DVD / TV Auto / NavigatiiDVD, TV Auto, DVD Auto Player, TV Masina, LCD, Tv Tuner, TFT, Monitoare, Multimedia, ICE, Parasolar, Monitor Plafon , Navigatii, audio
Au mai aparut doua modele la preturi numai pt voi
JVC AVC 800 cu touch screen
Unitate multimedia 2DIN
monitor LCD TFT 7" integrat
slot SD-card
port USB 1.1
Giga MP3 (citeste MP3 de pe suport DVD)
setari monitor: Brightness/Color/Tint/Contrast
amplificator MOSFET 4x50W Max (4x20W RMS)
egalizator cu 7 benzi: 60Hz/150Hz/400Hz/1KHz/2.5KHz/6.3KHz/15KHz
convertor DAC 24 biti
compatibil: DVD-R/DVD+R/DVD-RW/DVD+RW/VCD/DivX/MPEG1,2/JPEG/DVD-audio/WAV/MP3/WMA/ID3-tag/CD-text
DTS
Dolby Digital
Dolby Pro Logic II
Time alignment (5.1 canale)
Headphone surround
preout-uri pentru 5.1 canale
iesire video RCA
intrare AV
intrare pentru camera video mers inapoi
panou frontal motorizat slide-out
telecomanda multifunctionala
memorie anti-soc
cod regiune: 2
sistem video: PAL
aspect 16:9
unghi vizualizare selectabil
Dimmer (manual)
tuner radio HS-IV cu RDS
filtru HPF
buton ATT (atenuator volum)
panou frontal detasabil slide-out
carcasa de protectie pentru panoul frontal
control iPod (necesita adaptor KS-PD100)
DAB control (pentru tunerul KT-DB1000)
control magazie CD/MP3 (CH-X1500)
intrare muting telefon
compatibil comenzi pe volan (necesita adaptor)
impedanta recomandata difuzoare: 4-8 ohmi
conector ISO
Garantie si posibilitate de deschidere a coletului inainte de efectuarea platii!!
Pret 2800 ron
Clarion Clarion Vrx 578 Rusb
DVD±R/DVD±RW ready * CD-R/RW ready * MP3 and WMA and iTunes® AAC (only USB) Compatible with ID3-TAG display * Official DivX® Certified product * Plays all versions of DivX® video (including DivX® 6) with standard playback of DivX® media files * Rear USB connector * 18 FM/12 MW/LW station presets * iPod direct connection and control * Shock proof memory * 24-bit D/A converter * Subwoofer volume control * 2-Zone entertainment: front and rear separate source control * Z-Enhancer Plus sound customisation * 2-band parametric equaliser * MAGNA BASS EX dynamic bass enhancement * Built-in High-pass filter & Low-pass filter * Built-in amplifier canceller * 4 channel × 50 watts of MOS-FET amplification * Fully motorised 7-inch TFT colour LCD monitor * Touch panel control * Adjustable display brightness * Phone mute * 1 AUX AV input (2-channel audio +video) * 6-channel audio pre-out * AUX Bluetooth audio/mobile-phone transceiver BLT373 ready * OEM steering wheel remote interface capability * CCD camera input via video line-in with reverse gear connection * Detachable control panel
Posibilitate de deschidere a coletului inainte de efectuarea platii.Garantie reala
Pret 2600 ron
Ambele sunt noi si au garantie
cine nu are urs sa-si cumpere, LOGAN!!
sal , spune-mi te rog , dimensiunile la jvc kv 700 - caut un cass cu dimensiunile de - lungime 23,3 mm si inaltimea de 10 - am un nissan teranno II cu casetofon de fabrica in bord - pentru 1din imi trebuie o masca pe care nu o gasesc iar pt 2din trb sa fiu atent la dimensiuni...
Adancime are 185 si inaltimea lui este de 100.Are si o rama neagra care vine pe marginea lui.Practic este exact cat 2 casetofoane una peste alta de unde si denumirea de 2DIN Daca intra in adancime si inaltime cu latimea fetei nu este o problema,iar latimea lui fara fata e exact cat a unui mp3 normal
