-   -   AMG vs. M vs. RS (https://forum.4tuning.ro/55-versus-auto/93009-amg-vs-vs-rs.html)
boy_wonder 10-01-13 09:22
Re: AMG vs. M vs. RS
Tractiune integrala va avea cu siguranta. Au spus-o si cei de la Mercedes. De acea acceleratie nu stiu ce sa zic, pana si eu ma indoiesc. Acum sa vedem...
BTW, daca imi amintesc bine, dupa ce au luat contact cu cateva prototipuri, cei de la Car & Driver estimau un 0 - 60 mph in 3.2 secunde. Acum sa vedem, zic inca o data...
specialist 10-01-13 10:04
de la 3.5 sec in jos mi se pare racheta si greu de realizat pt o masina cu 2 tone minim(in varianta 4matic). va fi si cu tractiune integrala cu siguranta.
boy_wonder 10-01-13 10:30
Si mie mi se pare aproape imposibil un 3.5 secunde. Adica nici SLS-ul Black Series nu reuseste o astfel de performanta. Ramane sa vedem saptamana viitoare cum stau de fapt lucrurile.
boy_wonder 10-01-13 10:43
Am zis saptamana viitoare? E deja oficial:
E63 AMG 4MATIC S-Model, 585 CP si 800 Nm, 0 - 100 km/h in 3.6 secunde.
Aceleasi cifre sunt valabile si pentru noul CLS63 AMG 4MATIC S-Model.
specialist 10-01-13 12:15
mai multe detalii:
Mercedes-Benz has officially revealed the 2014 E63 AMG sedan and estate, following a previous photo released earlier this week.
Set to make its public debut at next week's Detroit Motor Show, the revamped E63 AMG comes with a considerably more aggressive front fascia featuring new headlamps, bespoke grille and bumper with large air ducts and a central splitter aimed to improve air flow underneath the vehicle. At the back the bumper has been restyled and houses an updated diffuser and quad trapezoidal tailpipes.
At its heart is the same V8 5.5-liter twin-turbo engine but AMG has further tweaked it now generating 557 HP (410 kW) at 5,500 rpm and 720 Nm (531 lb-ft) between 1,750 and 5,250 rpm. It enables the high-performance sedan to perform the 0-62 mph (0-100 km/h) sprint in 4.2 seconds. The all-wheel drive 4MATIC variant can do it in 3.7 seconds for the sedan and 3.8 seconds for the wagon.
Mercedes-Benz is also introducing the E63 AMG 4MATIC S-Model for both body styles with a rear differential lock and a more powerful variant of the same engine providing 585 HP (430 kW) at 5,500 rpm and 800 Nm (590 lb-ft) between 1,750 and 5,000 rpm. This will reach 62 mph in 3.6 / 3.7 seconds (sedan / estate). Regardless of the version, all models have an electronically limited top speed of 250 km/h (155 mph).
Power is sent to wheels via the AMG SPEEDSHIFT MCT seven-speed sports transmission which offers four modes: C (Controlled Efficiency), S (Sport), S+ (Sport Plus) and M (Manual). A ceramic brake system is optionally available and comes with ventilated and perforated 360mm brake discs with silver calipers for the regular AMG model and red ones for the higher-spec S-Model.
The S-Model is further distinguished by 19-inch, 10-spoke alloys with 255/35 R19 and 285/30 R 19 tires (front / rear). The front splitter and rear trim strip have a silver chrome finish, while the sedan has a body-colored spoiler lip which reduces lift at high speeds.
The RWD versions will go on sale in April, followed by the 4MATIC and S-Model variants in June.
se cunoaste ca motorul asta are 5.5 litri. scot astia cai putere si NM ca din branza.
557Hp si 720Nm pt versiunea light respectiv 585HP si 800NM pt versiunea de top.
eu sunt ferm convins ca RS6 va fi cel mai lent dintre toate 3 la viteze de peste 100km/h, avand cel mai mic motor si ca va fi cel mai rapid pana la 100km/h insa datorita tractiunii superioare. pana la urma M5 are un motor cu o capacitate cu 10% mai mare iar E63 are 37,5% capacitate cilindrica in plus iar asta se cunoaste la demarajele incepute la viteze mari.
