mplificator Dls Monoblock D1000 Mono 1000w
Power output in 4 ohm (0,3% THD) : 350 Watts
Power output in 2 ohm (0,5% THD) : 700 Watts
Power output in 1 ohm (1 % THD) : 1000 Watts
Dimensions H x W x D : 65 x 407 x 240 mm
Frequency range : 15 Hz - 160 Hz
Input sensitivity, variable : 0,2 - 6 V
Bass bost : 0- +18 dB
Lowpass crossover : LP: 35 - 250 Hz
Subsonic filter : 15 - 35 Hz
Power consumption, idle : 0,9 A
Maximum power consumption : 97 A
Weight : 5,4 kg
PL DYNAMICS PRO-12D4
300mm (12")
1400 Watt Paek, 700 W/RMS
2 x 4 Ohm
bobina 65 mm (2,5")
Fs 29 Hz
Vas 54 L
Xmax (lin/peak) 17/34 mm
SPL (1W/m) 86,8 dB
Condensator Rodek Ro10hc 10 F
pret- 1400 ron neg
