Go Back   Forum 4Tuning > Car Styling > CAR STYLING
CAR STYLING Cele mai reusite proiecte de styling prezentate in amanunt si supuse votului tau
Old 06-05-08, 03:15   #1
Nautilus
Default 100% fibra de carbon - Lancia/Zagato Hyena
Masina: Lancia/Zagato Hyena, 1993-1996, 26 de exemplare fabricate
Mecanica este aceeasi cu a Lanciei Delta Integrale Evo, caroseria deriva din ideile studioului de design Zagato si ale unui dealer olandez care credea ca Lancia Delta nu e destul de sportiva (!)
Greutatea e redusa cu ~150-200kg fata de Lancia Delta Integrale Evo, prin utilizarea panourilor exterioare de aluminiu si carbon/kevlar, masina avand numai 1148kg, de unde un timp de acceleratie 0-100 km/h de 5-5.75 secunde
Interiorul e lucrat din fibra de carbon. Toate componentele din fibra de carbon costa cam 7500 USD/masina si cantaresc 5kg
Comparatie intre greutatea componentelor unei Delta de serie / Hyene:
Panou de usa...2,5kg / 0,7kg
Tunel central...4,0kg / 0,8kg
Bord...............17kg / 2,5kg
~Nautilus
Nautilus is offline   Reply With Quote
Old 10-06-08, 10:00   #2
Nautilus
Default Re: 100% fibra de carbon - Lancia/Zagato Hyena
Din exterior masina arata cam asa:
~Nautilus
Old 10-06-08, 23:09   #3
topser
Fiat Driver
topser's Avatar
interesanta masina , nu stiam de existenta ei...
topser is offline   Reply With Quote
Old 16-08-08, 11:28   #4
markizu
markizu's Avatar
[Honda]
masina din cate stiu s-a comercilizat sub numele de Zagato Hyena dupa numele celebrului tuner olandez ....
citat :
''The Integrale based Hyena was built in collaboration between the Lancia importer for The Netherlands Paul Koot and Zagato. The Hyena was designed in 1990 by Marco Pedracini (Zagato), and introduced at the Brussels Motor Show in January 1992.[6] The Hyena was based on the Delta Integrale floorpan structure, but with a 2-door coupe body. Integrales were stripped down in Holland and then sent to Zagato in Italy to have the new composite/alloy body fitted. They were then sent to back to Holland for final assembly. All of this made the Hyena very expensive to build and they were sold for around $75,000.[7] The Hyena weighed around 200 kilograms (440 lb) less than original Integrale and had around 250 brake horsepower (190 kW) and could accelerate from 0-100 km in 5.4 seconds.[8] Only 24 were built."
Fiat tempra 1.6 ien aprox 110 cai (gone)
Lancia Delta II 1.8 132 hp ..(gone)
Alfa 156 1.8 ts 150 hp (great feeling, gone)
Golf III Rabbit 1.4 mic si rau..(gone )
Honda del Sol 1,6 soch vtec turbo on !!
markizu is offline   Reply With Quote
Old 18-08-08, 11:42   #5
Nautilus
Daca la introducerea ei in oferta se vindea cu 75 000 USD, ultimele exemplare, livrate in 1995-1996, ajunsesera la 128 000 USD
~Nautilus
Old 24-08-08, 12:42   #6
adi_wauxhall
adi_wauxhall's Avatar
interesanta jucarie...simpla..puternica...
adi_wauxhall is offline   Reply With Quote
Old 25-08-08, 13:58   #7
markizu
markizu's Avatar
[Honda]
tot zagato a facut si modificare la alfa 155 ...
https://www.youtube.com/watch?v=nyT4w...eature=related
si pot continua ... cu lancia motecarlo ,etc
Old 07-09-08, 20:45   #8
silebmw
silebmw's Avatar
cat costa fibra?
silebmw is offline   Reply With Quote
