Helix dark blue 2
Power RMS / Musik at 2 x 4Ohm at 13,8 Volt: 2 x 80/160 Watt
Power RMS / Musik at 2 x 2Ohm at 13,8 Volt: 2 x 120/240 Watt
Power RMS/Musik 1 x 4 Ohm bridged: 1 x 200/400 Watt
Total harmonic distortion: < 0,03%
Signal to noise ratio: > 93 dB
Bassboost adjustment : 0-18 dB
Frequency range Highpass: 15 Hz-4 kHz
Frequency range Lowpass : 40 Hz-4 kHz
Frequency range Bandpass: 15 Hz-4 kHz
Frequency range: 10 Hz-30 kHz
TIM distortion: < 0,04%
Input sensitivity: 200 mV - 8 V
Fuse: 1 x 30 A
Input impedance: 10 kOhm
Dimensions (H/W/D) in mm: 64 x 245 x 310
Weight netto: 3,6 kg
HELIX SINGLE DARK BLUE 12
Power - 250/500 W
Sensitivity - 90 db
Impedance - 4 Ohm
X W x H - 385 x 440 x 410 mm
Import germania stare foarte buna
pret pachet :450 lei
