-   BMW Styling (https://forum.4tuning.ro/642-bmw-styling.html)
-   -   *Style - E30 (https://forum.4tuning.ro/642-bmw-styling/44169-style-e30.html)
Bass-Evolution 10-08-09 18:53
Re: *Style - E30
nu stiu, dar asta pe care l-ai pus tu a mai fost, pus chiar de mine. Oricum aveti o problema cu acest "a mai fost"
dragos002 10-08-09 20:00
Re: *Style - E30
18 Attachment(s)
E foame mare de posturi pe forum .
noxe 11-08-09 06:59
Re: *Style - E30
au mai fost si astea care le-am pus ..:))) ...glumesc am ramas cu sechele de la paul..care alta treaba n-are =))
noxe 11-08-09 07:03
Re: *Style - E30
7 Attachment(s)
si astea ..:Dapp ...asta chiar ca-i frumusete
paul_cj,,,v12 11-08-09 10:18
Re: *Style - E30
da cred ca ai sechlele!! ce treba mah!!:rolleyes2carei pb ta !!:shock:
noxe 11-08-09 12:37
Re: *Style - E30
7 Attachment(s)
.............1...2 e deja 3 cheama liftu' fa repede un filtru daca ne permite timpu':D
2white e30 un ursuletz si o ursoaica :shock:
au mai fost :lol:
vasi..cj 11-08-09 22:27
Re: *Style - E30
E30 Cabrio :rolleyes::rolleyes:
Bass-Evolution 12-08-09 12:06
Re: *Style - E30
6 Attachment(s)
White Sensation.
Jante Sportmax.....
Enjoy.
bmw_fear 12-08-09 13:53
Re: *Style - E30
6 Attachment(s)
ENGINE
2.5 Litre S14 Blue Printed Motor
87mm Motorsport Crank
95mm JE Custom Ceramic Coated
Forged Pistons - 8.1:1 CR
Verdi 144mm H Beam Rods from PPF (along time ago Andreas. Do you remember?)
Cometic MLS Head Gasket
EVO III Oil Pump
Setrab Oil Cooler
Head Ported and Polished
EVO III Valve Springs
Re-seated Valves
248/248 Cams
VAC Motorsport Crank Sensor
VAC Motorsport Cam Sensor
E34 M5 TPS
ARP Head Studs
Earls Hoses and Fittings
Custom Made Ceramic Coated Turbo Manifold and Dump Pipe
Custom Made Stainless Steel Exhaust
Magnaflow 200CPI Metal Catalytic Converters
Garrett GT3076R .82 A/R Turbocharger
Tial 44mm Wastegate
Turbosmart Plumb Back BOV
Bosch 044 Motorsport Fuel Pump
Aeromotive Adjustable Fuel Pressure Regulator
Custom Made Surge Tank
Bosch 550cc Injectors
500x300x73 Alloy Intercooler
PWR Radiator and Spal Thermo Fan
Samco Hoses
Turner Motorsport Sump Baffle
Autronic SMC ECU
Autronic Direct Fire CDI 500R Ignition
Bosch Coils
Autronic Boost Controller
M Coupe Diff Cover
CHASSIS
Ground Control Coilovers
Ground Control Adjustable Camber Plates
Bilstein Shocks
Sparco Front Strut Brace
Solo-T Rear Strut Brace
Solo-T Rear Shock Mounts
Solid Steering Coupler
Braided Brake Lines
AC Schnitzer E30 M3 S3 3 Piece Rims
235/40ZR17 Toyo T1-R 's rear
215/40ZR17 Toyo T1-R 's front
EXTERIOR
Carbon Fibre EVO III Rear Spoiler
EVO II Front Spoiler
Carbon Fibre Front Splitter
Carbon Fibre EVO III Brake Ducts
Carbon Fibre DTM Cup Mirrors
INTERIOR
AC Schnitzer Steering Wheel
AC Schnitzer Pedal Set
AC Schnitzer Hand Brake
AC Schnitzer Gear Shift
Solo-T Short Shift Kit
Autometer Gauges
The car makes 270rwhp @ 9 psi. I am getting the tune finalised and will run it at around 14psi. Not sure what it will make then.
noxe 12-08-09 13:54
Re: *Style - E30
asta albu al tau merge cu ursoaica mea de mai jos:lol:
si ceva stil "american" ;)
on
pwr_bz 12-08-09 14:19
Re: *Style - E30
:arrow:
SiloS@1300 12-08-09 15:07
Re: *Style - E30
7 Attachment(s)
Am si eu nevoie daca stie cineva codurile la culorile urmatoare :
noxe 12-08-09 15:21
Re: *Style - E30
8)iti stiu masina...;) frumoasa chiar ti-am admirat-o la OMW acolo am vazut-o
sa-l stapanesti sanatos incontinuare;)
paul_cj,,,v12 12-08-09 16:45
Re: *Style - E30
V10 E30 M3
noxe 12-08-09 17:06
Re: *Style - E30
Originally Posted by paul_cj,,,v12 (Post 2553284)
V10 E30 M3
le stim...multumim frumos
on
