-   Timisoara (https://forum.4tuning.ro/39-timisoara.html)
-   -   Noutati, proiecte, prototipuri...impresii (https://forum.4tuning.ro/39-timisoara/1509-noutati-proiecte-prototipuri-impresii.html)
n0namee 30-07-04 21:37
sa innebunesc! i-ati gasit masina lui uberman??? sa ne traiesti nene ... si sa iti iei carnetu ...
akimoto 16-08-04 13:43
2004 Ford Shelby GR-1 Concept
2004 Ford Shelby GR-1 Concept - 605cp
detalii: http://www.rsportscars.com/eng/cars/...helby_gr-1.asp
COObra 16-08-04 14:35
parca mai frumoasa cea veche. modelul din gone in 60 seconds.
dar nu mi-ar fi rusine nici nu un dasta. :D
BogdanCMS 16-08-04 14:52
Ce cauta boshorogul langa masinutza asta? Sa inteleg ca e Shelby in persoana?
Speedy 16-08-04 15:28
merge :wink:
Corse 16-08-04 16:22
si eu sunt tot de parere ca modelu mai vechi e mai fain
akimoto 16-08-04 17:38
Re:
boshorogul este chiar Carroll Hall Shelby, acum ajuns la venerabila varsta de 81 de ani
mihaiu 31-08-04 14:33
nu stiu daca aici era cel mai nimerit sa postez, dar am si eu o intrebare. Cum va suna fabia 2.0 mpi, 116 cp, cuplu 170nm, jante pe 16 si un pic peste 9 sec pana la suta, totul in varianta elegance, cu 12500 euro?
BogdanCMS 31-08-04 17:22
Stai sa ghicesc...ti-ai vandut Swiftul si ti-ai luat Fabie...de ce ai facut prostia asta?? :cry: :( :(
akimoto 31-08-04 17:28
continuati aici: https://www.4tuning.ro/forum/viewtopic.php?p=72870#72870
Speedy 03-09-04 13:51
2005 Toyota Corolla XRS
The Toyota Corolla XRS sport sedan was first shown in November 2003. Featuring a newly tuned version of Toyota's 2ZZ dual overhead cam engine and six-speed manual transmission (found in the Celica GT-S and Corolla Matrix XRS), the car should be able to outrace the Ford Focus SVT and Honda Civic Si. The increase in power will be complemented by improved ride and handling, thanks to a sport-tuned suspension and new steering improvements.
The 1.8 liter engine produces 170 horsepower but only 127 lb-ft of torque - roughly the same torque as the standard Corolla. The engine has been retuned to deliver a broader and stronger mid-range power curve, but continues the variable valve timing and lift system for a turbo-like rise in power starting at 6,000 rpm. The result, along with the Corolla's relatively light weight, is a zero-to-sixty time under eight seconds coupled with good throttle response - and gas mileage of 25 city, 32 highway.
The new Corolla XRS will be powered by a 1.8-liter four-cylinder DOHC engine that produces 170 horsepower and 127 pounds of torque. The engine will deliver a broader and stronger mid-range torque than the previous versions of the 2ZZ engine. And, it will feature a VVTL-i variable valve timing and lift system that produces a supercharged-like rise in power from 6,000 to 7,800 RPM. The result is a compact sport sedan that blends sub-eight-second zero-to-sixty acceleration with exceptional throttle response throughout its broad power band.
The XRS features a sport-tuned suspension that includes a front connecting rod damper developed by Yamaha. The damper is mounted between the shock towers to produce improved ride and handling without compromising NVH. In addition to the performance damper, the XRS features increased rate coil springs and shocks on all four wheels for improved roll and pitch, and a ride height that is lower by a full half-inch.
The suspension stands on larger 16-inch aluminum alloy wheels and Michelin performance tires, an upgrade from the standard 15-inch wheels on all other Corolla grades. It is complemented by a steering system that features a more rigid steering column, producing less vibration and improved response. A power steering rack developed for the XRS allows for better steering feedback.
There are also cosmetic changes including sport seats, color-keyed bezel surrounding the grille, silver-colored center cluster and switch plates, a leather-like shift boot with a leather shift knob, and unique badging.
The Corolla XRS will be built at Toyota Motor Manufacturing, Canada (TMMC) in Cambridge, Ontario alongside the Matrix. It will reach dealerships on May 1st, 2004. Annual sales of the XRS are projected at approximately 5,000 units.
General
Make Toyota
Year 2005
Engine Location Front
Drive Type Front Wheel
Weight 2590 lbs | 1174.8 kg.
Gears 6
Transmission Type manual
Final Drive NA
Price NA
Skidpad NA
Body Material NA
Steering NA
Turns - Lock to Lock NA
Turning Circle NA
Engine
Cylinders 4
Engine Configuration Streight
Aspiration/Induction Normal
Displacement 1.8 L | 110 cu in. | 1803 cc.
Valves 16. 4 valves per cylinder.
Valvetrain DOHC
Horsepower 125.1 Kw / 170 BHP
Torque 127.6 Ft-Lb /
Redline NA
Bore NA
Stroke NA
Compression Ratio NA
BHP per Liter 94.44
Dimensions | Chassis | Body
Length 178.301 in | 4528.8 mm. | 4.5 m.
Width 66.901 in | 1699.3 mm. | 1.7 m.
Height NA
Wheelbase 102.401 in | 2601.0 mm. | 2.6 m.
Front Track NA
Rear Track NA
Ground Clearance NA
Cargo Volume 13.601 cu. ft.
Passenger Volume NA
Interior Volume NA
Bed Length NA
Seating Capacity 5
Doors NA
Performance
0-60 mph NA
1/4 Mile NA
Top Speed NA
Suspension
Front Suspension NA
Rear Suspension NA
Towing
Towing Capacity NA
Brakes
Front Brakes ABS, Disc
Front Brake Size NA
Rear Brakes ABS, Disc
Rear Brake Size NA
Tires
Front Tire NA
Rear Tire NA
Front Wheels NA
Rear Wheels NA
cioli17 25-12-04 02:38
http://www.carfolio.com/specificatio.../id/?id=122331 subaru
http://www.type-25.com/index.asp?file=t25pictures subaru type 25 , acc. de la 0-100 in 3.9
hai ma mai puneti si voi cate ceva...
n0namee 28-12-04 13:12
8) TOYOTA
The Toyota Prius has been voted 2005 Car of the Year by the 58 members of the European Car of the Year Jury. After 2 rounds of voting, the car was chosen from a list of 7 finalists and declared clear winner after gathering 406 points.
Prius , the world’s first mass produced hybrid vehicle, is propelled by the combination of an electric motor and a petrol engine. This unique system, called Toyota Hybrid Synergy Drive®, will spearhead the development of new environmentally friendly powertrains and is part of Toyota’s effort to create the ultimate eco car.
Speedy 28-12-04 14:04
2006 Mitsubishi Galant Ralliart
V6,3.8l,260 BHP
