-   Discutii generale moto (https://forum.4tuning.ro/571-discutii-generale-moto.html)
-   -   Modele noi (https://forum.4tuning.ro/571-discutii-generale-moto/1638-modele.html)
n0namee 16-09-04 08:20
2005 Yamaha R6 Debuts
Yamaha has updated the R6 for 2005, with changes aimed at increased power and better handling. The motor features larger throttle bodies, revised fuel and ignition maps, new camshafts and redesigned intake funnels - resulting in a claimed 3hp increase in peak power, with more power at all RPMs.
The chassis uses a new 41mm inverted fork and a redesigned frame and swingarm linkage. Up front, radial-mount calipers now grip larger 310mm discs, with fluid moved by a new radial master cylinder.
Styling changes are limited to revisions to the headlight lens and under-cowl.
n0namee 16-09-04 08:21
more ...
catalin rs4 14-04-05 01:32
Re:
Originally Posted by \"n0namee\"
:wink:
There are 2 2005 F4s on US soil. Attached are 3 pics. At the Ephrata (Pa.) Breakfast Run, Larry Ferracci, son of Eraldo Ferracci, brought a brand new 2005 MV Agusta F4 1000. One is going to Motorcyclist for a review and the other is going to Cycle World. They had it on the dyno this week and it turned 162hp at the rear wheel with 80 lb-ft of torque. They will be available for sale in August for about $21K. Dead sexy.
ce cauta motorul meu aici?? :lol: asa arata si al meu super motoreta un vis.... 8) ma declar mandru posesor de mv agusta f4 :wink:
n0namee 14-04-05 14:47
8) pune poze shefu' ... poze ... ca deja sterg cu limba pe jos!
needBrain 14-04-05 19:53
beton rau pe negru
catalin rs4 14-04-05 22:18
cel mai fain ii pe rosu si arginitu clasic....singura poza pe care o am ii asta.....nam motorul demult de cateva zile am sa pun si alte poze in curand...
needBrain 17-04-05 00:22
bai deci,sincer,imi plac motoarele.dar mi se par prea riscante
Gsx_18 17-04-05 14:27
Specs
Engine: 998.6cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
Bore Stroke: 73.4 x 59.0mm
Compression Ratio: 12.5:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital/transistorized
Transmission: 6-speed, constant mesh
Final Drive: #530 chain
Overall Length: 2030mm (80.0 in.)
Overall Width: 710mm (28.0 in.)
Overall Height: 1130mm (44.5 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1405mm (55.3 in.)
Dry Weight: 166 kg (365 lbs.)
Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, compression and rebound damping
Suspension Rear: Link-type, gas/oil-damped, fully adjustable spring preload, compression and rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 190/50-ZR-17
Fuel Tank Capacity: 18 liter (4.8 gal.)
Color: Blue/White, Black/Gray, Black/Yellow
TheRogue1 12-07-05 14:08
La CIP 8.680 euro se adauga o taxa vamala de 30% si anume 2.604 euro.
Rezulta 11.280 euro la care se adauga TVA, deci 13.427 euro, si nu 11.420 euro.
Pretul asta este la RSV-ul de 450 de la Aprillia?
