Go Back   Forum 4Tuning > Tuning Motor & Mecanica > Dyno Tuning > Exelixis Motorsport
Old 26-02-13, 18:07   #1
Exelixis
Exelixis's Avatar
Default Nissan GTR R35 EXL850R
Faptul ca modificam cu succes GTR-uri R35 nu mai este un secret pentru nimeni.
Folosindu-ne de experienta acumulata am decis ca este momentul sa structuram in pachete specifice configuratiile pe care le putem oferi clientilor nostri.
Masina de mai jos beneficiaza de pachetul EXL850R.
Aceasta este cea mai puternica configuratie atunci cand se doreste pastrarea motorului stock.
Componentele de baza ale pachetului sunt:
Turbine Exelixis hybrid
Injectoare de 1050cc
Greddy suction pipe kit
Forge Motorsport BOV kit
Forge Motorsport intercooler kit+piping
Senzori MAP 4bar AMS
Bobine Okada Plasma Direct
Pompe de benzina Walbro x 2
Downpipeuri custom Exelixis
Aditional in cazul specific al acestui proiect s-a optat pentru:
Acoperire ceramica a galeriei de admisie by Zircotec
Evacuare catback Greddy 94mm din titan
Diferential fata Quaife
Discuri frana fata AP Racing si placute Ferodo DS2500
Pentru a face fata puterii dezvoltate de motor cutia de viteze a fost intarita cu repere furnizate de catre Dodson Motorsport si Pfitzner Performance Gearboxes impreuna cu kitul de oilcooler pentru cutie Forge Motorsport.
ID:	2702735   Click image for larger version
ID:	2702736   Click image for larger version
ID:	2702738   Click image for larger version
ID:	2702739   Click image for larger version
ID:	2702741   Click image for larger version
ID:	2702742   Click image for larger version
ID:	2702744   Click image for larger version
ID:	2702756   Click image for larger version
ID:	2702758   Click image for larger version
ID:	2702759   Click image for larger version
ID:	2702761   Click image for larger version
ID:	2702762   Click image for larger version
ID:	2702764   Click image for larger version
ID:	2702766   Click image for larger version
ID:	2702776   Click image for larger version
ID:	2702777   Click image for larger version
ID:	2702779   Click image for larger version
ID:	2702780   Click image for larger version
ID:	2702782   Click image for larger version
ID:	2702783   Click image for larger version
ID:	2702794   Click image for larger version
ID:	2702795   Click image for larger version
ID:	2702797   Click image for larger version
ID:	2702798   Click image for larger version
ID:	2702800   Click image for larger version
Exelixis is offline   Reply With Quote
Old 28-02-13, 17:27   #2
Exelixis
Exelixis's Avatar
Default Re: Nissan GTR R35 EXL850R
Pentru gestiunea electronica a acestui proiect s-a folosit un sistem tip stand-alone Syvecs S8.
Masina beneficiaza de 3 softuri diferite (1,2bar, 1,4bar, 1,8bar) plus alte cateva functii aditionale cum ar fi: ALS, rolling ALS, controlul tractiunii cu posibilitatea ajustarii de catre utilizator si logarea automata a parametrilor de functionare in cicluri de 24 de ore.
Cele 3 softuri custom au fost furnizate ca si pana acum de catre ZOD Development, partenerul traditional al Exelixis Motorsport pentru resoftarea sistemelor tip stand-alone.
ID:	2704805   Click image for larger version
ID:	2704806   Click image for larger version
ID:	2704808   Click image for larger version
ID:	2704809   Click image for larger version
ID:	2704811   Click image for larger version
ID:	2704812   Click image for larger version
ID:	2704814   Click image for larger version
ID:	2704817   Click image for larger version
ID:	2704819   Click image for larger version
Name:	DIN corrected Engine power 1,2bar.jpg
ID:	2704820   Click image for larger version
Name:	DIN corrected Engine power 1,4bar.jpg
Name:	DIN corrected Engine power 1,8bar.jpg
Old 28-02-13, 22:11   #3
WPP
WPP's Avatar
nice
keep up the good work
WPP is offline   Reply With Quote
Old 01-03-13, 11:20   #4
Exelixis
Exelixis's Avatar
Multumim frumos!
In cateva zile speram sa fie gata ceva frumos legat de acest proiect.
Old 04-03-13, 14:29   #5
Alex23
Alex23's Avatar
[Style in Motion]
Sa intelegem ca Exelixis Motorsport a devenit si fabricant de turbine?????? Daca da puneti si voi o lista ceva pt mai multe modele.
Alex23 is offline   Reply With Quote
Old 04-03-13, 14:54   #6
Exelixis
Exelixis's Avatar
Corect ar fi fost sa intelegi ca turbinele au fost dezvoltate de catre o terta firma conform cerintelor noastre si nu le vei gasi de cumparat ca si produs standard la vreun furnizor, asa cum poti comanda marea majoritate a turbinelor de pe piata.
Old 05-03-13, 18:45   #7
squid
squid's Avatar
[Street 4 Cars]
867CP/988NM cu interne stock?!
Asta da masina.
squid is offline   Reply With Quote
Old 06-03-13, 08:39   #8
Alex23
Alex23's Avatar
[Style in Motion]
Corect ar fi fost sa scrieti asa: "Turbine xxxxx facute cu specificatii Exelixis"
Nu e corect sa scrieti "turbine exelixis" cand ele sunt facute de alta firma!!!!!
Cred ca nu e corect....... cine citeste va mai si crede!!!
Old 06-03-13, 09:39   #9
Exelixis
Exelixis's Avatar
@ squid - da, interne complet stock de la prima pana la ultima piulita
@Alex23 - faptul ca tu nu intelegi corect nu inseamna ca noi am gresit cu ceva. Fiecare intelege cat si cum poate, noi nu judecam pe nimeni.
Old 08-03-13, 16:04   #10
Exelixis
Exelixis's Avatar
EXL 850R - Highlights Part1
Old 11-03-13, 09:51   #11
gollum_
gollum_'s Avatar
Thumbs up Re: Nissan GTR R35 EXL850R
Felicitari EXL Team pentru acest proiect. Basca e si pentru EXPORT
gollum_ is offline   Reply With Quote
Old 11-03-13, 16:29   #12
Exelixis
Exelixis's Avatar
Multumim, multumim!
Pai numai ei sa exporte la noi castraveti in otet si zacusca? Sa le oferim si noi ceva in schimb...masini rapide
Old 12-03-13, 10:38   #13
Exelixis
Exelixis's Avatar
EXL 850R - Highlights Part2
Old 12-03-13, 20:35   #14
Kolegosu'
Kolegosu''s Avatar
Felicitari Exelixis, inca un GT-R ce se poate mandri cu badge-ul powered by Exelixis Motorsport!!!
Kolegosu' is offline   Reply With Quote
Old 14-03-13, 21:43   #15
Exelixis
Exelixis's Avatar
Se pare ca sezonul de abia a început
