatura lichid racire-30; Senzori detonatie-20; Furtune vacuum-10/buc; Lant distributie-30; Patine-20; Evacuare finala stock -50; Corp/clapeta acceleratie/galerie admisie-20; Termostat-40; Furtune radiator (2)-40; Injectoare (4)-50; Rampa injectie/regulator presiune-30; Fise inductie-30 toate 4 Plus o toba finala sport de 318/318is, necesita refacerea sudurilor de la intrare si de la iesire: 50 ron |
Re: Piese E36
Furtune vacuum-10/buc; Lant distributie-30; Patine-20; Evacuare finala stock -40; Corp/clapeta acceleratie/galerie admisie-20; Termostat-40; Furtune radiator (2)-40; Injectoare (4)-50; Rampa injectie/regulator presiune-30; Fise inductie-30 toate 4 |
| All times are GMT +2. The time now is 16:37. |
