Old 29-03-11, 07:32   #1
liviu_e30
liviu_e30's Avatar
Default o noua achizitie e30
salutare ce imi pueti spune de aceasta masina cei care stiti cate ceva de ia sau care ati mai vazuto .Masina cam trebui reconditionata exterior+interior pt ca si-au batut joc in ultimul hal de ia masina a fost loata de la Focsani si am nevoie de un sfat de la voi masina e 1,8 in acte si pe masia e 2,5 12 v si vreau sa o trec pe numele meu eu intentionez sa ii pun un 1,8 jante pe 14 si fuga la rar voi ce parere aveti? CAM ASA ARATA
ID:	1939791   Click image for larger version
ID:	1939792   Click image for larger version
ID:	1939794   Click image for larger version
ID:	1939795   Click image for larger version
ID:	1939797   Click image for larger version
ID:	1939798   Click image for larger version
ID:	1939800   Click image for larger version
ID:	1939801   Click image for larger version
ID:	1939803   Click image for larger version
ID:	1939804   Click image for larger version
ID:	1939806   Click image for larger version
ID:	1939807   Click image for larger version
ID:	1939809   Click image for larger version
ID:	1939810   Click image for larger version
ID:	1939812   Click image for larger version
ID:	1939813   Click image for larger version
ID:	1939815   Click image for larger version
ID:	1939816   Click image for larger version
ID:	1939818   Click image for larger version
ID:	1939819   Click image for larger version
ID:	1939821   Click image for larger version
ID:	1939822   Click image for larger version
ID:	1939824   Click image for larger version
ID:	1939825   Click image for larger version
liviu_e30 is offline   Reply With Quote
Old 29-03-11, 07:35   #2
liviu_e30
liviu_e30's Avatar
Default Re: o noua achizitie e30
imi trebui urmatoarele piese faruri originale cu lupa interioru di porbagaj
Old 29-03-11, 18:48   #3
madalin_pyf
madalin_pyf's Avatar
salut
e cam belea exact asa am avut eu mi-am cumparat un urs 318 is ok in acte si pe el avea 2.5 si a trebuit sa o inmatriculez pe numele meu
NU AM AVUT CE SA II FAC A TREBUIT SA II OMOLOGHEZ MOTORU sau mai exista o varianta daca ai pe cineva la rar si sa o rezolvi acolo cu AUTENTIFICARE
mult succes
madalin_pyf is offline   Reply With Quote
Old 29-03-11, 19:35   #4
erhabe
erhabe's Avatar
in primul rand felicitari ,pentru faptul ca ai kit-ul complet de bari m 1 , la ea ,in rest masina arata bine la varsta ei ,trebuie sa ai motorul la ea daca in acte e 1.8 sa poti sa o treci pe numele tau....asa stiu eu...
erhabe is offline   Reply With Quote
Old 29-03-11, 19:37   #5
liviu_e30
liviu_e30's Avatar
io ma gandeam sa imi cumpar un 1,8 sa il pun si sa il trec in acte io zic ca e mai ok
Old 29-03-11, 20:04   #6
madalin_pyf
da merge sa incerceci si asa dar cel mai bine banii pe care ii dai pe motor mai bine vb cu cineva la rar si te trece asa si lasi 2,5
e alegerea ta gandesta-te bine fa-ti socotelile cum iesi mai bine si aia e
in rest succes cu masina si sa o stapanesti sanatos multi multi km
Old 30-03-11, 06:53   #7
liviu_e30
liviu_e30's Avatar
multumesc
Old 30-03-11, 07:06   #8
liviu_e30
liviu_e30's Avatar
am o mica problema cu masina masina sta ok la relani iar cand pleci de pe loc zici ca nu se alimenteaza nu se tureaza mai mult de 4000 rot min zici ca nu se alimenteaza merge ce merge asa si deodata se duce in limitare cand am venit cu ia de la focsani mi-sa oprit de 3 ori pe drum
Old 31-03-11, 18:35   #9
alexandru320
foarte frumoasa masina.... mai ales.... mt1
succes cu inmatricularea
alexandru320 is offline   Reply With Quote
Old 31-03-11, 19:02   #10
DEVIL's Style
DEVIL's Style's Avatar
[Toyota]
Verifica pompa de benzina !
DEVIL's Style is offline   Reply With Quote
Old 28-04-11, 14:32   #11
liviu_e30
liviu_e30's Avatar
se vinde care e interesat pret discutabil
Old 29-04-11, 11:14   #12
gxg_85
salut.masina a plecat din iasi.a fost a mea vreo 4 ani.eu am facuto asa.cand a plecat de la mine nu avea nici un defect.a fost refacuta complet si vopsita la bmw.din pacate nu poti scoate fiscalu la ea.eu am tinuto asa.proprietaru din acte e din iasi daca vrei iti pot da un nr de tel.
gxg_85 is offline   Reply With Quote
Old 29-04-11, 11:16   #13
gxg_85
vezi ca ai o mufa in partea din stanga a motorului parca mufa de la injectoare.aia mai face figuri.
Old 29-04-11, 11:21   #14
gxg_85
motoru de 1.8 nu mai este eu l am schimbat.chilomeri la ea sunt reali.masina a stat f mult pe dreapt in iasi pana am luato eu.trebuie sa schimbi grupul.e prea scurt 4.10 e de pe 1.8
Old 02-05-11, 06:48   #15
liviu_e30
liviu_e30's Avatar
masina nu se mai vinde
