Re: Sibiu, discutii off-topic
VAND Statie auto MTX Audio Model THUNDER 6500D
• 150 watts x 2 at 4 ohms • 250 watts x 1 at 4 ohms • 500 watts x 1 at 2 ohms • 775 watts dynamic power x 1 at 2 ohms • Adaptive Class D Technology • variable 40-200 Hz crossover, 24 dB/octave (since the amp is strictly for low-frequency reproduction, the crossover is always active) • preamp outputs • compression circuitry guards against overdriving speakers during loud musical passages at high sound-pressure levels • EBC2 port for multi-amp external control of bass boost • high preamp input capability (up to 8 volts) • PWM MOSFET switching power supply • gain control • Thunder EQ bass boost (0-18 dB at 40 Hz) • rubber Iso-Feet allow you to mount amplifier without the mounting screws contacting the amp's chassis • speaker-level inputs with SmartEngage (turns on the amp when it detects signal from the receiver, eliminating the need for a turn-on lead) Pret: 800 Ron Negociabil Detalii la telefon: 0742115680 |
e cam mare pretul..mai scade tati..cine vrea statie asa mare isi poate lua SIERRA DUVAL VT8000 de 1150 W RMS la 850 lei nou nouta si pe deasupra mai e si Stabila la 1 OHM..parerea mea e ca mai mult de 500 lei nu iei pe ea..si stiu pe cineva care ar fi interesat sa o cumpere...lasa-mi un pm cu nr tau...
pai daca dai si tu un search pe google si cauti "SIERRA DUVAL VT8000" nu prea gasesti detalli, iar in schimb daca dai mtx audio zic ca gasesti foarte multe detalii. iar de pret .. am scris negociabil tinand cont ca statia este NOUA! 150 euro eu zic ca e un pret bun.
2. Daca e noua inseamna ca oferi factura cu garantie 3. Mtx e Mtx totusi .. |
Pai de cand ii legea asta ca daca e noua trebuie si garantie si factura ? esti persoana juridica ptr factura ?
@mikeyexc esti cam in urma cu schimbarile
Eu cumpar de cativa ani pe persoana fizica,,,, si cand a fost vorba de garantie si factura...nu m-a refuzat nimeni pe motivul de "nu sunteti persoana juridica" Cand cumperi un frigider? trebuie sa fii persoana juridica ca sa ai dreptul la garantie? |
pai vezi ca faci o greseala, una e factura si una e bon fiscal :)
oricum stai relax. nu are factura si nici garantie. esti multumit ? fi am zis la pers. juridica de factura, nici decum de garantie. dar na sunt unii carcatosi si n-au ce face :D |
parerea mea este ca daca o cumperi noua totdeauna vei primi un certificat de garantie..iar daca tu vinzi statia ai mult mai multe sanse sa te creada lumea ca e noua...si stai relax ca stiu diferenta dintre un mtx si un sierra duval vt8000...iar statia e foarte ok...am vb cu mai multi specialisti care se ocupa doar cu (decibeli) si e mult mai ok...asta in cazul in care vrei sa ai muzica de ce sa dau 150 euro pe o statie care nici macar nu e stabila la 1 ohm si are 800 w (parca asa scria) si sa nu imi iau una nou nouta cu inca 50 euro in plus si sa am si garantie si sunet mai mare...poti sa vezi in masina la mine cum suna daca ne-o intalni cumva...si poate ai sa iti faci si tu o parere despre SIERRA-u ala care "nu are prea multe detalii"...PAREREA MEA
@mickey uitate putin pe net si vezi un pic cand a fost fabricata....e totusi 2002...are 9 ani vechime..sa nu imi spui ca 9 ani de zile nu a fost montata niciodata...eu unu cel putin nu cred asa ceva...pentru ca cine isi ia un amplif il monteaza cu siguranta..
Iti atasez cand vrei factura+garantie pe persoana fizica de la un amplificator Sony luat din magazin ! Ma rog .. fiecare cere cat crede pe produs dar asta nu inseamna ca o sa-l si vanda ! p.s. Vand si eu amplificator Sony clasa D 2x300RMS NOU cu factura+garantie 1 an si 8 luni (l-am probat pe masina o singura data!) Pret catalog 1200 ron ! |
@tino
iati prietene statie nou, nu te obliga nimeni sa cumperi statia mea. iar despre SIERRA .. fiercare isi lauda marfa .. si interenetul spune treaba asta cat de laudat ii sau nu .. dar din pacate nu este! ii greu sa traiesti cu adevarul. fiecare vrea sa fie cum vrea el. nu-i problema, ma bucur ptr statia ta. si sa-mi arati si mie difuzorul ala care il ai tu pe un ohm. nu trebuie live arata-mi-l in poza :) sunt curios. si mai arat-mi unde ai vazut ca statia mea e facut acum 9 ani. si iti garantez ca nu a fost montata pe nici o masina si nicaieri, nu a fost folosita. @SynTheLaZ nu neaparat iei factura. le e lor mai usor cu factura prietene .. dute la real si cumpara un electronic/electrocasnic si vezi ca nu iti da factura, iti da un bon fiscal. fiecare cum vrea. dar am mai spus-o si o mai spun, nu aveti altceva de facut si criticati pe altii.:nospam: |
Prietene... stii ce te sfatuiesc eu?
Sa cauti mai bine in acest topic si ai sa vezi ca exista un topic dedicat vanzarilor pe zona sibiului... Si nu ne strica buna dispozitie.. Nu crezi ca are dif de 1 ohm Tino? Te inseli |
mucea, sfatuieste mai bine pe unu de varsta ta !
Te rog sa iti revizuiesti comportamentul ! Uiti ca ai venit in comunitatea noastra si trebuie sa respecti niste reguli ! Cu siguranta nu esti tu cel care a pus coada la pruna, cel care le stie pe toate ! Te rog sa asculti si sfatul altora iar daca nu esti in stare cauta-ti te rog alt loc unde sa iti etalezi cunostintele ! Cel mai mult conteaza sa iti respecti aproapele dar din pacate unii stim numai sa cerem si nu avem habar cum si cand trebuie sa oferim ! Iti multumim ! |
mouse ii zici lu fiuto mai laba.
si cu asta am pus punct in fata la toti labarii care se baga inseamna doar ca sa scrie si si ei pe forum doar sa se arate. ca daca nu se arata nu se simt ca traiesc. |
| All times are GMT +2. The time now is 03:08. |
