Magnat Tribal X1 2KW
amplificator monobloc pentru subwoofer
putere:
4 ohmi: 350W RMS (750W max)
2 ohmi: 500W RMS (1250W max)
1 ohm: 700W RMS (1800W max)
impedanta suportata: 1-8 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
THD < 0,05% (1kHz)
intrare de linie 0,25V - 4V
filtru low pass variabil 40-300 Hz (12 dB)
filtru subsonic (high pass) 10-40 Hz (12 dB)
bass boost variabil 12dB la 45 Hz
circuit de protectie la supraincalzire si scurtcircuit
Subwoofer Audiotop ECP 15.4
Type passive subwoofer
Standard size 15 "(38 cm)
Number of bands 1
Rated Power (RMS) 400 W
Maximum Power 800 W
Frequency 28-180 Hz
Impedance 4 Ohm
Built-in amplifier no
Housing yes
Enclosure Type vented
Number of speakers 1
Speaker dimensions 380 mm
Dimensions (WxHxD) 690 × 390 × 425 mm
PRET 850RON
tel: 0765.586.262
