Go Back   Forum 4Tuning > Comunitati 4tuning locale > Comunitati locale si internationale 4Tuning > Oradea
Old 11-10-09, 08:16   #1
szoke_sz
szoke_sz's Avatar
Default daca aveti probleme la motor(benzina)
am deschis acest topic ca sa ne ajutam intre noi...
szoke_sz is offline   Reply With Quote
Old 12-11-09, 10:32   #2
CJ02VDV
CJ02VDV's Avatar
Default Re: daca aveti probleme la motor(benzina)
am la bmw e30 318 is,dupa ce se incalzeste motoru si il opresc min 2 min si repornesc motoru se ineaca si realantiu seara in sus si in jos.de ce?
https://www.facebook.com/dezmembrare.mab MASINI DEZMEMBRATE BMW E30 E34 E36 SI ALTE MODELURI LA COMANDA,RENAULT 21 SI GOLF 3
CJ02VDV is offline   Reply With Quote
Old 12-11-09, 10:33   #3
sandor406
Dacia Driver
sandor406's Avatar
la mine la dacie 1310 li, da in nas si in relanti si cand o bruschez!(
sandor406 is offline   Reply With Quote
Old 12-11-09, 10:47   #4
CJ02VDV
CJ02VDV's Avatar
cu mers nare bai ,dupa ce dau 2-3 talpa revine,dar in oras te bate capu sa nu ramai in trafic daca joaca relantiu
Old 12-11-09, 16:22   #5
szoke_sz
szoke_sz's Avatar
prima data verifici aprinderea...astfel: rotesti volanta la 0 grade cu ajutorul cheii de la roate..bagi sub radiator direct in fulie, daca nu atunci rotesti direct cu cheue de 19...ai o gaura pe cutie unde vezi volant...pe volanta exista un semn... pui la 0 grade
dupa aia dai jos capcu de delcou, slabesti surubul de avans si rotesti sa aiba platina cea mai mare deshidere..reglezi la 0.7-0,8mm, pui totu la loc si dai contact..mist din avans stanga drapta pana obtii scanteie...fixez totu laloc si est gata.. fixezi delcoul la poz care da scanteie fis centrala...(apropii fisa centrala de la dist. de 50mm la ceva metalic..)
Old 12-11-09, 22:30   #6
szoke_sz
szoke_sz's Avatar
dupa aia dai jos capcu de delcou, slabesti surubul de avans si rotesti sa aiba platina cea mai mare deshidere..reglezi la 0.7-0,8mm, pui totu la loc si dai contact..mist din avans stanga drapta pana obtii scanteie...fixez totu laloc si est gata.. fixezi delcoul la poz care da scanteie fis centrala...(apropii fisa centrala de la dist. de 50mm la ceva metalic..)[/QUOTE]
Old 12-11-09, 22:33   #7
szoke_sz
szoke_sz's Avatar
curata clapeta la soc cu smirghel...si asigura te ca functioneaza corect..uita te la evacuare ,cand ineaca nu scoate mai mult fum ca de obicei? daca scoate este problema de amestec..verifica socul ce este o piesa mobila care imbogateste amestecul, si daca se intanpla la motorul cald se ineaca
daca nu e socul va fi o sonda ....verifica daca nu sunt fire intrerupte sau mufe slabite
Old 14-11-09, 16:31   #8
CJ02VDV
CJ02VDV's Avatar
azi am schimbat bujile bosch pe Ngk,ce e nou ca scoate miros de benzina,ar fi sonda landa??
Old 14-11-09, 16:44   #9
sandor406
Dacia Driver
sandor406's Avatar
mai szoke sz! poi tu dai acelasi sfat si pentru bmw si si pentru dacia mea? seamana un bmw cu dacia mea? poi mai citeste si tu peacolo, ca la mine ii dacia 1310 LI , ceea ce inseamna cai pe injectie! nu am delcou ca la daciile pe carburator?!doamne! si ce sa invart de el?) esti meserias ca si mine cred ca!) si sa numi zici ca mai esti si ungur, ca ma faci de ras!!!(
Old 14-11-09, 22:27   #10
szoke_sz
szoke_sz's Avatar
eu as incepe cu acest lucru la ambele masini.. ...ai specifacat cumva ca masina ta e DIESEL???? daca e benzinar ai DELCOU....sau distribuitor.daca te crezi mare destept explica-mi cum functioneaza masina pe benzina fara scanteie? daca zici ca nu are delcou??
Old 14-11-09, 22:30   #11
szoke_sz
szoke_sz's Avatar
asta inseamna ca bujia e scuipata....pot fi 2 cauze...nu ai amestec ca lumea..la acesta poate fi cauza si sonda lambda..si alte 20 de lucruri sau nu ai scanteie bune
Old 15-11-09, 10:38   #12
sandor406
Dacia Driver
sandor406's Avatar
mai omule, a mea ii pe benzina! eu inca nu am auzit dacia 1310 li pe diesel!??? in fine! iar delcoul nu este ca la modelele vechi de invarti de ele, si prostii dealea! la asta te puteai gandi tu mai inainte! delcoul meu este fix! eu nu am zis/scris ca nu am delcou! ti-am precizat ca nu am delcou ca la daciile pe carburator!!! deci...nu mai zic nimik! unu' care se pricepe la masini, ala numa cand aude modelu masinii stie cu se inceapa! nu cand aude dacie, ooo, sarma , ciocan , surubelnita si ii gata! bafta in continuare!
Old 15-11-09, 10:48   #13
szoke_sz
szoke_sz's Avatar
ma tu esti habarnist...mecanismul de aprindere la tine e identic ca la alte dacii, difernta e ca ai un regulator electric...si ca in locul bobinei de inductie ai transformator...avansul se poate regla orice la aprindere ...regleaza-ti masina ta fara delcou cum vrei...cacatul oricum cacat ramane
Old 15-11-09, 10:51   #14
sandor406
Dacia Driver
sandor406's Avatar
esti chiar prost ma, pe bune!tu ziceai acolo sus sa invart de delcou pana se regleaza ?!poi delcoul meu este fix nu se poate invarte mah! tu ai mai vazut vreodata dacie pe injectie??? sau teai facut meserias la apelu de seara?sau macar esti cv meserias? sau teai gandit sascrii aici, sa nu stai degeaba?doamne!( si ai dreptate, un cacat ca t...e tot cacat ramane!!!!))
Old 15-11-09, 11:07   #15
szoke_sz
szoke_sz's Avatar
deschide ochii ,si daca esti destept gaseste metoda sa reglezi avansul..eu sunt sigur ca se poate regla, dar fiind ca tu esti habarnist nu vezi cum trebuie..si ma stresezi pe mine aci ca nu stiu din cap cum arata cacatul tau de 500 ron pe de rost, dar eu sunt sigur dac as vedea as gasi metoda..eu cum am precizta mai sus sa verifici aprindere este valabil aproape pt orice tip de aprindere
si nu terbuie sa vad dacii pe injectie, ca nu-s curios ..arata, functioneaza,si rugineste la fel de bine ca 1300-ul ...numai ca au pus ceva electronica aiurea in ea
