Pachet format din HELIX SPXL, SinusLive sla 1500v2 si ALPINE CDA-9855R
Pret pachet - 3000 lei.
relatii la telefon 0751488830
ALPINE CDA-9855R
Product Information
Take a close look at CDA-9855's faceplate, and you might find yourself saying in surprise, "Hey — there are no preset buttons!" And you're right — instead, there's only a simple, white, silicon rubber strip. That's Alpine's incredibly innovative GlideTouch™ panel.
Just like the touch pad on a laptop computer, you simply slide your finger over the strip until you've found the function you want (a sound guide helps you out). When you press it, it feels like you're pressing a real button! GlideTouch offers total system control, while allowing you to keep your eyes on the road — possibly the most innovative system control on the market.
This incredible innovation is enhanced by the sharp, easy-to-read BioLite display, which offers up all system information — you'll be able to digest it all with just a glance. And your passengers won't fail to notice just how incredible it looks.
Of course, the CDA-9855 isn't just about its cutting-edge controls. It also comes with a robust internal amplifier (18 watts RMS x 4 channels) and Bass Engine® Pro sound controls for perfect-sounding music. MediaXpander has the power to restore depth and fullness to your music, especially your MP3s and WMAs, which tend to lose something in the compression process. With iPersonalize, you can even adjust your system settings online at Alpine's website, burn it onto CD-R, and use that disc to set up your system automatically.
And if you never go anywhere without your iPod, you're in luck. The CDA-9855 works with Alpine's KCA-420i iPod interface, which not only lets you play your iPod through your car stereo system, it'll let you control your iPod's functions! And if you crave even more power, add external amplifiers to the three sets of preamp outputs.
You can enjoy the satellite radio service of your choice: built-in controls let you connect a compatible XM or SIRIUS tuner (XM or SIRIUS subscription and antenna also required), and enjoy the most comprehensive entertainment packages around — over 120 channels of music, sports, news, talk, entertainment, and much more.
CD receiver with built-in amplifier (18 watts RMS/50 peak x 4 channels)
Detachable, fold-down face with GlideTouch controls and BioLite display
Plays audio CDs, CD-Rs and CD-RWs, plus discs burned with MP3 and WMA files
Bass Engine Pro sound controls with iPersonalize setup options
MediaXpander (restores clarity and detail to compressed or broadcast audio)
MaxTune SQ tuner
12 FM/6 AM presets
Satellite radio controls (SIRIUS or XM subscription, tuner, and antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or territories
CD changer controls for Alpine Ai-NET changers only
compatible with Alpine's iPod interface adapter
4-volt front, rear and subwoofer preamp outputs
Amplifier Link — can control up to 12 Alpine V12 external amps
Clock
Wireless remote
CEA-2006 compliant amplifier
CD frequency response: 5-20,000 Hz
CD signal-to-noise ratio: 105 dB
FM sensitivity: 9.3 dBf
Helix SPXL 12 Competition
subwoofer de putere, destinat pasionatilor de SPL
diametru 12 inch
sasiu din aluminiu
putere: 1500W RMS, 3000W Max
impedanta: 2 x 2 ohmi
Fs: 31 Hz
Qts: 0,46
VAS: 38,4
adancime instalare: 21 cm
greutate: 21,5 Kg
Sinuslive SL A-1500
Im Inneren zeigt sich die moderne und hochwertige Technik durch einen sauberen Aufbau auf einer doppelseitigen Platine mit vielen oberflächenmontierten Bauteilen, kurz SMD-Technik.
Mit Hilfe der Kabelfernbedienung kann sehr bequem und einfach der Bassdruck vom Fahrersitz aus auf den persönlichen Hörgeschmack geregelt werden. Die Kabelfernbedienung ist selbstverständlich kostenfrei im Lieferumfang enthalten. Aufgrund der extremen Leistung ist ein professioneller Sicherungshalter mit vergoldeter 150 Ampère-ANL-Sicherung direkt an der Endstufe montiert und im Lieferumfang enthalten.
An diesen kann problemlos und sicher unser empfohlenes 35 mm² Batteriekabel angeschlossen werden.
Daten bei 14,4 Volt Versorgungsspannung:
Impulsleistung über 3000 Watt!
rms an 1 Ohm 1500 Watt (THD 0,8 %)
rms an 2 Ohm 900 Watt (THD 0,4 %)
rms an 4 Ohm 550 Watt (THD 0,3 %)
Frequenzgang 10-500 Hz (elektronisch begrenzt)
Rauschspannungsabstand 85 dB
Eingangsempfindlichkeit 0,2-5 Volt
Tiefpass variabel von 40-150 Hz / 24 dB
Subsonic Filter AUS-AN variabel von 20-50 Hz / 24 dB
Bassanhebung variabel von 0-12 dB bei 45 Hz
Abmessungen in mm Länge 445 x Breite 195 x Höhe 62
Die Kabelfernbedienung ist im Lieferumfang enthalten.
Bubble-Sticks mit vierfacher LED-Beleuchtung sorgen für blauen Schimmer.