UNLORD 10-01-13 16:45
Originally Posted by bluey (Post 5312729)
Chiar am si eu o mare curiozitate.
Cauciucuri de strada, asfalt normal. Cum dracu pleci cu rwd sa faci 3.5s pana la 100km/h de pe loc???
Si daca pleaca cu launch control sau alt sistem electronic cu timpul asta, in cat timp face suta cu slick si pe lipici?
Recunosc ca nu m-am dat la viata mea cu rwd dar totusi la puterile alea trebuie sa fie putin dificil cu 2wd.
E destul de greu de realizat, mai ales pe un asfalt de rahat ca asta din Ro...oricum conteaza si cauciucurile cu care sunt dotate, Michelin Pilot Supersport sunt cele mai bune la ora actuala.
Originally Posted by specialist (Post 5313077)
boy_wander, lasa NFS-ul deoparte. aci nu e vorba de computer, e viata reala.
E63 amg fara facelift cu 525cp avea 4.3 pana la 100km/h iar varianta performance package cu 560 cp avea 4.2.
cum crezi tu ca un facelift amarat ar putea sa aduca o asa diferenta de performanta ?! daca era un model nou, hai ca poate ar fi fost posibil.
pt o masina de 2 tone ar trebui awd si 600 cp pt 3.5 sec.
Toate au/vor avea peste 600 de hp la volanta (inclusiv M5-ul si viitorul RS6). Si cred ca mai e vesnica eroare/confuzie a celor ce adapteaza textele americane 100km/h = 60mph ... oricum pt mine mai important decat cifra 100 e sfertul de mila, unde cred (parerea mea) ca Mercedesul cu al sau cuplu urias dat de 5.5 biturbo va da cu RS6-le si M5-ul de pamant ( chiar daca e penalizat de cutia de viteze, va fi forta bruta). Ramane de vazut, e clar ca Mercedes nu stat degeaba si pregateste o revenire in forta.
specialist 11-01-13 07:33
cred ca niciodata nu a fost ca acum, adica fiecare sa ia in serios pe celalalt si, de regula, la facelift-ul unui model de nisa modificarile erau minore, nicicum asa cum au facut mercedes acum.
estimarile mele sunt astfel:
rolling:
E63AMG
M5
RS6
0-100
rs6
E63AMG
M5
1/4(aici oscilez cine va fi primul dar ma bazez ca S8 are 11.8, SLS amg are abia 11.6, E63amg PP fara facelift are 12.0 iar S6 avant are 12.4, S6 sedan 12.1 )
. cred totusi ca ordinea va fi urmatoarea desi sunt sigur doar ca M5 va fi cel mai slab:
E63
Rs6
M5
circuit:
RS6
M5
E63 amg(modelele amg de regula sunt bune doar la liniute si mi-e greu sa cred ca au rezolvat handicapul imens)
ce e interesant ar fi faptul ca E63 are 8 modele diferite iar Rs6 si M5 au doar cate unul iar in clasamentul virtual scris mai sus ma gandesc la E63-ul adaptat cel mai bine pt o astfel de competitie.
in concluzie, cred ca M5 nu va castiga nici o competitie cronometrata ci doar pe alea subiective de gen feeling/emotion samd.
boy_wonder 14-01-13 18:47
560 CP si 700 Nm.
Attachment 2659804 Attachment 2659805Attachment 2659806
boy_wonder 14-01-13 19:06
Inca un set:
Attachment 2659822 Attachment 2659823
Attachment 2659824 Attachment 2659825
PS: 0 - 100 km/h in 3.9 secunde (oficial).
