Old 08-06-10, 16:32   #1
alindum
alindum's Avatar
Default E30 - vvv
320i - '85 ... aproape stock
ID:	1510077   Click image for larger version
ID:	1510078   Click image for larger version
ID:	1510080   Click image for larger version
ID:	1510081   Click image for larger version
ID:	1510083   Click image for larger version
ID:	1510084   Click image for larger version
alindum is offline   Reply With Quote
Old 08-06-10, 16:36   #2
pwr_bz
pwr_bz's Avatar
Default Re: E30-vvv
Arata bine domnul!
Ce planuri ai cu furia rosie pt viitor?
Bafta pe viitor cu proiectul sa speram ca iese ceva frumos!
Ai multe exemple pe forum de unde te poti inspira si culege numai lucruri bune si sa scoti ceva frumos din ursulet!
pwr_bz is offline   Reply With Quote
Old 08-06-10, 16:47   #3
RideTheRiddle
RideTheRiddle's Avatar
Default Re: E30-vvv
stock sau nu arata foarte bine ursache asta al tau. l-am vazut de multi ori cocotat pe trotuar, dar parca sa zic ca avea alte jante, sau ma insel eu?
RideTheRiddle is offline   Reply With Quote
Old 08-06-10, 17:21   #4
alindum
alindum's Avatar
Default Re: E30-vvv
Originally Posted by pwr_bz View Post
Arata bine domnul!
Planurile sunt aproape de final in privinta aspectului exterior ... mai lipseste doar o toba finala de urs stock si o vopsea , tot rosu , normal ...
Proiectul este de a aduce masina la stadiul initial .
Ursul asta a intrat in posesia mea sub forma de caroserie fara geamuri , bonus 200kg de zapada in interior si un bloc motor in portbagaj in 1997 ...
in '99-2000 deja mormaia prin Craiova ...
ID:	1510135   Click image for larger version
ID:	1510136   Click image for larger version
Old 08-06-10, 18:32   #5
myky99
myky99's Avatar
Default Re: E30 - vvv
bun bun ..usor usor revine la starea lui initialabrava
myky99 is offline   Reply With Quote
Old 08-06-10, 19:02   #6
alindum
alindum's Avatar
ms , erau tot astea dar sub alta forma
sa cresti mare
in starea asta a reintrat in posesia mea dupa 6 ani de despartire (2004-2010) timp in care ii pierdusem urma ...
ID:	1510291   Click image for larger version
Old 08-06-10, 19:04   #7
EmyM6
EmyM6's Avatar
bine ai venit printre noi pasionatii de bmw.
sa il stapanesti sanatos si fara incidente.bafta
EmyM6 is offline   Reply With Quote
Old 08-06-10, 21:10   #8
Gabi
Super Moderator
Gabi's Avatar
Originally Posted by alindum View Post
[...] dupa 6 ani de despartire (2004-2010) timp in care ii pierdusem urma ...
Cine ţi-o fi arătat anunţul ?
Gabi is offline   Reply With Quote
Old 08-06-10, 23:43   #9
alindum
alindum's Avatar
am ramas dator o bere mare ... si daca o mai lungim mult se preschimba in whisky...
Old 09-06-10, 00:38   #10
Calin_CGM
Calin_CGM's Avatar
frumos ursu...ar merge un kit m technik 1 pe el...oricum arata bine...bafta!
Calin_CGM is offline   Reply With Quote
Old 09-06-10, 00:50   #11
yonutz85
yonutz85's Avatar
Foarte frumos ursachele tau! Daca vrei sa modifici ceva la el,de preferinta sa fie pe partea tehnica. Mai rar vezi un urs stock care sa arate asa de bine ca al tau,majoriatea celor ingrijiti avand kituri M. La aspect: o vopsea si niste jante mai late in ton cu anii masinii si cam atat. O masina mai veche dar care arata ca si cum ar fi iesit pe poarta fabricii are farmecul ei aparte...
RC-ul il mai ai?
performante >functionalitate >aspect
yonutz85 is offline   Reply With Quote
Old 09-06-10, 02:28   #12
alindum
alindum's Avatar
ms ,
imi place foarte mult stock...cel putin deocamdata...
RC-ul il mai ai?
ms ,
RC'ul dupa ce a ramas fara motor si-a schimbat proprietarul...
Old 09-06-10, 17:09   #13
MiTzA-
MiTzA-'s Avatar
Default Re: E30-vvv
pozele sunt facute pe traseul de la bucovat ?
MiTzA- is offline   Reply With Quote
Old 09-06-10, 17:16   #14
myky99
myky99's Avatar
Default Re: E30-vvv
da...
Old 11-06-10, 01:28   #15
alindum
alindum's Avatar
incet incet se completeaza si la interior ...
ID:	1514102   Click image for larger version
