-   -   Nissan a dezvaluit noul GT-R SpecV (https://forum.4tuning.ro/18-masini-tunate/103617-nissan-dezvaluit-noul-gt-specv.html)
spiri14 09-01-09 19:28
Re: Nissan a dezvaluit noul GT-R SpecV
mie unu nu-mi plac deloc jantele astea !! aratau mult mai bine cele standard...
si stie cineva daca va mai avea limitatoru' ala pentru viteza daca nu esti pe circuit??
p.s. o subtitrare la ce spune acel om.. directorul cine o fi :) ar ajuta pe multi de aici
bbim 09-01-09 21:30
Originally Posted by boy_wonder (Post 1968145)
nu, are doar 480 cai putere si este cu 60 kg mai usor decat GT-R standard.
are 485 cp exact ca si GT-R standard model 2009 numai ca are cu 100 km mai putin
bisag daniel 09-01-09 22:18
ce inrosite erau discurile. performanta .
Takashy_Vtec18 10-01-09 10:16
wooww...o masina fantastica...
steffan 10-01-09 13:23
tare masina asta... japonezii astia stiu ei ce fac:|
blacksnake 11-01-09 09:00
parca bate putin a celica din fata
b_gt 11-01-09 20:17
degeaba...tot o masina japoneza ramane..poate sa fuga si 600
300zxtt 12-01-09 12:46
japoneza nejaponeza...incepe sa dea lectii altora...
ZaXXaZ 12-01-09 13:41
in cazul in care nu se stie japonezii sunt lideri in domeniul fiabilitatii masinilor:yes:
boy_wonder 12-01-09 17:53
Nissan GT-R SpecV
Nissan SpecV Main Specification:
Name and Type:
* Nissan CBA-R35
Transmission Type:
* Type GR6 Dual Clutch transmission
Dimension:
* Length x Width x Height (mm): 4650 x 1895 x 1370
* Interior Length X Width x Height (mm): 850 x 1475 x 1095
* Wheel Base (mm): 2780
* Track [Front] (mm): 1590
* Track [Rear] (mm): 1600
* Minimum Ground Clearance (mm): 110
Weight, Capacity:
* Curb Weight (kg): 1680
* Passenger Capacity: 2
* Gross Weight (kg): 1790
Performance:
* Turning Radius (m): 5.7
* Fuel Efficiency (Km/L): 8.3
* Fuel Saving Strategy: Variable Valve Timing
Drivetrain:
* Drive: 4 Wheel Drive
* Steering: Electronically Power Assisted Rack & Pinion
* Suspension: Front- Independent Double Wishbone
* Suspension: Rear - Independent Multi-Link
* Brake: Front & Rear - Ventilated Disk
* Tire [Front, Rear]: 255/40 ZRF20 (97Y), 285/35 ZRF20 (100Y)
Engine Specification:
* Engine: VR38DETT
* Type, Cylinder: DOHC, V6
* Bore & Stroke (mm): 95.5 x 88.4
* Displacement (L): 3.799
* Compression Ratio: 9.0
* Power: 357 Kw (485 PS) / 6400 rpm
* Torque: 588 N.m (60kgf.m) / 3200~5200 rpm
* Fuel Delivery System: Nissan EGI (ECCS) Fuel Injection System
* Fuel Type, Fuel Capacity(L): Premium unleaded, 74
Gear Ratio:
* First: 4.056
* Second: 2.301
* Third: 1.595
* Forth: 1.248
* Fifth: 1.001
* Sixth: 0.796
* Reverse: 3.383
* Final: 3.700
b_gt 13-01-09 19:35
lectii de ce?o parchezi langa un ferrari..pleaca singura de rusine...;)...:D
Mustang 13-01-09 22:25
Man, da' tu nu te saturi sa postezi numai ineptii pe aici?!
Nu te-ai saturat cu ban-ul ala?
Da si tu niste argumente solide cand spui ca e "japoneza ... poate sa aiba si 600...". Ce nu inghiti la ea? De ce nu inghiti acest lucru la ea, de ce ti se pare absurda?!
Fii mai comunicativ cand postezi, nu mai posta doar asa de dragul maririi numarului de posturi...
georgerg 21-01-09 23:46
tare, scumpa, aaa foarte scumpa - inutil de scumpa - cu banii astia obtii mult mai mult de la un GTR normal si mod aftermarket - sunt curios ce timp va scoate pe Nur' - sper sub 7.25.
Alex_55 22-01-09 00:12
iar .... pffff, ce rost mai are ?!!?!
