Re: Aduc pe comanda scule audio
Sorry, siteul nu ma convinge, nu precizeaza nicaieri ca ar fi alpine, sincer nici nu cred ca este. Stiu ca Alpine a facut si inca face DVD HU dar din pacate acest model nu este unul dintre ele.
Merci oricum, bafta la comenzi |
Ok, nici o problema... o sa aduc oricum unul si atunci ma voi convinge si eu daca este sau nu Alpine... poate nu este poza corecta... sincer nici eu nu stiu ce sa spun pentru ca am luat multe de la ei si niciodata nu a fost vreo problema..
pai ... singurul dvd player de la alpine e cu afisaj color .. :)
Ceva amplif monoblock in clasa D?
Common Features
• Linkable with Second Identical Model (Hardware Included) • Hour Meter • Remote Mount PMA100V Digital Volt Meter • Remote Mount PMA10B Bass Boost Control • Heavy Duty One-Piece Extruded Aluminum Heat Sink • Beveled Clear Acrylic Protective Cover • Tiffany-Style RCA Jacks • Parallel Line-Out RCA Jacks • Removable Aluminum Side Covers Conceal Control & Terminal Panels • MOSFET High-Speed Switching Power Supply • Milspec Double-Sided Glass Epoxy Circuit Board w/ Through-Hole Plating • Heavy 4 oz. Pure Copper PC Traces at All Preamp & Amplification Stages • Internally Mounted Fan-Cooled Power Supply • Solid Brass Nickel-Plated Terminal Blocks (4-Gauge Power, 8-Gauge Speaker) • Variable Low-Pass Filter: 50Hz - 150Hz @ 24dB/Octave • Variable Subsonic Filter: 15Hz - 40Hz @ 24dB/Octave • Variable Bass Boost @ 45Hz: 0 - +18dB • Variable Phase Shift: 0 - 180° • THD: <0.08% • Signal-to-Noise Ratio: >100dB • Frequency Response: 5Hz - 250Hz • Input Impedance: 10kΩ • Input Sensitivity: 300mV~8V • 4-Way Protection Circuitry: Thermal, Short Circuit, Overload & DC Offset • Cooling Fan(s) si sunt 3 variante: 900W rms la 4ohmi pret 800E 1000W rms la 4 ohmi 900E si 1200W rms la 4 ohmi 1000E ->toate sunt de la Alphsonik mai am si de la audiobahn daca te intereseaza |
M-ar interesa unul sau doua subwoofere audiobahn. AW1208T, AW1506T...in jur de 800-1000 RMS...Imi poti spune niste preturi?
Merci. |
Aduci si Clarion?
ma intereseaza un dvdplayer... merci |
Niste preturi pentru Audiobahn A8002T Car Audio Amplifier, A6004T Car Audio Amplifier, A4002T Car Audio Amplifier se poate? Merci.
Audiobahn A8002T -> 340E
Audiobahn A6004T -> 300E Audiobahn A4002T -> 250E Audiobahn AW1208T -> 420E Audiobahn AW1506T -> 420E Clarion nu aduc! |
nimic nimic?
ai ceva produse de la alpine ... wofere ... de 300 W rms ?? in cutie sau fara ...
De la alpine nu am... Saptamana asta o sa am un subwoofer de la DUB audio.. Poate te intereseaza asta!
Ce subwoofer free air poti sa aduci si la ce bani? o lista daca poti sami faci si mie... sa fie cu diametru de 8" sau 10"
sal ma intereseaza boxele auto de la jbl model t595 limited serius la ce pret le aduci da-mi un mail pe [email protected]
| All times are GMT +2. The time now is 02:42. |
