-   Scule-Echipamente Service (https://forum.4tuning.ro/528-scule-echipamente-service.html)
-   -   Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc (https://forum.4tuning.ro/528-scule-echipamente-service/119818-vand-polizor-dublu-masina-gaurit-coloana-electromotor-u650-alternator-u650-etc.html)
ellaghe72 21-08-11 20:54
re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
Up....
ellaghe72 28-08-11 20:01
Up....
ellaghe72 02-09-11 17:15
Up....
ellaghe72 08-09-11 07:43
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron
Alternator Volkswagen Jetta-S.H.-----------------------------90ron
Element filtru ulei avion(inoxidabil)---------------------------40ron
Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron
Mandrina 20/B22-fixare pe con morse----------------------40ron
Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron
Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron
Placute Widia------------------------------------------------5ron/buc
Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron
Polizor trifazic(380V) dublu PD 300------------------------430ron
Dulap metalic tip fiset---------------------------------------200ron
Dulap metalic 2 usi------------------------------------------400ron
Masina gaurit cu coloana(380V)---------------------------1200ron
Pompa picior(1cilindru)------------------------------------------12ron
Pompa picior(2cilindrii)-------------------------------------------22ron
Cutite strung vidia--------------------------------------------------5ron/buc.
Set placute vidia(10buc/blister)(12x12)---------------------------150ron
Semeringuri FARTEC-----110x130x13--------------10ron
------80x100x13----------------------------------------8ron
------50x70x10------------------------------------------7ron
-------35x50x8--------------------------------------------5ron
--------26x42x10------------------------------------------4ron
Manometru presiune0-250atm.-------------------------------------10ron
Manometru presiune 0-60atm---------------------------------------8ron
Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc
Cutite strung 10x10--------------------------------------------------5ron/buc
Stativ magnetic ceas comparator---------------------------------100ron
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron
Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron
ellaghe72 18-09-11 16:50
Up....
ellaghe72 22-09-11 00:20
Up....
ellaghe72 09-10-11 11:03
Up....
ellaghe72 12-10-11 19:48
Up....
ellaghe72 16-10-11 23:17
VAND MOTOR BENZINA,MOTOR ELECTRIC,POLIZOR DUBLU,MASINA GAURIT CU COLOANA,DIVERSE.
Vand:
Element filtru ulei avion(inoxidabil)---------------------------50ron
Mandrina rapida precisa 0-10mm(pe filet)-------------------40ron
Mandrina 20/B22-fixare pe con morse----------------------50ron
Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----200ron
Polizor trifazic(380V) dublu PD 300------------------------450ron
Masina gaurit cu coloana(380V)---------------------------1300ron
Cutite strung 10x10--------------------------------------------------10ron/buc
ellaghe72 21-10-11 17:41
Up....
ellaghe72 31-10-11 11:34
Up....
ellaghe72 03-11-11 10:08
Vand:
ellaghe72 07-11-11 13:46
Up....
hg 09-11-11 01:34
scuze de deranj, mai ai cumva, din greseala, o fotografie buna, in care sa se vada diagrama de avansuri de la strung?!
ellaghe72 09-11-11 19:28
Strungul nu mai este de actualitate.
