-   Masina mea BMW - Alte serii (https://forum.4tuning.ro/123-masina-mea-bmw-serii.html)
-   -   E89 - Z4 DCT ALPIN WHITE - "my joy toy" (https://forum.4tuning.ro/123-masina-mea-bmw-serii/191874-e89-z4-dct-alpin-white-my-joy-toy.html)
///carbon 13-12-10 22:18
Re: E89 - Z4 DCT ALPIN WHITE - "my joy toy"
Originally Posted by ddannyeld2 (Post 3895469)
hahahah... laser!!!!
Wilgax 13-12-10 22:34
Arata intr-un mare fel cu jantele.TUB!:-)
edy1092 13-12-10 23:18
Pure luxury :D
morpheusmaster 14-12-10 00:23
Intra 10mm de distantier pe spate? Ar fi cireasa de pe tort!!!
///carbon 14-12-10 03:10
thanks... :)
Originally Posted by edy1092 (Post 3895680)
Pure luxury :D
you made my day!!!!!
no way they are yet rubbing.
morpheusmaster 14-12-10 11:45
OFFSET!!! /-o-\ <<< asa sa stea :X :X :X
///carbon 14-12-10 12:01
Asta e stance!
Offset e altceva! ;)
morpheusmaster 14-12-10 12:20
Originally Posted by ///carbon (Post 3896600)
Asta e stance!
:)) "stance" e ...un curent...si o expresie.
A inclina rotille >>>offset. Si nu zic de ala de la janta ;)
of of
///carbon 14-12-10 13:05
of of
Hahaha... Cum zici tu maestre!!!
morpheusmaster 14-12-10 13:15
Man, poate gresesc eu, poate am retinut terminologia gresit dar je stie ca ii zice "offset" la operatiunea de inclinare a rotilor. Daca gresesc, te rog corecteazama ca nu vreau sa mor prost :))
ce ai zis tu, stance, da, e un trend in tuning care se bazeaza pe wheelgap 0 (hellaflush), low & ...& offset.
Correct me!!!
P.S. Poti sa'i zici si negative camber...
///carbon 14-12-10 13:53
Correct me!!!
OMG... ar fi asa simplu. exista un site se chiama GOOGLE!!!!!
OFFSET:
The offset of a vehicle's wheel is the distance between the centerline of the wheel and the plane of the hub-mounting surface of the wheel. It can thus be either positive or negative, and is typically measured in millimeters. Offset has a significant effect on many elements of a vehicle's suspension, including suspension geometry, clearance between the tire and suspension elements, the scrub radius of the steering system, and visually, the width of the wheel faces relative to the car's bodywork.
Zero Offset - The plane of the hub mounting surface is even with the centerline of the wheel.
Positive Offset - The plane of the hub mounting surface is shifted from the centerline toward the front or outside of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative Offset - The plane of the hub mounting surface is toward the back or brake side of the wheel's centerline.
http://vw.zenseeker.net/Wheels/wheel_offset.jpg
CAMBER:
http://www.barrystyre.co.uk/cdata/27...41_893738i.jpg
tu compari mere cu pere.
morpheusmaster 14-12-10 14:01
ok.......
///carbon 14-12-10 14:58
https://www.youtube.com/watch?v=F23YWbLO5dY
///carbon 14-12-10 17:56
inca unu scurt....
http://s13.directupload.net/images/u...4/622xhmcy.png
https://www.youtube.com/watch?v=HJjRlMy5cqg
///carbon 14-12-10 19:27
EDIT:
https://www.youtube.com/watch?v=mD8WCnSPGdg
