Sistem audio format din urmatoarele:
Amplificator Ground Zero Uranium GZUA 1.1600D
amplificator subwoofer, 1 canal clasa D MOSFET
putere RMS:
1 x 500W @ 4 ohm (14.4V),
1 x 800W @ 2 ohm (14.4V),
1 x 1200W @ 1 ohm (14.4V),
1 x 1600W @ 1 ohm (16V),
THDL 0.01%
S/N Ratio: >75dB
Damping Factor: >200 (@ 100Hz)
Fuse: External 150A
Dimensions: 13" x 9.5" x 2.2" (33cm x 24.2cm x 5.6cm)
Subwoofer
subwoofer dual 12"
diametru difuzoare: 30cm
tip incinta: bassreflex
impedanta: 2 ohmi
putere RMS: 800W
putere Max: 1600W
raspuns in frecventa: 25Hz - 100Hz
Dimensions: 32-3/8" W x 16" H x 17-3/8" D (Bottom) x 13-15/16" D (Top)
Pret - 1700 ron neg..
Produsele sunt cumparate din magazin folosite circa juma de an... daca vrei sa ai muzica adevarata ca la concert si un bass de dezmembreaza masina...
nu ezita!
