Vand amplificator 5 canale DLS Classic CA51 + subwoofer FOCAL Polyglass SB 27 V1
Amplificator DLS Classic CA51:
Nominal power output in 4 ohm (0,1% THD) : 4 x 50 W
Typical power output in 2 ohm (0,2% THD) : 4 x 80 W
Typical power output mono channel in 4 ohm : 150 W
Typical power output mono channel in 2 ohm : 225 W
Frequency range : 10 Hz - 35 kHz
Input sensitivity, variable : 0,25 - 5 V
High level input with auto start: Yes
Low level output: No
Filter channel A & B: HP: 15-500 Hz. LP: 50-500 Hz / 05 - 5 kHz (x10)
Filter channel C & D: HP: 15-500 Hz / 150 Hz - 5 kHz (x10).
Filter channel E: LP: 60 - 120 Hz + subsonic 25 Hz
Phase control 0 - 180 degrees: Yes
Fuse value : 3 x 30 A
Dimensions H x D x B: 67 x 419 x 250 mm
Pret: 700 lei
Subwoofer FOCAL Polyglass SB27 v1:
Nominal power handling: 250W
Sensitivity (2.83 V / 1 m): 90dB
Frequency response: 36Hz - 500Hz
Impedance: 4 ohm
Pret: 400 lei
Preturi negociabile.
Sunt in perfecta stare de functionare, instalate pe masina.
