Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Pachete Audio: Statie+Sub, HU+difuzoare, etc
Pachete Audio: Statie+Sub, HU+difuzoare, etc Pachete Audio: Statie+Sub, HU+difuzoare, etc
Old 18-03-13, 22:50   #1
miniMo
miniMo's Avatar
Cool vand/schimb pachet audio auto de putere
Pachetu este format din:
1- Amplificator Ground Zero Nuclear GZNA 2600
Class a/b
250rms x 2 at 4 ohm
400rms x 2 at 2 ohm
600rms x 2 at 1 ohm
800rms x 1 at 4 ohm bridged
1200rms x 1 at 2 ohm bridged
4 x 40a fusing
2-Difuzor Audio System Helon 15 SPL 2000w rms
2x 1500/1000 Watt
10.000 Watt Peak > 60Hz
Impedance 2x 2 Ohm
Weight: 24kg
Installation depth: 218mm
3- Se adauga cablul de plus,cablul de minus si soclu cu siguranta ANL de 200A.
Sistemul este montat pe masina si se da cu tot cu incinta,se ofera proba inainte ca sa se vada ca functioneaza impecabil fara nici o problema...
Pretul este de 2100 ron...este negociabil in limita bunului simt...
Schimburi ma intereseaza doar cu un alt sistem mai mic +diferenta...ma intereseaza ceva pe la 1000-1200w rms maxim...
Un filmulet cu ce poate subwooferul : https://www.youtube.com/watch?v=ZARVzJRNfTI
Contact
Nr:0766512553
ID:	2722811   Click image for larger version
ID:	2722812   Click image for larger version
ID:	2722814   Click image for larger version
miniMo is offline   Reply With Quote
Old 24-03-13, 11:09   #2
miniMo
miniMo's Avatar
Default Re: vand/schimb pachet audio auto de putere
pretul scade la 2050 ron....
Old 15-04-13, 12:49   #3
miniMo
miniMo's Avatar
2000 ron...
Old 20-05-13, 11:01   #4
miniMo
miniMo's Avatar
1900 ron
Old 07-08-13, 15:38   #5
miniMo
miniMo's Avatar
valabil in continuare...pretul scade
