re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
pune o poza cu Biax MPPI-46
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Mandrina 20/B22-fixare pe con morse----------------------40ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------320ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------430ron Dulap metalic tip fiset---------------------------------------200ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Telef.0722.121.520 |
Element filtru ulei avion(inoxidabil)---------------------------40ron sunt interesat..as dori cate o poza cu fiecare... |
7 Attachment(s)
Avet foto dle.sharky-vw
Vand:
Salut nu te supara a-si fi interesat de biax .Nu vreau pietre la el sau alte accesori . il lasi la 1 mil? Astept un raspuns Salve
Aveti PM dle.BeWaRe
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Mandrina 20/B22-fixare pe con morse----------------------40ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------320ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------430ron Dulap metalic tip fiset---------------------------------------200ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Telef.0722.121.520 |
Up....
Poti pune te rog niste poze cu urmatoarele produse,scuze daca au mai fost postate pozele dar nu am urmarit topicul de la inceput
Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Manometru presiune 0-60atm---------------------------------------8ron |
10 Attachment(s)
Aveti foto dle.salfkm
Vand:
Up....
Up....
Up....
| All times are GMT +2. The time now is 20:26. |
