-   -   Cer ajutor constructie incinta bass-reflex (https://forum.4tuning.ro/382-coltul-incepatorului/142536-cer-ajutor-constructie-incinta-bass-reflex.html)
Stage2 21-07-10 20:17
Re: Cer ajutor constructie incinta bass-reflex
25(latime) / 300(inaltime) / 320(adancime) mm
scooby89 21-07-10 20:31
Am achizitionat si eu o tigaie de difuzor Woofer HiFi Carpower CRB-25HQ, de 25 cm, si as dori cateva sfaturi despre incinta.. cum sa o fac ... cu bass reflex sau inchisa,... aici mai jos sunt niste specificatii ale dif.. am luat si eu cateva prg de calculat incinte,,, dar ma depasesc, nu stiu cum sa le folosesc... in fine as dori si eu cateva pareri... si unele schite.. va multumesc..
Vad ca ei recomanda bass reflex.
already possible in closed cabinets of 20
litres or in BR cabinets of approx. 35 litres (very recommendable).
Technical Facts Speakers
Impedance (Z)4Ω
Resonant frequency (fs)33Hz
Max. frequency rangef3-300Hz
Music power500WMAX
Power rating (P)200WRMS
SPL (1W/1m)85dB
Suspension compl. (Cms)0.20mm/N
Moving mass (Mms)116g
Mech. Q factor (Qms)5.56
Electr. Q factor (Qes)0.49
Total Q factor (Qts)0.45
Equivalent volume (Vas)27 l
DC resistance (Re) 3.3Ω
Force factor (BxL) 14.6Tm
Voice coil induct. (Le)2.2mH
Voice coil diameter Ø 38mm
Voice coil former aluminium
Linear excursion (XMAX)±5mm
Eff. cone area (Sd)315cm2
Magnet weight 2.3kg
Weight 5.6kg
V-AS FI FOARTE RECUNOSCATOR DACA MA AJUTATI SI PE MINE
boly76 21-07-10 23:43
mersi de ajutor.
imi poti spune cum ai facut calculul(pentru cultura mea generala)?
Stage2 22-07-10 09:50
Matematica asta, ceva foarte frumos, deschide multe usi daca intelegi.
1) Calculezi volumul cilindrului tau (Z)
2) Ne imaginam un paralelipiped cu l = X (25) si L = Y (300), cifre puse de mine pentru simplificarea constructiei
3) Ai multe metode la dispozitie, una ar fi, cu ajutorul X,Y,Z, calculezi adancimea.
Ai destule metode, asta cred ca-i cea mai simpla.
Boxa 30 litrii cu tub dreptunghiular 20/250/200(adancimea) mm
In legatura cu schite, cred ca sunt la ordinea sutelor, implica-te putin, la urma urmei, pentru tine o faci.
boly76 22-07-10 10:11
mersi mult
matematica,mai ales geometria, au fost intotdeauna punctul meu "forte":D
MARIUS_05_GEK 26-01-11 12:06
Salutare! am achizitionat de curand un amplificator blaupunkt gta 260(180wrms in punte) si un diifuzor Sony xplod xs-L104P5B de 10 inch, 330wrms. Ma puteti ajuta cu un volum pentru incinta bass-reflex? Precizez ca in cutia difuzorului nu am gasit nimic despre acei parametri care stiu ca sunt importanti :sad: Multumesc anticipat!
anarky21 24-07-11 16:24
constructie woofer.
am achizitiona acest difuzor http://www.mivarom.ro/catalog/produc...oducts_id=3997. doar atat stiu despre el.Putere max.:250W
Impedanta: 8 Ohm
Sensibilitate: 92dB
Frecventa: 30Hz - 4kHz
Magnet : 40 Oz.c
cine ma poate ajuta si pe mine cu dimeniunile carcasei.vreau sa-l fac woofer.Va multumesc la toti cei care imi da un sfat.
Stage2 24-07-11 20:18
Cine te poate ajuta cu dimensiunile boxei/incintei/cutiei, carcasei ?!
Pentru inceput, avem un difuzor, unele stiu sa redea inalte(tweeter), altele medii(mid-range), altele bass(woofer), altele subbass(subwoofer), altele ,,le stie pe toate"(fullrange).
Esti cunostient ca difuzorul prezentat este facut pe vapor si nu avem parametrii pentru el, dupa care, in mod normal, se poate calcula dimensiunea boxei/incintei/cutiei; carcasei !?
Sper ca reusesti sa gusti tonul putin glumet pe care-l am, lasand gluma insa, n-ai de ales decat sa mergi pe ceva ,,standardizat" in speranta ca iese bine.
Boxa de aproximativ 28 litrii cu reflex rotund (tub) la diametrul de 7 cm si 20 cm adancime.
Spor la treaba !
anarky21 25-07-11 16:30
[QUOTE=Stage2;4484844]Cine te poate ajuta cu dimensiunile boxei/incintei/cutiei, carcasei ?!
Spor la treaba !
scz asta e ptr mine?daca e ptr mine eu vreau sa fac incnta in forma de paralipiped.ai idee ce dimensiuni ar trb?
animalutz 27-07-11 12:47
Colegu', ar trebui sa te gandesti sa-ti iei un difuzor adevarat, si pe urma sa-i faci o incinta. ;)
anarky21 27-07-11 13:15
ee lasa ca e bun si ala il fac pana la urma asa cum cred eu.multumesc oricum.
