sunt perfect de acord
Re:
LEGAL RACING
Recomand oricui are posibilitatea sa se dea pe pista sa o faca. Atenti primele dat vi se poate parea ciudat, insa obisnuinta poate deveni a doua natura. |
Audi BMW
Model 1999 RS4 Avant 2001 E46 M3 Powertrain Layout Front Engine / 4WD Not Available Base Price Not Available Not Available Curb Weight 2100 kg / 4630 lbs 1570 kg / 3461 lbs Length 4510 mm / 177.6 in 4492 mm / 176.9 in Wheelbase 2610 mm / 102.8 in 2731 mm / 107.5 in Width 1730 mm / 68.1 in 1780 mm / 70.1 in Front / Rear Track 1500 mm / 59.1 in 1490 mm / 58.7 in 1508 mm / 59.4 in 1525 mm / 60.0 in Height 1400 mm / 55.1 in 1372 mm / 54.0 in Engine Configuration Biturbo V6 S51 Inline-6 Valvetrain 5 Valves / Cyl Not Available Displacement 2671 cc / 162.9 cu in 3246 cc / 198.1 cu in Bore 81.0 mm / 3.19 in 87 mm / 3.43 in Power 283.4 kw / 380.0 bhp @ 6500 rpm 255.8 kw / 343.0 bhp @ 7900 rpm Stroke 86.4 mm / 3.4 in 91 mm / 3.58 in Torque 440.0 nm / 324.5 ft lbs @ 2500 rpm 364.72 nm / 269.0 ft lbs @ 4900 rpm Compression Ratio 9.3:1 11.5:1 Bhp / Liter 142.27 bhp per litre 105.67 bhp per litre Max Engine Speed Not Available Not Available Chassis & Body Body / Frame Not Available Not Available Brake Type Vented Discs w/ABS Vented Discs w/Single Piston Caliper & ABS Steering Rack & Pinion w/Power Assist Rack & Pinion w/Power Assist Brake Size 360 mm / 14.2 in 312 mm / 12.3 in 325 mm / 12.8 in 328 mm / 12.9 in Wheels (Diameter x Width) F 45.7 x 43.2 cm / 18.0 x 17.0 in R 45.7 x 43.2 cm / 18.0 x 17.0 in F 45.7 x 20.3 cm / 18.0 x 8.0 in R 45.7 x 22.9 cm / 18.0 x 9.0 in Tires F 255/35ZR-18 R 255/35ZR-18 225/45ZR18 225/40ZR18 Drivetrain Transmission 6-Speed Manual 6-Speed Manual Final Drive Not Available 3.620:1 1st Gear Ratio Not Available 4.227:1 2nd Gear Ratio Not Available 2.528:1 3rd Gear Ratio Not Available 1.669:1 4th Gear Ratio Not Available 1.226:1 5th Gear Ratio Not Available 1.000:1 6th Gear Ratio Not Available 0.828:1 Performance Top Speed 250.0 kph / 155.3 mph 249.4 kph / 155.0 mph 0 - ¼ mile Not Available Not Available 0 - 60 mph 4.9 seconds 5.1 seconds 0 - 100 mph Not Available Not Available Lateral Acceleration Not Available Not Available EPA City/Hwy Not Available 15.9 / 33.6 |
bai oameni buni comparatia asta nu are rost, in primul rand trebuia sa fie intre AUDI S4 si BMW M3 sau intre AUDI RS4 si BMW M3 CSL si masinile sa fie \"normale\" nu modificate. si in amble cazuri bmw-ul castiga asa ca ...
daca cele 2 masin sunt stock ....nu se pot compara...daca in ambele masini investesti 10-12 mii euro pariez pe M..... pentru cai-as pune un kit de turbo si cu un control al tractiunii de DTA......daca si daca ....daca aveti 7-8mi puteti avea kadett turbo :D ..... glumeam masini le nu se compara..dar ........ uex(M5)...poate are o alta parere ...am inteles catalin ca ai stat egal cu sorici (M5)pana pe la 280km/h dupa care te-ai dus.... E ADEVARAT?
important este sa sti sa pierzi..... |
am mai spus odata si mai repet pt fani audi, nu poti compara un RS4 cu un M3, compara un M3 cu un S4 si un RS cu M3CSL.
atunci sa vedem....... a si sa fie stock. |
comparatia ce trebuia facuta era urmatoarea
M3 vs S4 stock SAU M3 CSL vs RS4 stock si pana una alta....in ambele cazuri....audi isi ia omor chit ca e time attack sau liniuta |
| All times are GMT +2. The time now is 05:42. |