PvDTranceAddicted 14-01-13 20:53
Fara suparare, stres sau nervi din partea unora dar RS6 va castiga testele pe circuit si in linie dreapta cu M5 si E63AMG S fara sa se chinuie prea tare! Vedeti ce a facut vechea generatie cu rivalii iar acum ca S6 e incredibil de rapid, 0-100km/h in 3.9s la S6 in teste e mai mult decat concludent ce va face RS6 in teste impreuna cu rivalii sai! Sa nu mai zic de RS7 Sportback care e avion de vanatoare si la aspect si la performante! Ideea e ca asteptam cu totii testele concludente, mai ales cele de la Autobild si AMS Germania, foarte obiectivi in teste, uneori cam sarcastici dar testele lor sunt reale...
GTR 14-01-13 21:12
Fara suparare, s-ar putea sa avem o surpriza de la noul E facelift. Acum era si normal ca la 2 ani de la aparitia noului M5, sa scoata o masina mai performanta, tipic VAG-Audi.
Sa nu uitam ca C63 AMG BS face misto de actualele M3 si RS4-RS5 variantele 2012.
specialist 14-01-13 21:47
GTR, dintre toate persoanele prezente aici pe forum, tu dezinformezi cel mai mult, posturile tale sunt nedocumentate si aruncate in vant, fara sa te interesezi inainte sa vorbesti.
1) bmw seria 5 s-a lansat pe 23 noiembrie 2009.
2) bmw M5 s-a lansat in septembrie 2011
adica lui bmw i-a luat 1 an si 10 luni pt lansarea lui M5
1) audi A6 s-a lansat pe 30 noiembrie 2010
2) audi RS6 s-a lansat in prima zi a lui decembrie 2012
lui audi i-a luat 2 ani pt lansarea lui RS6 adica doua luni in plus fata de BMW
audi RS6 a venit practic la 1 an, doua luni si doua saptamni dupa M5, deci nu la doi ani cum spui tu. in acel an, omenirea nu a inventat nimic dpdv tehnic pe care audi sa foloseasca in favoarea lor
RS6 si M5 sunt masini ce au fost dezvolatate aprox in acelasi timp, iar daca una din cele doua este mai rapida pe circuit sau in linie dreapta, atunci nu exista nimic de comentat si de contraargumentat.
si eu ma astept ca E63 amg sa fie mai rapid in linie dreapta in comparatia cu RS6, insa clar va fi surclasat pe circuit.
C63 amg este mai rapid la randu-i doar in linie dreapta, pe circuit neavand nicio sansa.
mercedes nu a demonstrat ca poate sa faca masini la nivelul handlingului celor de ma bmw sau audi.
GTR 14-01-13 22:29
"The F10 M5 was released to the public at the 2011 Frankfurt Motor Show, and went on sale in November 2011."
"On November 20,2012 Audi announces to debut an Avant version of the RS6 at the 2013 Detroit auto show."
Deci una e prezentarea, alta e vanzarea, asa ca mai adauga cateva luni. Deci oricum am dreptate.
Normal ca este de 10 ori mai usor sa bati o masina care este deja in fabricatie, decat sa-ti asumi riscul sa o scoti in acelasi timp, cum au patit cu M3 E46 vs RS4 B5.
Tocmai o sa-ti demonstrez ca "posturile tale sunt nedocumentate si aruncate in vant, fara sa te interesezi inainte sa vorbesti.", tipic romanesc dealtfel.
http://fastestlaps.com/comparisons/m...-audi_rs5.html
Si nu ca-l bate pe RS5, se "c a c a" pe el la absolut TOT.
run_forest 14-01-13 22:55
Chestie "tare" la mercedes este
0-60 mph = 4.0 sec
0-100 KPH = 3.9 sec :)
Scuze dar nu m-am putut abtine..
GTR 14-01-13 23:32
0-60 mph = 4.0 sec
Normal, sunt din teste diferite. Dealtfel, de multe ori exista diferente mici de performanta intre modelele de Europa si cele de SUA.
Valorile de drag cele mai apropiate de realitate sunt aici:
http://www.zeperfs.com/en/duel4098-3281.htm
Fastestlaps este foarte ok pentru timpii pe circuite.
